Old 02-18-2013, 08:06 AM   #211
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by so26 View Post
At the time of my runs I had BP gas in the car with a fuel level between 1/2 to 1/4. Also I dropped my speed a couple of mph below 60 before flooring it.
I had almost a full take of gas in the car and i also dropped my speed a couple of mph below 60 before flooring it. the floor was just a little wet so it cud have affected the run
brichard0625 is offline   Reply With Quote
Old 02-18-2013, 02:25 PM   #212
developer
Drives: BRZ Limited
Using some of the information I have gleaned from other posts I have come up with what looks like a very accurate reading of how much fuel is in the tank. It seems to be much more accurate than the default fuel percentage that is in Torque.
Torque PID setup for accurate fuel remaining.
PID: 2129
Long name: Fuel Remain (or whatever you want)
Short name: Fuel Remain (or whatever you want)
Minimum Value: 0.0
Maximum Value: 100.0
scale: x1
Unit: Gal
Equation: ((A*13.2)/100)
OBD Header: 7c0
The 0 in 7c0 is a zero not the letter O.
developer is offline   Reply With Quote
The Following 7 Users Say Thank You to developer For This Useful Post:
Brody602 (03-20-2013), jpit (02-18-2013), melon (02-16-2014), nix (02-20-2013), reeves (03-18-2013), Sarlacc (11-30-2013), shirker (06-07-2013)
Old 02-18-2013, 02:39 PM   #213
developer
Drives: BRZ Limited
PID: 2129
Minimum Value: 0.0
scale: x1
Unit: Gal
OBD Header: 7c0
If you want the fuel remaining in Liters:
Unit: L
Equation: ((A*50)/100)
The Following 4 Users Say Thank You to developer For This Useful Post:
lazyluka (02-18-2013), melon (02-16-2014), nix (02-20-2013), Sarlacc (11-30-2013)
Old 02-18-2013, 06:42 PM   #214
so26
Drives: Raven FR-S 6MT
Should I be monitoring AFR (commended) or AFR (measured)?
so26 is offline   Reply With Quote
The Following User Says Thank You to so26 For This Useful Post:
Old 02-18-2013, 07:14 PM   #215
developer
Drives: BRZ Limited
I do measured. My reasoning is that I want to know the actual AFR, not what the ECU is commanding.
The Following User Says Thank You to developer For This Useful Post:
so26 (02-18-2013)
Old 02-25-2013, 12:49 AM   #216
aiiee
Drives: 2011 Porsche Cayman S
Originally Posted by andreyiv View Post
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running).
Without further delay, here's the info:
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from.
Edit: The incorrect readings of 189 and 1840 I was getting were caused by a faulty OBD adapter. Just received another one and have no problems.
Enjoy!
Andrey
I would like to do this with my Cayman S. Can you tell me how you converted the output from Torque Scan into a useable format to create the extended PID? I have tried looking everywhere but no luck at all.
aiiee is offline   Reply With Quote
Old 02-25-2013, 10:48 AM   #217
Ingen
Drives: Ultramarine FR-S 6MT
Is there a sensor for transmission oil temp?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-25-2013, 10:51 AM   #218
aiiee
Yes there is.
Old 02-25-2013, 05:09 PM   #219
ML
ML's Avatar
Drives: 13 White MT FR-S
I haven't noticed but is there a oil pressure sensor available?
Old 02-25-2013, 05:17 PM   #220
Yruyur
Yruyur's Avatar
Only for no pressure.
Old 02-25-2013, 11:47 PM   #221
reeves
Originally Posted by aiiee View Post
Yes there is.
Why doesn't anything show up for this guage? Is there a custom PID you need for this too? I see 2 Transmission temperature selections.. tried both, but none of them works.
Old 02-26-2013, 08:54 AM   #222
andreyiv
Drives: Hot Lava FR-S
No problem. PM me and I'll help you through the process I went through to find it.
andreyiv is offline   Reply With Quote
Old 02-26-2013, 04:50 PM   #223
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Since this seems better than any current IOS setup what's the cheapest way to get into a Android device that will support/run Torque? An old beat up phone? Cheap tablet? Just needs bluetooth and I'd guess some min food-related OS or whatever?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-26-2013, 04:53 PM   #224
Foobar
SLO NO MO
Foobar's Avatar
I'd go with a tablet so it's easier on the eyes if you want to see things in realtime.
Plenty of cheap options out there, but you can't go wrong with the Google Nexus 7 @ $199.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
