Old 07-19-2012, 10:27 PM   #1
onemorelap
Drives: 2013 lava frs
oil pressure gauge
can anyone tell me how to install an oil pressure gauge on my frs?
onemorelap is offline   Reply With Quote
Old 07-20-2012, 12:27 PM   #2
getbent
Drives: 2013 FR-S Blue MT
The car has both a oil pressure switch and a oil temperature sensor just in front of and below the oil filter.
I believe the one on the left with a single wire going to it is the oil pressure switch.
I would imagine you can probably take that one out and install T or Y junction and then bolt the original switch as well as your aftermarket sensor to the junction.
I plan to pick up a dual gauge (oil temperature and oil pressure) once somebody comes out with a good looking gauge pod.
getbent is offline   Reply With Quote
Old 07-20-2012, 12:35 PM   #3
onemorelap
Think you for the info.
Old 01-23-2013, 04:32 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So when I am ready to install Oil Temp gauge, which one should I Tee up?
Left or right? (I saw @getbent said you should tap to the one on the left, just want to confirm). Also, anyone know what size fitting is needed? Links? Pictures? Thanks!
Edit: @onemorelap where did you end up connecting and using what? (Longshot since he has not logged in since August.. but who knows!)
@PrimeMotoring @Rev Works may be able to help too.
Old 01-23-2013, 04:36 AM   #5
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Here's oil temp gauge that reads through the OBD2 connector. No need to wire in another sensor as uses the OEM one. Expensive but looks great.
Mounts in drivers side aircon vent but still allows the air flow
http://pivotjp.com/product/dual-gauge/img/DXW-e.pdf
nzer is offline   Reply With Quote
Old 01-23-2013, 10:44 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
I like the look of that. Too bad it isn't Oil pressure and Oil temp, then i'd buy it in a heartbeat.
1974 TA22 Celica
2013 86 GT
Old 01-23-2013, 10:55 PM   #7
xwd
I just want the vent pod.
The one on the left is the idiot light oil pressure switch. It is 1/8 BSPT or PT. You usually do not want to screw a tee directly into the block, a lot of guys will use an extension hose.
The Following 3 Users Say Thank You to xwd For This Useful Post:
Sportsguy83 (01-23-2013), Supermassive (01-24-2013), van_fc3s (08-18-2014)
Old 01-26-2013, 06:40 AM   #8
Sportsguy83
Drives: Limited BRZ
Lightbulb
Thanks to @Supermassive for the pics!
I believe this is a GREAT location for the Oil Temp gauge sensor.
Thoughts anyone? @PrimeMotoring @Rev Works @Dave-ROR @P&L Motorsports @Pure Automotive
The Following User Says Thank You to Sportsguy83 For This Useful Post:
hmong337 (02-10-2015)
Old 01-26-2013, 09:31 AM   #9
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
On the FBM kit I used a 3 way junction at the factory oil sensor on the front of the motor. I think the reason they used that for the turbo feed is because the coolant lines for the turbo run under the intake pipe where that port is. I would either use that port or run off a sandwich plate in combination with an oil cooler.
Pure Automotive is offline   Reply With Quote
Old 01-26-2013, 10:38 AM   #10
Sportsguy83
Drives: Limited BRZ
The 3 way junction is 1/8" NPT? Can you take a pic? :-D thanks!
Sent from my HTC One X using Tapatalk 2
Old 01-26-2013, 01:20 PM   #11
xwd
Is that a standard Subaru oil gallery plug in the pic, if so it would be a good place to tap for oil pressure. It is what most Subaru guys do on th EJ engines since there is an extra unused plug. You just buy the oil pressures switch plug which has a 1/8 PT hole in it to replace the solid plug.
Again I would not use a Tee screwed into the front ports, those things have a tendency to crack under repeated stress without much support.
You can even buy this one which is threaded for NPT and not BSPT. Depends on the gauges and send unit you are using.
http://www.fastwrx.com/oilgalleryplug.html
Or just get the whole relocation kit since the pressure senders are usually pretty large.
http://www.fastwrx.com/reoilprsekit.html
This Tee I would see working but it's expensive
http://www.nissport.com/catalog/prod...e=Applications
The Following 4 Users Say Thank You to xwd For This Useful Post:
frsvr4 (11-25-2014), jcw99 (01-06-2015), Traktor (06-08-2017), whataboutbob (04-25-2017)
Old 01-26-2013, 02:25 PM   #12
Sportsguy83
Drives: Limited BRZ
Is Tee I would see working but it's expensive
Thank you so much for the suggestions. I believe it is the Standard Subie oil gallery plug. I got this AEM Oil Temp gauge. Still need to wait for gauge cluster, but will update when installed.
Old 01-27-2013, 03:06 PM   #13
Xdragonxb0i
Drives: ex500r
There is DIY on to set up a guage like this. its Pretty straightforward and easy to do. just need a 60-62mm guage and some double sided tape
Xdragonxb0i is offline   Reply With Quote
Old 01-27-2013, 08:46 PM   #14
nzer
nzer's Avatar
And I assume an oil temp sensor or is there another one that will use the OBD2 connector or the OEM one?
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 02:01 AM
Self-diagnostic busses? Specifically oil pressure? Nezz Electronics | Audio | NAV | Infotainment 6 08-13-2012 09:34 AM
phantom tire pressure warning eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2012 10:04 AM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
