Old 03-12-2013, 03:48 PM   #1
lemonspeakers
Drives: blue
3 things: Even after reading many reviews, I still can't fathom these...
1) When people say this car is slow. How slow am I talking? Can you put it into perspective of a 1998 Honda Civic SI or a 1999 Acura Intega GSR?
2) This car raves all about handling and on turns? Can you explain this to me better in your own words to someone who drives a 2001 Acura TL?
3) Low COG like a Porche 911. Will lowering the car with proper Coil overs/ etc alter the COG in any way? Good or bad?
lemonspeakers is offline   Reply With Quote
Old 03-12-2013, 04:03 PM   #2
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
1.) Go take a test-drive
2.)Go take a test-drive
3.) Yes; depends on what you're trying to accomplish
zaptorque is offline   Reply With Quote
The Following 21 Users Say Thank You to zaptorque For This Useful Post:
86BRZ (03-12-2013), aghuman (03-12-2013), Anthonytpt (03-12-2013), Brzetto (03-25-2013), civicdrivr (03-13-2013), Dadhawk (03-13-2013), DBacon1052 (03-12-2013), Freeman (03-12-2013), Gixxersixxerman (03-15-2013), IloveBaldEagles (03-12-2013), jmaryt (03-13-2013), NOHOME (03-12-2013), R2RO (03-13-2013), raul (03-12-2013), rthaanum (03-13-2013), russv (03-13-2013), Silverdub (03-12-2013), SnapOv3st3r (03-25-2013), suaveflooder (03-12-2013), supragoods (03-13-2013), tomato86 (03-14-2013)
Old 03-12-2013, 04:12 PM   #3
Yruyur
Yruyur's Avatar
When you drive the car rev the engine out. Most people I let drive my car shift before 4k. You need to be up at 5 when you gun it snd shift so it drops you st 5k again.
Who cares what others think. If you like it after a drive then buy it.
The Following User Says Thank You to Yruyur For This Useful Post:
Old 03-12-2013, 04:13 PM   #4
suaveflooder
I'll answer a little better than zaptorque, although he is 100% correct in this matter. Test drive is your best bet.
The car is slow, but when you buy a sports car, you are buying the "the whole package" You will probably be quicker than both the civic and acura, but the car is VERY light. Once again, if you are worried about being fast, find another car. This car is not designed to be fast, it is designed to be balanced. Toyota has done it perfectly. The interesting thing is that my wife's 07 civic 2 door feels like a pig after driving my FR-S.
As far as coilovers are concerned, you have them on all 4 corners from the factory on the twins. If you are talking about adjustable coilovers, zaptorque is once again correct. It really depends on what you have planned for the car
suaveflooder is offline   Reply With Quote
Old 03-12-2013, 04:17 PM   #5
zaptorque
zaptorque's Avatar
Listen to this guy, the little boxer really comes alive around 5500 RPM
Old 03-12-2013, 04:21 PM   #6
Mr.Corvus
Mr.Corvus's Avatar
Drives: dirty er'ryday
1. It's not "fast" in the sense that you're going to outrun a muscle car with twice the HP on a flatrack but once you get that little engine going, it's fun no matter what.
2. Listen to suave, this thing is balanced. As such, it handles turns like a champ.
3. 'Nuff's been said on this one.
Mr.Corvus is offline   Reply With Quote
Old 03-12-2013, 04:26 PM   #7
whtchocla7e
Drives: 2013 FR-S Hot Lava
The car is a dog. It's mini-van slow. If you are between the ages of 16-22, you will find it uncool.
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following 11 Users Say Thank You to whtchocla7e For This Useful Post:
Allch Chcar (03-12-2013), Craig (03-13-2013), FRSPirate (03-12-2013), mkiisupra (03-13-2013), Nepenthe (03-13-2013), raptor87 (03-26-2013), SneakyPete (03-12-2013), sprintertrueno86 (03-12-2013), TeamZleep (03-26-2013), tomato86 (03-14-2013), tracerit (03-13-2013)
Old 03-12-2013, 04:32 PM   #8
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i bought it because i loved it at the first curve, its just a matter of making it faster slowly but surely... if you like it but its just too slow, put a turbo in it your self, that simple
Silverdub is offline   Reply With Quote
Old 03-12-2013, 04:33 PM   #9
shawnperolis
shawnperolis's Avatar
Drives: 2013 Scion FR-S MT "Panda"
1. This car is slow compared to other sports cars. It is about as fast as my old stock 2006 Honda Civic Si, which is definitely faster than a '99 Civic Si. (Stock B16s be mad overrated, yo)
2. It handles SO MUCH better than my 2006 Civic Si with upgraded suspension. No comparison between the two cars in this area.
3. Lowering a car will probably lower the COG a bit... But most things I've read say that a .8" drop is about the best you can do, any more will hurt the handling without other serious suspension mods.
shawnperolis is offline   Reply With Quote
Old 03-12-2013, 04:59 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I notice the same thing with my 07 tC, feels sloppy and huge now after getting used to my FR-S. Even though the tC only weighs 100lbs more than the FR-S...
AsphaltLover (03-14-2013)
Old 03-12-2013, 04:59 PM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Yup. It's a geezermobile. I bought one. Comprable to my 95 Grand Caravan. Uncool
If you lower it a bunch you'll be scraping every speedbump and driveway transitions.
It's low to begin with and has little body sway. Skidpad testing is the way to evaluate cornering traction.
Old 03-12-2013, 05:20 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The only meaningful thing I can add is on #2, compared to just about everything you listed (except maybe the Integra, idk) the main difference you will feel is how FLAT it goes around corners. The car doesn't roll over like you are used to, it gives the driver confidence to push the car a little further and you'll quickly realize that the dynamics of the Toyobaru mean that the chassis is designed to stick to the ground, the car does exactly what you tell it to do almost on a telepathic level.
ineedyourdiddly
Old 03-12-2013, 05:21 PM   #13
ExWhyZer0
ExWhyZer0's Avatar
Drives: Whiteout FR-S M/T
This car sucks bro don't buy it. Get that stang bro. Mad props. You lift? :P
ExWhyZer0 is offline   Reply With Quote
The Following 16 Users Say Thank You to ExWhyZer0 For This Useful Post:
Apoc (03-13-2013), chenshuo (03-12-2013), CrazyWookiee (03-12-2013), dammitcubs (03-12-2013), fish66 (03-13-2013), Freeman (03-12-2013), Lonewolf (03-12-2013), mact (03-13-2013), Pete (03-12-2013), shawnperolis (03-12-2013), SneakyPete (03-12-2013), Squishy86 (03-13-2013), suaveflooder (03-12-2013), tbwoodlee (03-13-2013), tomato86 (03-14-2013), white_knight (03-13-2013)
Old 03-12-2013, 05:24 PM   #14
NOHOME
Drives: RAVEN
Unless you are smitten by the looks, ( 6/10 on my scale... meh...) the car makes no sense on paper. Minivans and Camrys ARE going to leave you in the dust. Problem is compounded by the fact that the car seems to act as a challenge to a certain demographic when they see it.
But do yourself a favour and go drive it. There is a lot I am willing to live with (or without) for a car that has the handling properties of this car.
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
Razz (03-14-2013)
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 10:33 AM
i'm getting confused reading the tire booklet chenshuo BRZ First-Gen (2012+) — General Topics 23 02-09-2013 07:34 PM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 10:05 AM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
... reading the reviews? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 6 04-26-2012 09:08 AM
