#827 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Thanks
#828 |
Drives: Argento FRS
Everything went well with the install, until I torqued one of the 10mm bolts and it snapped off. Luckily my neighbor is a mechanic and was able to drill it and then tap it out. Including longer 10mm bolts is definitely a good idea.
#829 |
Is this really a big issue? Now I don't know if I want to start the install until a real fix is in place. Grimspeed can you guys find a fix and ship it out to the people who've already purchased the product? Before we actually install the struts and have issues later? Now that would be real customer service!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#830 | |
Matt Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | zoomzoomers (02-13-2013) |
#831 |
Drives: Attitude
It's a small bolt, I'm willing to bet factory torque value is under 20lb-ft. Always start by hand and don't tighten with a wrench until the bolt can't be hand tightened anymore. Should take more than a few turns by hand, otherwise you're crossthreading it.
| The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | chanomatik (02-13-2013), GrimmSpeed (02-13-2013) |
#832 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | sierra (02-13-2013) |
#833 | |
However, the issue isn't an inadequate amount of thread engagement, the issue appears to be over torquing the bolt. I can't necessarily solve people way over tightening, but I can prevent people potentially crossthreading the bolt and leading to them over torquing the bolt. A longer bolt will give a better chance to prevent this. For now, just be careful to make sure you're not cross threading your factory bolt when you insert it, and do not torque it over 7.5ftlbs. 7.5ftlbs is next to nothing, the average human can exert almost twice that with a screwdriver. If you're using a ratchet, albeit small, it becomes extremely easy to bring this bolt past its yield point, its tiny! If anyone is still having issues post up, or email us (engineering@grimmspeed.com), or give us a call 612-379-0000 and we'll get you taken care of. Chase Engineering *Edited suggested torque to reflect non-zinc plated stock bolts Last edited by GrimmSpeed; 02-13-2013 at 02:17 PM. |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | Foobar (02-13-2013) |
#834 |
Drives: Attitude
What was easiest for me was to have the hood as high up as possible without the lower bracket lifting from one end or laying on the fender with the through hole misaligned. There's about a half cm of space near the top of the damper's stroke that allows you to properly locate the bolt.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | GrimmSpeed (02-13-2013) |
#835 |
#836 |
Awesome! That would be great if you guys can send out the part.
Z
#837 | |
We'll be shipping them out in new kits, and to individuals who need them (broke a bolt from overtightening/crossthreading). We won't be shipping them to everyone who has already purchased the kit, because of how isolated the issue is and that almost all users have had no problems during the installation. Just let us know if you want or need them after we post up saying we've received the new bolts, and we'll send them out. Again, for anyone who missed the previous post: Hand thread the bolt in, and then torque to 7.5ftlbs, and there should be no issue. However, if you're interested in sourcing the bolt before we can get them here, it will be a 6mmx1.00mm 20mm length flange bolt. Chase Engineering Last edited by GrimmSpeed; 02-13-2013 at 02:17 PM. |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | Jayde (02-13-2013), zoomzoomers (02-13-2013) |
#838 | |
I don't even think my 3/8th torque wrench goes to 9ftlbs. Heh, I converted it to inch pounds, and that's 108inlbs. My 1/4in torque wrench has that. ![]() EDIT: Now it's 90inlbs.
| The Following User Says Thank You to Jayde For This Useful Post: | GrimmSpeed (02-13-2013) |
#839 | |
Love you guys! Chase Engineering |
#840 | |
| Replacing Struts and Installing Coil Springs | DarrenDriven | DIY (Do-It-Yourself) Guides | 195 | 04-26-2017 05:15 PM |
| Stock Springs/Struts FRS | jadewbj | Brakes, Suspension, Chassis | 1 | 12-18-2012 11:00 AM |
| WANTED (GA) - Stock FR-S/BRZ struts | xwd | Brakes, Suspension, Chassis | 8 | 11-07-2012 11:43 AM |
| performance/aftermarker struts | karma003 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-07-2012 12:26 PM |
| JDM BRZ Struts different than USDM BRZ Struts? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-30-2012 11:21 AM |
