Old 02-08-2013, 02:23 AM   #15
Nardi330
Nardi330's Avatar
Drives: 86
My older version 3.17 doesn't work. Need to send it in to upgrade firmware.
Nardi330 is offline   Reply With Quote
Old 02-08-2013, 02:37 AM   #16
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Dang
86•BRZ is offline   Reply With Quote
Old 02-08-2013, 02:40 AM   #17
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
doesn't look like you can put custom gauges in the scangauge E, not sure I want to dremel out the usb port just yet.. I can pop it on the steering column if i need it..
Old 02-08-2013, 02:54 AM   #18
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by 86•BRZ View Post
Dang
Well it's A$50 + one way postage (return postage included in the $50) so it's not too bad.
Old 02-08-2013, 06:47 AM   #19
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Oh ok i see it now, no X-Gauge Feature for scangauge E.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 02-08-2013, 09:09 AM   #20
Synack
Boosted
Synack's Avatar
Drives: Sideways
here is a pic I found on these forums somewhere
Ill have to look into the scangauge E, hopefully it will fit in the start button models. I pinched this scangage from my other car anyway..
Wow that's perfect! I'm totally getting one and doing that now.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 02-08-2013, 10:15 AM   #21
brillo
Drives: 2013 Firestorm FR-S
I just sent mine in for the firmware update.
brillo is offline   Reply With Quote
Old 02-09-2013, 04:47 PM   #22
pkny
Drives: Firestorm FR-S 6MT
Fast refresh precise Fuel gauge
Found a xgauge code for faster, more accurate and precise fuel level:
Percentage:
TXD 07C02129
RXF 046105290000
RXD 2808
MTH 000100010000
US Gallons:
TXD 07C02129
RXF 046145290000
RXD 2808
MTH 052900640000
Liters:
TXD 07C02129
RXF 046145290000
RXD 2808
MTH 01F4000A0000
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
The Following 3 Users Say Thank You to pkny For This Useful Post:
Bullnettles (08-23-2013), SkullWorks (03-26-2013), Synack (02-09-2013)
Old 02-09-2013, 08:00 PM   #23
TIE Pilot
TIE Pilot's Avatar
This looks like a fairly good guide
https://spreadsheets.google.com/spre...ZTUR1eVE&hl=en
Old 02-09-2013, 08:34 PM   #24
TIE Pilot
TIE Pilot's Avatar
Percentage:
TXD 07C02129
RXF 046105290000
RXD 2808
MTH 000100010000
US Gallons:
TXD 07C02129
RXF 046145290000
RXD 2808
MTH 052900640000
Liters:
TXD 07C02129
RXF 046145290000
RXD 2808
MTH 01F400A0000
Can give this a try ... U never know it might work...
Wheel Pressure showing tenths place
Wheel 1 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 3008
MTH: 4DC627100000
NAM: TP1
Wheel 2 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 3808
MTH: 4DC627100000
NAM: TP2
Wheel 3 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 4008
MTH: 4DC627100000
NAM: TP3
Wheel 4 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 4808
MTH: 4DC627100000
NAM: TP4
Old 02-09-2013, 09:12 PM   #25
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Someone needs to make a sticky database here of all the working 86 BRZ FRS codes that work.
Old 02-09-2013, 09:54 PM   #26
pkny
Wheel 1 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 3008
MTH: 4DC627100000
NAM: TP1
Wheel 2 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 3808
MTH: 4DC627100000
NAM: TP2
Wheel 3 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 4008
MTH: 4DC627100000
NAM: TP3
Wheel 4 Pressure:
TXD: 075122C901
RXF: 046285C90601
RXD: 4808
MTH: 4DC627100000
NAM: TP4
These codes are for Ford/Mazda, right? The 22 in TXD 075122C901 is the mode #. Toyota uses mode 21 (and standard mode 01).
For anyone who wants to get more understanding about the xgauge code, I suggest take a look at the xgauge coding manual.
Note: This manual does not cover the multi-frame coding (e.g. oil temp). I can do a write up on that if someone is interested.
I’ll try to do that when I have time.
Old 02-09-2013, 10:18 PM   #27
TIE Pilot
TIE Pilot's Avatar
Yes it is. I was hoping they were standard codes. I'm going read your attach' to understand thanx.
I'm hunting for a small gauge due to the lack estate in this car. So far i'm liking scangauge. And TPMS will be a dream here.
+1 on the write up.
Old 02-09-2013, 11:25 PM   #28
TIE Pilot
TIE Pilot's Avatar
@pkny how about car settings? Like disable seatbelt beep or other examples i read for toyota.
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
