Old 02-19-2013, 06:37 PM   #71
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by Basti View Post
If one wanted to make the garnishes functional the metal of the fender would need cutting in order to increase the opening but then the clip holes would be gone.
I'm currently more worried about that part as I'm not too fond of just glueing the vents to the fender.
Now imagine cutting all excess fender off on the inside and just letting little noses for the clips stand... one might then need to cut the garnish in the same way and hope that there will be enough space left between the visible outside of the garnish and the inner clips.
Even if that works (and, though it'll need some skill sounds very possible) this would not guarantee a good finished look. Very iffy.
However, if you guys CAD sth. like that up I'll be the first one interested.
Or maybe I'll visit a body shop for that...
This is one of the designs we came up with. It's just a photoshop, no cad designs for it yet, but the process is started. The idea is to be functional , so this side vent would actually be a vent into the engine bay area. Obviously, that doesn't address the other concerns of such a vent, such as its effectiveness, but it would be an actual open vent nonetheless.
Sent from...somewhere?
Old 02-19-2013, 08:43 PM   #72
mad_sb
Drives: 2013 Asphalt FR-S
you can move a lot of air through 6 square inches given enough differential pressure, which is the name of the game anyway.
I'm going to order a digital manometer anyway so I may try and get some underhood and on the hood measurements as well as at the fake vent.
Old 02-20-2013, 12:49 AM   #73
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
You could also slap on a 12v Fan for the vent to create low pressure under the hood.
Xanatos is offline   Reply With Quote
Old 02-20-2013, 05:15 PM   #74
GregV
Drives: Kia Stinger GT2
I noticed the hood lifting on my drive home today, only doing about 70-75mph but there was a lot of crosswind.
Saw a good 1/2" of movement at least where the hood meets the fender.
GregV is offline   Reply With Quote
Old 02-21-2013, 06:34 AM   #75
YDNA
YDNA's Avatar
Drives: Raven FR-S
Originally Posted by wbradley View Post
In Ontario (Canada) if you drive 180 km/h you might as well just give your car to the police since they will seize it when you are stopped, plus up to $10,000.00 fine for "stunt driving".
Even on the unrestricted stretches of autobahn, is this really the car to be burying the speedometer needle?
That sucks. Police cars here are only factory tuned. If you can do better than 180K they can't catch you, so they don't even try.
YDNA is offline   Reply With Quote
The Following User Says Thank You to YDNA For This Useful Post:
racecaresuaceb (03-11-2013)
Old 02-21-2013, 10:30 AM   #76
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
barvo..
Ranatsu is offline   Reply With Quote
Old 02-21-2013, 11:10 AM   #77
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
You could always install one of these on your hood!
Scott
naikaidriver is offline   Reply With Quote
Old 02-27-2013, 10:49 AM   #78
GregV
Scott
Ironically on that Civic the front spoiler is probably of greater benefit.
Old 02-27-2013, 11:13 AM   #79
CSG Mike
CSG Mike's Avatar
After specifically paying attention to the hood, I noticed that it flaps at 120+....
Old 02-27-2013, 11:34 AM   #80
QFry
QFry's Avatar
Drives: '13 Argento FR-S
After watching the 500 this weekend i noticed while looking through their hood cam that the hoods on these professionaly built race cars flex and wave the same way ours do (just at different speeds...) so could end up being more of a wind sucking the flexible hood up issue (like blowing across the top of a piece of paper) than a problem with engine bay pressure
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
The Following User Says Thank You to QFry For This Useful Post:
charged86 (03-13-2014)
Old 02-27-2013, 05:09 PM   #81
Basti
Basti's Avatar
I believe that both are true and that we'll hardly ever be able to fix the hood bending at very high speeds due to the airflow over the hood.
However, I also think that a great deal of the air causing this phenomenon comes from under the hood.
Think about it: the Toyobaru's engine bay is very well covered; pretty much closed off in comparison to other cars'.
Even my very own Honda was an underbody-slut in comparison, it was just THAT open ^^
Still, at over 160km/h, it felt as if I had a 5k front splitter, functional diffusor and adjustible rear wing installed, which I didn't. So my expectations were kinda high for the BRZ. Well, bummer...
Best way to confirm would be to drive w/o the lower engine bay cover, see what happens. Will enough air be evacuated so the hood will actually bend later in the process of acceleration?
I unfortunately don't have a garage to do that kidn of thing and I'd depreciate that action anyway.
I have another point to reinforce the theory that the engine bay air causes early hood lifts: the flapping.
The continuous stream of air above the hood should create a continuous rise, right? So how does it flap?
First thing that comes to mind: the pressurized air under the hood evacuates through the gaps in the newly-bent hood, relieving the inside pressure momentarily so the hood goes back down, increasing the pressure again and 'round we go...
Basti is offline   Reply With Quote
Old 03-01-2013, 09:37 PM   #82
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
i have had this issue occur recently too, but it was the first time that i payed attention to the hood. so i don't know how long its been like that, its probably cause the hood is so light weight and air is creeping into the engine bay
R2RO is offline   Reply With Quote
Old 03-01-2013, 10:34 PM   #83
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Wont the Grimspeed Hood strut fix this issue? I mean, if your hood is gonna fly open, might as well create some gas pressure to keep it from hitting your windshield momentarily right?
http://www.rallysportdirect.com/Grim...rce=GoogleBase
LeeMaster is offline   Reply With Quote
Old 03-01-2013, 10:54 PM   #84
Captain Insano
How common is this in other vehicle models? Seems like it would be very common. For example, I noticed this yesterday driving my 2012 honda pilot on the highway at 70ish mph. Is this really a problem up until the point the hood is ripped off? Nobodys hood has been ripped off yet.
Captain Insano is offline   Reply With Quote
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 09:51 AM
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 07:40 PM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 11:11 AM
Post you speeds for fun... seven Off-Topic Lounge [WARNING: NO POLITICS] 48 01-27-2013 08:37 PM
RedLine Tuning Hood Quick Lift tonystewart Cosmetic Modification (Interior/Exterior/Lighting) 4 12-15-2012 01:28 PM
