Old 01-22-2013, 02:35 AM   #1037
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I check this thread nearly every day, so I figure I would just post and subscribe to it. Keep up the great work, can't wait to see this finished
Thanks,
Rick
RallySport Direct is offline
The Following 2 Users Say Thank You to RallySport Direct For This Useful Post:
mines13 (01-22-2013), thebear21 (01-22-2013)
Old 01-22-2013, 02:44 AM   #1038
Visconti
Drives: 05 STi
Originally Posted by subatoy View Post
don't be greedy! you are getting ripped by ecutek when you purchase it by yourself. they are discounting the cost not the retail price.
Wrong
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
cruzinbill (01-22-2013)
Old 01-22-2013, 02:49 AM   #1039
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
The price of the intercooler isn't really the problem to me, it's just I personally don't want to add an electric water pump and hoses. There is nothing wrong with that just personal preference. I would rather add something like the robi spec cooling system or Perrin oil cooler and aftermarket radiator. Keeping underhood temps down would still help I think. Any input from Innovate on this?
JoeBoxer is offline
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
Jeff86 (01-22-2013), swift996 (01-22-2013)
Old 01-22-2013, 04:20 AM   #1040
cruzinbill
Drives: Argento 6spd FR-S
I agree some people just dont wanna spend the whole amount right now if they dont need to. Some just wanna a lil boost in power/remove the trq dip...... and maybe have a sweet S/C under the hood.
For those tracking and all of that nonsense ya I couldnt imagine not getting the stage 2 kit.
cruzinbill is offline
Old 01-22-2013, 04:21 AM   #1041
ft_sjo
Drives: GT86
Originally Posted by Innovate Motorsports View Post
-What is the relationship between the Cusco and Innovate Motorsports Kits?
Innovate Motorsports is the exclusive North American distributor and customer service center for this supercharger package. We have been intimately involved in the design and development of this kit since the beginning (and have several rapid prototypes, drawings, components and our own development car.). If you're in North America, we're here to support your use of our products full time. Cusco, a very respectable company, will be representing this product in Japan only if they decide to pursue distribution.
So is it fair to say then that is is really a Cusco product which Innovate have had some design input into? Or would you say it was a truly joint effort?
I only because your company is not well known for forced induction conversions, is this the first mass produced one?
So if Cusco might be supporting Japan, and you're only doing North America, what about the rest of the world?
ft_sjo is offline
Old 01-22-2013, 04:22 AM   #1042
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Sure, keeping fluids cool is good but reducing temperature of the air isn't only good for reliability but it also increases power/efficiency, so it's kind of a double bonus.
I think I want what's not currently illustrated on the price chart which is the stage 1 kit but with the laminova aftercooler system. So I'm looking forward to that package when it becomes available (which page 1 says it will at some point).
SCCA T4 - FRS
rice_classic is offline
The Following User Says Thank You to rice_classic For This Useful Post:
JoeBoxer (01-22-2013)
Old 01-22-2013, 04:30 AM   #1043
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Sprintex the manufacturer and Bullet the original designer.
150 Units are heading to the USA from the first batch, the other 100 are going to the rest of the world: http://www.carsales.com.au/news/spor...rcharged-34393
JP is offline
The Following User Says Thank You to JP For This Useful Post:
ft_sjo (01-22-2013)
Old 01-22-2013, 04:34 AM   #1044
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Those items are are well and good, but the charge air temp is still going to be pretty high with any good amount of boost.
The IC version should allow for a fair bit more boost, thus unlocking more of the kits potential.
I had a whipple twin screw on my mk1 MR2 SC (custom install), and I was running around 15 psi. I data logged the intake temps, and they were usually around 100-110 deg F while flogging it around on a 75-80 degree day.
I never logged the temps upstream of the IC, but just feeling the pipe, it was literally so hot you couldn't touch it for longer that a split second!!! The pipe after the IC, was as those mentioned (much cooler). My IC was also air-to-water, which makes sense for the MR2. Please not that the twin screw SC was mounted to the side of the block, with inlet and outlet pipes. Which allowed the use of a standard (non-integrated) IC setup.
Once the pump was primed, I never had any trouble with the pump/lines/IC setup. I also used the same pump/heat exchanger from the mk1 MR2 on my Rotrex SC MR2 Spyder with a different IC core. Always had good intake temps even with 17psi max boost.
uspspro is offline
The Following User Says Thank You to uspspro For This Useful Post:
Jeff86 (01-22-2013)
Old 01-22-2013, 09:57 AM   #1045
swift996
swift996's Avatar
Also, correct me if I'm wrong but doesn't the a chargecooler/intercooler provide denser air? It's not just about running cooler engine temps, it's a more efficient/more powerful combination.
It probably comes down to your goals. For me an extra $1200 is worth it, but for some people I'm sure it isn't.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 01-22-2013, 10:00 AM   #1046
swift996
swift996's Avatar
I hear you too. The reason I like this system compared to a turbo is that it reduces the amount of additional components and systems/modifications to systems.
It looks to me that it will just be an external electric water pump. At least the design is simple and if the pump failed, it would be easy to spot.
swift996 is offline
Old 01-22-2013, 10:20 AM   #1047
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Definitely. Adding the cooler is really about adding power more than anything. All I've been saying is that I've had an uncooled blower that was less efficient than this one and it made plenty of reliable power. Most of us aren't looking to run 15-17psi on this car. Just add the power we feel the car should have had from the factory and maintain the overall balance. I believe the uncooled option will deliver this.
Jeff86 is offline
Old 01-22-2013, 10:30 AM   #1048
JoeBoxer
JoeBoxer's Avatar
Exactly, i would run no more than 7psi non intercooled and figured the oil cooler and radiator would just add a little piece of mind if nothing else.
Hopefully Innovate will show us some of the IAT temps they have logged and we can monitor our own with Ecutek. Just thought of wrapping the intake tube with a heat reflective shield and you could check the IAT's before and after to see if it did anything.
JoeBoxer is offline
Old 01-22-2013, 10:44 AM   #1049
Visconti
Drives: 05 STi
Vroom!
Visconti is offline
Old 01-22-2013, 10:54 AM   #1050
djliquidsteele
Drives: Scion FR-S
Vroom!
Uh oh. Is there a video of said Vroom?
djliquidsteele is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 03:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 10:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 06:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 07:10 AM
