#71 | |
Turbo FR-S
Yes I am a 1/4 mile guy. And I am getting this car for that. I could honestly care less what some of you guys on here say "oh if you want to go fast in a straight line this is the wrong car" blah blah blah. Guess what it's my car I'm buying it for my purpose so why can't most people just leave it at that? All the cars I have owned have been built for drag strip purposes. That's just how Houston is I guess. We don't have much of a fallowing for lap times. I have two shops that will hook me up on custom fab work at cost. I just pay for supplies and they spot the labor. I just have to sport there name. Inline Racing(ILR) he has done some amazing work with All motor Hondas. South Side Performance(SSP) New shop, but does have some amzaing work with GT-Rs, Evos, STIs and Turbo Hondas. So either way I'm going with this car. It's balanced out great, RWD and lightweight. Most import cars today aren't engineered to go in a straight line anyways, GT-Rs Evos STIs 370Zs etc etc. All were engineered to go around the track with the quickest lap time possible. But guess what AMS, ILR, SSP, Melon Racing, Secret Service, J-Tran Stuidos etc etc all build these cars to go down the drag strip anyways. This car for me is meant to go down the quart mile at the fastest time It can within the power goals I want. Which depending on weight and how the motor is built would be around 400whp or 230whp. I know most on here will prolly use the car for AutoX, Road Racing, and drifting. So HP may not be your guys goal. But it's mine. I hope to be a valued member on this board one day letting you guys know the ups and downs of building this car for that purpose. Anthony |
#72 | |
There were hardly ANY Subaru enthusiasts here up to that point, and they only had the 2.5 N/A motor in the 2.5RS models to work with, so there really weren't any shops here in the states working with the turbo motors until the '02 WRX finally was sold here. I joined the party about a year before the WRX came out, so I got to witness the madness, pretty much like being here a year before this car comes out, LOL! I was thinking about this last night... If and I mean IF the FB25 shortblock is compatible with the FA20 heads, then this might be a good option. You would probably have to keep the FA20 crankshaft and rods (the FB rods are bent) and use the FB25 pistons or some custom pistons, but this MIGHT be a way to increase displacement. A lot of the guys here with 1.8L Imprezas from the '90's build what they call "High Compression Frankenstein" motors by utilizing the shortblock from the 2.2 and combining it with the 1.8 heads. Increases compression AND displacement, making for good power. This also works with the 2.2 heads in conjunction with the 2.5 block, but its slightly more tricky. |
#73 | |
I'm pretty lucky though, the closest station too me sells E85, Diesel AND Biodiesel
#74 | |||||
People say California is pretty bad but really its not. A new car doesn't have to get a SMOG check (tail pipe emissions inspection) for like 6 years, and a used car only every 2 years. So you can run whatever exhaust or intake you want, then swap it for stock when you go for your SMOG test. There are SOME rolling emissions trucks, but they are few and far between and easily avoided. They only reason I run a stock exhaust (at least stock header/cat) at this point is cause I got tired of swapping and it didn't make enough of a difference anyway to matter. Quote:
Honestly, this will be a GOOD car for the 1/4. I've seen early model Imprezas with WRX or STI swaps run 12's without any serious modifications to those motors (maybe a tune and an exhaust, but thats it). With this car, I suspect a 400hp engine build and the low weight can get you into the low 11's, but with the even higher power engine builds out there the sky is the limit |
#75 | |
Drives: N/A
Do boy, do you what suits you
For consistency running a very high strung setup, you need to go with a race blend for E85. But that is no different than race gas, except it's still pretty cheap. Still better than running Methanol.
#76 |
Drives: '06 AM V8V Coupe
To the people who want a stupid 8.0 CR: there is about 15% theoretical efficiency loss going from 12.5 to 8. There's a good reason they don't go that route :P
#77 | ||
Drives: N/A
^This +1. |
#78 | |
Exhausts on Subaru motors are hard for anyone to recognize if they are modded too, because they are hidden under the motor. Uppipes on turbo motors can even pass SMOG tests without being spotted. Noise isn't so much of an issue in California either, but if you drive around with a huge coffee can exhaust you are more likely to get pulled over than if you have a nicely crafted can that matches the look of the car. If you are running around catless with a straightpipe and no resonator, thats a different story, LOL!!! |
#79 | |
Drives: N/A
![]() It's a farcry from here because they can ask you to pop your hood and can ticket you for emissions or potentially take your car for an engine swap. That isn't happening here. |
#80 | |
hashiryu
Drives: Mk4 Supra
#81 | |
Drives: Slowly
Subaru are building a car that will be a good little until in stock form and just about the best modification platform on the planet. The way some of the kids here carry on, you'd think they were promised a $1000 GT3 for Christmas and now feel robbed. |
#82 |
Drives: MR2
#83 | ||
Site Moderator
Drives: ichi 86 Project
#84 |
I forgot how close zzyzx got. He and TWE kind of disappeared after that, as did the place that did that dyno run.
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 08:53 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 09:22 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
| Super Bowl! | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 01-29-2010 04:02 PM |
| Super Lap Battle | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 0 | 12-10-2009 09:46 PM |
