Old 09-02-2012, 02:13 PM   #57
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
looks great with the drop! well done sir
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 01-23-2013, 09:10 PM   #58
2013BRZ
2013BRZ's Avatar
Drives: 2013, Galaxy Blue Silica, Limited
Hey Draco-Rex, Steve_12v, what size rings are you using??
2013BRZ is offline   Reply With Quote
Old 01-23-2013, 09:32 PM   #59
OrbitalEllipses
Drives: Attitude
Mine came with 65mm to 56.1mm hub rings.
Old 01-27-2013, 11:57 AM   #60
Jay Jr
Jay Jr's Avatar
Drives: 04/2013 BRZ-L
Originally Posted by Draco-REX View Post
But, understeer is like a light switch. Once the front lets go, the car continues to understeer and punching the throttle does not shift the car to oversteer. Instead you just continue to push wider. So the trick is to stay just within the front tire's grip. Otherwise you have to back off the throttle, shift weight to the front with a tap of the brakes if lifting isn't enough and unwind the steering wheel a bit to get front grip back. But once you get it back, you can literally yank the car back on line.
Now, this isn't the end of the world. A good alignment and a little more roll stiffness (through stiffer springs or larger sway bars) should let this car explore 10/10ths and keep the balance we love so much. I have the RCE Suspension Starter Kit going on this week. That should take care of what I'm experiencing and unlock the upper 10ths. This car with good tires has amazing levels of grip. I can't wait to see what happens with a good alignment.
Any reviews on cruise 80% 90% 100% with the new ride height/ spring rate swap? I'm curious how it respond and if you put any camber into it? I know the lightswitch understeer is tunable but want to hear your experience thus far!
Jay Jr is offline   Reply With Quote
Old 02-18-2013, 02:42 AM   #61
2013BRZ
2013BRZ's Avatar
These are my 17x8's, wrapped in Michelin Pilot Super Sports, 225/45 (closest size i could get the super sports in...)
They are powder coated a mix of Anthracite and Black (lets call it gunmetal), using extended Ray's lugs. I popped the Wedssport logos from the center caps, sprayed them black and clear coated
them before replacing them with glue.
I'm not experiencing any vibration from not using my hubcentric rings, I'll keep you all posted if I do.
To remedy the TPMS light from not using the stock sensors (doesn't look like they would even have fit on the narrow mounting surface on this wheel) I followed this tutorial: http://www.ft86club.com/forums/showthread.php?t=7827
Thanks for the inspiration guys, hopes this serves to further that of others out there.
Old 02-18-2013, 08:20 AM   #62
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Q for OP, where did you buy them?
Adeets is offline   Reply With Quote
Old 02-18-2013, 01:16 PM   #63
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm sorry, I thought I had replied to this already.
Cruise is perfectly fine. I hardly noticed a difference in the spring rates. The tires are noisy, but that's to be expected ith this type of tire. However, the stock Michelins are pretty noisy for touring tires anyways, so it's a wash there.
8/10th is the same. Fun, responsive, and plenty of play in the tail for general hooning.
9/10ths+ is much improved. The front doesn't feel like it's struggling and the noise just shoots around corners pulling the tail with it. I haven't had a chance to take it to an AutoX yet, however. I was unable to attend the last two events I wanted to last year. But I have driven it down a very agressive road here in OH called the Triple Nickel (rt 555). It was fantastic and I was able to hunt down and hang on to a turbocharged G35 coupe. I could really get into the throttle early and launch out of turns at full song. I actually had to hang back and gap him before a turn so I could get a good run on exit to compensate for his power between the turns. Eventually he let me pass (then I missed a turn and ended back up behind him again. Oh well. ). But as for my desired setup, this car is spot-on. I'm extremely happy with it. And I'm amazed at how little I had to do to achieve this.
I got mine from RavSpec. They're a vendor here on the forum.
After getting some real camber on the car, I'm thinking I should have gone with the +35s. The perfectly flush tires I had before are now not so flush. But I do worry about the steering feel if I did. So I'm happy with what I've got.
The Following User Says Thank You to Draco-REX For This Useful Post:
Fly Guy (03-31-2013)
Old 03-30-2013, 11:54 PM   #64
OrbitalEllipses
Drives: Attitude
17x8+42
225/45/17
Old 04-05-2013, 12:54 PM   #65
frslee
Just drive it
Drives: 13' FR-S
Looks awesome. I guess the ET42 is the way to go.
I'm planning to get 17x8 Kosei or Enkei wheels with 235/40/17.
Can't wait until next summer!! Need to burn these stockers first, then use winter tires... then new set for summer.
frslee is offline   Reply With Quote
Old 12-02-2013, 11:06 PM   #66
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm about to pull the trigger on similar wheels in exactly the same size/width/offset as OP....but with factory 215 tires for the time being.
I know the rears will be fine, but the fronts look pretty flush to the fender and i'm worried i'll get scrubbing issues. Should i be concerned at all?
I'm lowered about 1 inch all round with -1.2 camber in front. Daily driver, no track use.
Fizz is offline   Reply With Quote
Old 12-02-2013, 11:33 PM   #67
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Surely you guys that are lowered some are running spacers with this offset?
Also on the 8" weds I assume there is zero concave correct? I know 9" have some concave but curious on 8"..
The Following User Says Thank You to OICU812 For This Useful Post:
Fizz (12-03-2013)
Old 12-03-2013, 09:12 AM   #68
df.dima
Drives: FR-S and Mazda 3 Sky
http://www.ft86club.com/forums/showp...5&postcount=44
df.dima is offline   Reply With Quote
Old 12-03-2013, 12:21 PM   #69
OICU812
Just a dude
OICU812's Avatar
Ya that kinda answered.."nothing"?
Old 12-03-2013, 12:35 PM   #70
OrbitalEllipses
Drives: Attitude
8" are flat faced, no concave. The hub is pretty deeply recessed though the spokes don't have much curvature to them.
Top: my 17x8+42
Bottom: Foobar's 17x9+35
Note how my spokes don't curve much from the hub while the 9" wheel spokes visibly curve out.
Originally Posted by kask2_6.0 View Post
Jealous of his brakes!
Originally Posted by Foobar View Post
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Anthonytpt (12-03-2013), OICU812 (12-03-2013)
Wheel Directory: SSR Competition 17x8.0 +38 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 08-07-2015 06:38 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 07:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
Pre Order TC105N vividracing Wheels and Tires 27 07-30-2012 03:28 AM
