Old 02-09-2013, 04:07 PM   #15
EBMCS03
Drives: Argento FR-S
They do. Adjust All fluid levels is included in the service
EBMCS03 is offline   Reply With Quote
Old 02-09-2013, 04:23 PM   #16
EBMCS03
here's a pic right form the scion boost card they sent me.
Old 02-09-2013, 04:39 PM   #17
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by rasec29 View Post
At dealer now doing 15k mile service and they told me coolant is really low. I had to buy a gallon for them to add, $44... They couldn't tell me why it was low. I thought they topped off fluids at service. :confused:
Sent via Galaxy Nexus
Let me guess...Longo Toyota/Scion
I have heard baaaaaaaaaaaaad things about their service dept.
Old 02-09-2013, 04:43 PM   #18
EBMCS03
Really? Crap. I was going to use them
Old 02-09-2013, 04:53 PM   #19
Lonewolf
Lonewolf's Avatar
Drives: Moped
This is what I have heard from two other members. Their sales team is good, but the service department is lacking. But what the heck, give them a try, you might have a better experience...sometimes its just one tech or service adviser that is the problem.
Old 02-09-2013, 05:09 PM   #20
Carlsbad
Drives: 2013 Subaru BRZ WRB Limited MT
I just had my 7500 mile service completed on my BRZ (first oil change). I noticed they marked the coolant as low and filled it up. I was surprised. Now it seems like others are encountering the same thing.
Carlsbad is offline   Reply With Quote
Old 02-09-2013, 06:38 PM   #21
Synack
Boosted
Synack's Avatar
Drives: Sideways
The good thing about coolant is that you can never put too much of it (mixed of course) in the reservoir, because it will just flow out if you have too much at any point, whether your motor is super warmed up or freezing cold
Just be sure you're never too LOW on it.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 02-09-2013, 07:25 PM   #22
EBMCS03
Where'd rasec29 go!? I was curious if he used my pic to get his $44 back. And curious which dealer too.
Old 02-09-2013, 07:25 PM   #23
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by Zach View Post
13k miles here - was just on a 700 mile road trip when I noticed a funny smell at a motel when i stopped for the night. Checked it in the AM and the coolant res was BONE DRY. No idea how much was in the rad but i didnt have any CEL or warning lights and had not checked since my last oil change so no idea how long its been dry.
I found a toy dealership close to me and got to spend the entire day there, the end result was a ok pressure test and them filling it back up. Not happy, keeping my eye on it.
Zach
If a pressure test checked out ok and you are still looking coolant, that narrows the possibilities. The pressure test if done properly should rule out leaks due to hoses/connections etc. So that leaves either escaping through the top of the reservoir or escaping through something that requires more pressure than what the pressure test can reproduce. For example a crack in the head gasket or engine block, something that may be affected by heat or stress. Or am I wrong?
I imagine you guys that are loosing coolant have checked the oil or looked under the oil cap for milky residue?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following User Says Thank You to ahausheer For This Useful Post:
Laika (02-16-2013)
Old 02-10-2013, 09:12 AM   #24
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Im at 3k ive added a little coolant here and there cuz its half way down and couple days later its back down. I think it burns it somewere
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-10-2013, 12:55 PM   #25
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I guess I'm gonna start keeping an eye on my coolant!
I haven't noticed being low and I just had my car in for 22.5K service and they didn't say anything or note anything about it being low...
Old 02-13-2013, 12:17 AM   #26
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Somehow missed this thread.
For reference, when the car is warmed up, coolant level should be halfway between full and low. Mines reading at low-slightly below low. I have an appointment tomorrow with my dealership. Keep you guys posted
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
JD213 (02-13-2013)
Old 02-14-2013, 08:27 PM   #27
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Damnit. They topped it off but didn't use Subaru Blue coolant. Hopefully it's an equivalent.
From what I could tell, coolant temp is getting to operating temp faster but I'm trying to rationalize this maybe someone else can chime in.
Ideal gas law tells us that PV=nRT (pressure, volume, n=moles, r=constant, temp)
Volume of the vessel holding the coolant stayed constant but the moles of coolant went up so in a closed state pressure increases.
Now I need a car guy to tell me if the coolant "Vessel" is actually closed. Does the car have an overflow hose or anything? Even something to relieve pressure?
whataboutbob (02-22-2013)
Old 02-15-2013, 12:57 PM   #28
ahausheer
Re-member
The ''vessel'' is usually closed. Once a certain pressure is exceeded the radiator cap will open, thus opening the ''vessel'' but that should only happen during an overheating event.
Once the cap opens you get a pressure drop and, I assume, an immediate cooling effect due to lower pressure.
I wouldn't worry about a slight decrease in the time it takes to get to operating temp. I would make sure that your warranty covers the use of whatever coolant they put in. I would also do everything I could to try and find the source of the coolant leak.
Laika (02-16-2013)
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 09:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 10:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
