Old 02-26-2013, 04:28 AM   #57
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by 20valvewynn83 View Post
No I just get trained on it from corporate. And as I stated people can say what they want and do what they won't to their cars but I still think 5w30 is too heavy for this car I wouldnt go higher then 5w20 but that's me. Personally I will stay with 0w20 and run a better quality oil like eneos sustina.
It would be much welcomed if you could elaborate on what have you learned on training that leads you to conclude the oil recommendation by the Toyota/Subaru engineers who designed the car is wrong.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
blu_ (03-31-2013), JP (02-26-2013), track_warrior (02-26-2013), tripjammer (03-07-2013)
Old 02-26-2013, 05:36 AM   #58
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Just curious...was any of the VVTi changed prior to your modding? Or was it the stock VVTI that is known to throw CELs and has a TSB for replacement since Aug of last year?
Pscylo is offline   Reply With Quote
Old 02-26-2013, 08:34 AM   #59
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
As you said do whatever you want. Subaru and Toyota SUGGEST 5w-30 though for severe usage which likely means their experience (instead of book based training by a corporate trainer) matched my own data that we see low oil pressure with 0w-20, especially when warm and at high RPM. 0w-20 is great for Eco though. Based on my data alone my car will never see 0w-20 again.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
ATL BRZ (02-26-2013), blu_ (03-31-2013)
Old 02-26-2013, 08:41 AM   #60
brillo
Drives: 2013 Firestorm FR-S
Why not 0w-30 instead for better cold start protection?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 02-26-2013, 08:42 AM   #61
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's also fine.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-26-2013, 09:06 AM   #62
OrbitalEllipses
Drives: Attitude
That's also fine.
In this scenario it's the second number that's more important. So as Dave said, 0W-30 is fine. My favorite oils don't come in 0W-30 though.
Sargy (02-26-2013)
Old 02-26-2013, 09:26 AM   #63
celica73
Because 0W-30 generally has inferior properties (lower HTHS for example) to 5W-30.
Old 02-26-2013, 09:29 AM   #64
xwd
I'm using the Motul 8100 X-Lite 0w30 which has fairly good reviews.
Old 02-26-2013, 09:33 AM   #65
markitect
Drives: Scion FRS
I hate to go there, but could you be running into oil starvation problems. I haven't heard of any problems yet, but Subarus in general are know to have problems. If you have big sticky tires all the oil might be stuck in the head.
The cam timing is adjusted by oil pressure, so if it is starting to drop they may not adjust properly. I have no idea what the required pressure is vs when the sensor reports low pressure.
Of course you should also just plain make sure the oil is full.
markitect is offline   Reply With Quote
Old 02-26-2013, 09:53 AM   #66
Sargy
Long Distance Driver
Sargy's Avatar
Originally Posted by dwx View Post
The 2.5L turbo Subarus are pretty famous for cracking the ring landing on the #4 piston. I did many years ago when I had an EJ257 block in my 02 WRX. Poor tunes on the 08-09 WRX/STi models led to those failures even on stock cars. People got tunes as a reliability investment.
It's very easy to tell with a compression test. The smoking on startup happens with the cracked ringlands, here is a video:
But the codes you are getting aren't indicative of it and usually there is no associated noise/rough running until things get really bad.
Hey I know the guy that started the car! small world hahahaha. He has a Corvette now.
Sargy is offline   Reply With Quote
Old 02-26-2013, 10:03 AM   #67
OrbitalEllipses
Drives: Attitude
Oil pooling in the head at high Gs, very typical Subaru problem...same with cracked ringlands. I hope neither are the case here.
Old 02-26-2013, 10:08 AM   #68
Sargy
Sargy's Avatar
The Following User Says Thank You to Sargy For This Useful Post:
Old 02-26-2013, 10:09 AM   #69
OrbitalEllipses
Drives: Attitude
Originally Posted by Sargy View Post
And this is a 2L Subaru. 2L WRX was famous for chewing bearings.
Old 02-26-2013, 10:20 AM   #70
ft_sjo
Drives: GT86
Gotta love dealership fitters pretending that they're engineers.
The Following 3 Users Say Thank You to ft_sjo For This Useful Post:
D1cker (02-26-2013), Gords_zenith (03-02-2013), track_warrior (02-26-2013)
Scion/Toyota broke 3rd brake light applying tint Lefty Cosmetic Modification (Interior/Exterior/Lighting) 32 10-31-2019 06:23 PM
How to wash your car in an hour or less, make it look like a pro, and not go broke... seven Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 141 01-30-2015 11:32 AM
