Southern California SoCal
Old 02-27-2013, 07:50 PM   #1
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
Chirp in SoCal Advise
I noticed chirping in my FR-S and want to get it fixed. I don't want to go to a dealer thats never done it before though. Has anyone else had the chirp fixed? If so, which dealership did you get it done at?
DBacon1052 is offline   Reply With Quote
Old 02-27-2013, 08:25 PM   #2
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
It's normal but if its bugging you that much change gas stations I believe using shell 91 gas kills the chirp noise here and there
oso_25 is offline   Reply With Quote
The Following 2 Users Say Thank You to oso_25 For This Useful Post:
DBacon1052 (02-28-2013), illmatic (03-09-2013)
Old 02-27-2013, 09:18 PM   #3
that_one_guy
Drives: none
everyone thinks the chirping is the fuel pump but its actually an electrical problem. you can adjust it with the volume knob on your stereo, just keep turning up the volume until the chirping is gone
that_one_guy is offline   Reply With Quote
The Following 9 Users Say Thank You to that_one_guy For This Useful Post:
danthedirt (02-28-2013), DBacon1052 (02-28-2013), Fish (02-27-2013), ft86me (03-09-2013), Grateful Dave (03-17-2013), MF_DEUCE (03-09-2013), Shinobi2u (02-28-2013), suaveflooder (02-28-2013), typeray12 (03-09-2013)
Old 02-27-2013, 09:29 PM   #4
WRM
I second this. Out of Unocal 76, Chevron, and Shell, Shell has been quiet. Crickets are usually the worst in the heat of summer.
I second this also, especially if you have upgraded to the OEM Audio Plus system.
WRM is offline   Reply With Quote
The Following User Says Thank You to WRM For This Useful Post:
Old 02-27-2013, 09:32 PM   #5
subiestar
Drives: CBS Limited BRZ
I was just saying this in the general FR-S section, I've been using Chevron with hardly any chirps. I tried Shell 91 and it gave me a lot of chirping, switched back to Chevron and it was gone.
subiestar is offline   Reply With Quote
The Following User Says Thank You to subiestar For This Useful Post:
Old 02-27-2013, 09:42 PM   #6
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
I've used only Shell up to now, and the chirping has been consistent. Maybe I'll try Chevron.
EK_Golfer is offline   Reply With Quote
The Following User Says Thank You to EK_Golfer For This Useful Post:
Old 02-27-2013, 09:57 PM   #7
Fish
Fish's Avatar
Drives: 2015 Yuzu RS1.0 Scion FR-S #893
I've honestly forgot about the chirping noise.
I believe a few people have gone to Longo for that fix though.
Fish is offline   Reply With Quote
The Following User Says Thank You to Fish For This Useful Post:
Old 02-27-2013, 10:24 PM   #8
DSOmegaX
DSOmegaX's Avatar
There's really no point fixing this at this time. Everyone I know that's gone in, all of them had the chirping come back (basically means its not a fuel pump issue like they sat it is, and they have no idea what's causing it). you'll just have to live with it. Honestly, as others are saying, you'll hardly notice its there after a while.
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Old 02-27-2013, 10:28 PM   #9
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
The noise is the fuel pump, everyone knows that. They replace it with the exact same part and the chirps come back...its from fuel and lack of internal lubrication in the pump, aka its normal, but no one know what the long term effect of the lack of lubrication might have...Replacement means the chirp goes away for about 300 miles, until enough of the US gas has gone through and worn the lubricant off of the part that chirps....the pump runs at 2400psi iirc...
Pscylo is offline   Reply With Quote
The Following User Says Thank You to Pscylo For This Useful Post:
Old 02-27-2013, 11:26 PM   #10
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Our gas sucks here.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
The Following User Says Thank You to Tim_Asphalt_FRS For This Useful Post:
Old 02-28-2013, 03:03 AM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Chevron &/or Mobil works for me
Shell didn't cut it
The Following User Says Thank You to Bonburner For This Useful Post:
Old 02-28-2013, 03:44 AM   #12
QuikSilveRX-8
QuikSilveRX-8's Avatar
Drives: SE3P
Well, if loss of lubrication in the fuel pump is the problem. Try premixing with Idemitsu or Royal Purple in the gas tank(4 oz/fill-up). It burns off clean and won't clog your sock filter, fuel lines, injectors, or OEM Cat-converter and always fill up with 91 oct.
Three moving engine parts, yet complicated... Or do I mean complex?
QuikSilveRX-8 is offline   Reply With Quote
The Following User Says Thank You to QuikSilveRX-8 For This Useful Post:
Old 02-28-2013, 04:05 AM   #13
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Thats been the bandaid to counter ethanol
Old 02-28-2013, 10:43 PM   #14
QuikSilveRX-8
Drives: SE3P
Why would you use ethanol on these cars anyway?
Advise Needed Wheels USMC -FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-03-2013 10:39 PM
Guys I can really use some advise... ScionFrsFan Engine, Exhaust, Transmission 27 12-31-2012 12:03 PM
Advise On Purchasing Fr-s Please! 7EASTAP Scion FR-S / Toyota 86 GT86 General Forum 7 09-18-2012 06:45 PM
Legal guru I need an advise Vino Scion FR-S / Toyota 86 GT86 General Forum 31 09-13-2012 07:13 AM
FR-S buying experience... advise chessplaya2010 Scion FR-S / Toyota 86 GT86 General Forum 30 07-31-2012 04:37 PM
