Old 03-10-2013, 03:38 PM   #15
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Sounds to me you're wanting half manual and half automatic. Which ever way you go, be consistant. In manual mode, shift when needed. Don't feel like shifting, leave it in automatic.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
Beyer Subaru (03-10-2013)
Old 03-10-2013, 03:55 PM   #16
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I can shift into 6 at 38mph.. And it will run that way all 5 miles on base that I had to for work.. Speed limit is 35, so I'd get it into 6th at 38 and it would stay there untill about 35-36 then downsift into 5th.. So sounds like its normal to me
Gixxersixxerman is offline   Reply With Quote
Old 03-10-2013, 03:55 PM   #17
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Originally Posted by tim35ct View Post
you were in manual mode, which means you manually up n down shift
Originally Posted by FirestormFRS View Post
That would be normal. The whole manual thing is supposed to get you more involved.
Originally Posted by Auto-Hauss View Post
If your allowing the transmission to downshift for you when you slow down in manual mode, why not just it in full auto mode? I wouldn't want to lug the engine to much. Use manual when your doing a little more spirited driving.
Like the others said:
Manual = You Shift
Auto = The car Shift
If you don't want to shift, don't put into manual.
Beyer Subaru is offline   Reply With Quote
Old 03-10-2013, 04:12 PM   #18
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i don't think anyone's quite understanding this. the automatic transmission, regardless of whether it's in drive or in manual mode will downshift automatically. if you're in 5th and come to a slow roll for more than a couple seconds, it will automatically switch to second gear. If you stop completely, it will automatically go back to first. Yes you can downshift on your own if you want to but it's still supposed to take care of it for you as needed. In this case it did not. Instead it got stuck at a low rpm in 5th gear and prevented the car from moving any faster. That is not normal behavior for an automatic in manual mode.
abutterman is offline   Reply With Quote
Old 03-10-2013, 04:18 PM   #19
Gixxersixxerman
And I don't think you read my post.. You can/the car will stay in 5th around 30-35mph, without downshifting.. As I did this regularly.. Off the top of my head I don't remember the speed it downshifts into 4th
Old 03-10-2013, 04:22 PM   #20
abutterman
abutterman's Avatar
ok well even forgetting about when it should downshift, you say you can drive the car perfectly fine in 6th gear at 38mph. I was at around 35 in 5th with the rpm stuck real low and the car no longer accelerating.
Old 03-10-2013, 04:26 PM   #21
Gixxersixxerman
I'm just maintaining speed.. It's about 5 miles from the gate to where I worked on post.. All 35mph.. Three stop signs on the way.. But I also average about 38 mpg and its because during my normal commute its driving like this.. Now that I've been living in Vegas.. It's a different story and I'm down to around 27 mpg lol
Old 03-11-2013, 03:57 AM   #22
jlu
jlu's Avatar
Drives: Asphalt AT FR-S
I noticed the threshold for the manual mode auto downshifts are pretty low when not in sport mode (similar to the transmission itself). It's usually content to chug along in 5th or 6th at 1500-2500 RPM. It's much better at sensing downshifts into 2nd and 1st gear in manual mode.
I feel like in sport mode it's more aggressive with its automatic downshifts, that might help you out.
jlu is offline   Reply With Quote
Old 03-11-2013, 10:41 AM   #23
Originally Posted by Jester View Post
my AT in manual mode doesn't shift down until about 1300-1500 rpm anyway...
That's my experience as well. In Full Manual Mode, I've never had the AT downshift by itself until the computer thinks its going to stall. Has nothing to do with speed but RPMs, or at least that is how it appears to me.
If, as the OP says, the car was moving at 35 or so MPH the entire time, I wouldn't expect it to downshift, even if I was trying to accelerate, just like if I was driving a stick in 5th gear at 35MPH. I could do it, but I wouldn't expect to accelerate too quickly.
Old 03-12-2013, 03:46 AM   #24
Someguyk
Someguyk's Avatar
When I drive in full manual mode my car doesn't downshift on its own until I come to a complete stop or to a crawl. But I usually downshift on my own since I'm in that mode for a reason...to control my selection of gears.
2013 AT FRS...Stock... for now...
Someguyk is offline   Reply With Quote
Old 03-12-2013, 01:34 PM   #25
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
If I'm slowing down I really don't mind letting the AT downshift on its own, much smoother that way. If I know I'm going to need to accelerate soon, I'll obviously downshift myself to get in the correct gear, otherwise I don't mind cruising at 35 mph in 5th gear.
EK_Golfer is offline   Reply With Quote
Old 03-14-2013, 08:33 AM   #26
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
It is normal for the AT FRS to behave like this in Manual mode. It downshifts when you come to a stop and there is a distinct speed/rpm cutoff. However, and guys this is a good thing, having it hold a gear at low rpm/mph in manual mode is a good thing. Running a fixed gear Virtual Dyno, or real dyno, on this would be impossible if manual mode didn't hold a gear in the low RPM range.
pixel67 is offline   Reply With Quote
Old 03-14-2013, 10:11 AM   #27
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Maybe you should try to drive it in the same way you should drive a sequential gearbox. Downshift as you slow down, like a motorcycle...so you are always in the right gear.
Rayme is offline   Reply With Quote
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 03:35 AM
Manual upshift/downshift and smoothness kchkwan BRZ First-Gen (2012+) — General Topics 61 02-06-2013 08:35 PM
AT Manual Mode Easter Egg? whataboutbob Engine, Exhaust, Transmission 2 12-14-2012 12:03 PM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 12:40 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 04:02 PM
