Drives: Scion FR-S 2013 Raven
Linear (No progressive) springs
Hi,
I want to know which aftermarket springs are not progressive. Some info about this subject : @Koji_Online linear spring simply gives you a more direct feeling http://www.ft86club.com/forums/showthread.php?t=9028 @Knightshade Progressive springs are softer under light load, and firmer under hard load. http://my.is/forums/f126/f-sport-acc...prings-440927/ Info about aftermarket springs on oem shocks : http://www.ft86club.com/forums/showthread.php?t=22473 I have this list until now : Progressive Springs Rates Eibach Pro-Kit http://performance-suspension.eibach.com/ Eibach Sportline http://performance-suspension.eibach.com/ H&R Sport Spring H&R Super Sport Springs http://www.hrsprings.com/ Tein H-Tech http://www.tein.com/ Tein S-Tech http://www.tein.com/RaceComp Tarmac http://www.racecompengineering.com/ RS*R Super Down SUS http://rs-r.com/lowering-springs/ B&G S2 Sport Springs http://www.b-gsuspension.com Racecomp Tarmac to be confirmed http://www.racecompengineering.com/ "Predominantly" Linear Springs Rates Hotchkis Sport http://www.hotchkis.net/ Racecomp Yellow http://www.racecompengineering.com/ Mach V http://www.machv.com/ Swift sport to be confirmed http://www.swiftsprings.net/products-sport_springs.html Tanabe GF210 http://www.tanabe-usa.com Linear in front and progressive in rear TRD No idea : ST Sport
o= FR-S =o Last edited by Mikepage; 04-24-2014 at 01:41 AM. |
#2 |
I currently work on a list, i will share it with you soon guys.
#3 |
update post 1
#5 |
i don't know, am on it, am doing some research.
I think they don't specify it. |
#6 |
Drives: none
Tag - will be some good info!
#7 |
Drives: Your Car
I know a progressive spring is really horrible to pair with a stock shock. Will a linear spring cause the stock shock to blow quicker?
#8 |
Probably less than a progressive spring, let the company engineers reply to this question in detail.
Maybe the guys from Race Comp can help here, Andrew? Can you tell if your spring are linear? |
#9 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Some of the springs out there are only progressive just to take up some initial drop and be captive, then the rate is linear.
#10 |
Drives: GT86
I'd be extremely surprised if you find any linear aftermarket springs which aren't custom made.
The easy option is coilovers, but that opens up a big can of worms in itself. |
#11 | |
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
To keep that from happening, you wind in some lower-rate coils that will be fully compressed (or "dead") when the car is at normal height. Then when the suspension goes to full droop, the spring will stay snug and won't rattle around. Some coilover suspension systems use a lighter-rate "helper" spring for the same purpose. ![]() As you can see above, our springs have close-wound coils for a bit, then wider-spaced coils for the bulk of the spring travel. The effective rate that the suspension will see under normal use is linear, but the spring is not uniformly wound. Most, if not all, the aftermarket springs I have seen for this car use that design. I guess that's a long way of getting to the point that it's not so simple as saying a spring is "progressive" or "linear." --Dan Mach V |
#12 |
Our springs are linear at normal ride height. There is a progressive section that kind of acts as a helper/tender spring but we wanted them to be as linear as possible.
![]() EDIT: wow, Mach V Dan answered around the same time in a little more detail. Well put. - Andrew |
#13 |
Thanks Dan for the explanation. Where i can put your springs into my list finally :P ?
#14 | |
| Front Spring Diameter | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 12-17-2012 01:06 PM |
| Best Spring Rate please help | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-30-2012 10:02 PM |
| Progressive snapshot | Yruyur | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-25-2012 01:31 AM |
| vibration after spring install? | sajonf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-30-2012 03:30 PM |
| Spring Rate Calculator | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-28-2012 12:31 PM |
