Old 01-16-2013, 01:29 AM   #211
Xdragonxb0i
Drives: ex500r
Originally Posted by Dispect View Post
I second this. Happened to me
maybe the Heat is not able to escape which causes the crack?? idk
Xdragonxb0i is offline   Reply With Quote
Old 01-16-2013, 10:00 AM   #212
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Cody View Post
I tried to take the brake light apart and paint the reflector. Mission was a failure...
After attempting it and failing i have come to the conclusion that the lens portion of the brake light was sunk into the black portion. I do not believe there is any adhesive on the light at all.
It is plastic welded and not glued like the headlight.
This has been done by many people on the board. search DCW Doggy's build in the journals for example.
you need to cut open the tail lights
Old 01-17-2013, 03:47 AM   #213
Cody
Cody's Avatar
Drives: White Fr-S
Okay i will search that!!
Cody is offline   Reply With Quote
Old 01-17-2013, 05:08 PM   #214
BlueLeader
Drives: Ultramarine Blue Scion FRS
I wanna do this but a friend recommended that i spray the red inside the lens to prevent cracking. Imo thats a pain in the ass job just for red clears. I would take the time for wet sanding. Anybody know what grit to sand with and how many coats of clear to put. Also redding out the turn signals is not illegal in cali right?
BlueLeader is offline   Reply With Quote
Old 01-18-2013, 12:15 AM   #215
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
That makes no sense. Why would spraying the inside prevent cracking!?! It's the same material inside and outside. If anything, you would cause more damage taking the lights apart to paint the inside!
Red or amber turn signals are legal in all 50 states. You won't get a ticket as long as they look stock. Take note, ANY modification to your lighting system is technically illegal as far as DOT goes, but they shouldn't hassle you as long as you can still clearly see the lights.
The Following User Says Thank You to DarrenDriven For This Useful Post:
BlueLeader (01-19-2013)
Old 01-19-2013, 03:04 PM   #216
mottor
mottor's Avatar
I'm getting my tails replaced under warranty (for condensation) before I tint them red. The service manager said that Toyota recommends new gaskets on the tails for every install. What do you guys think about this? Is it necessary? I really don't want to tint them red and then get condensation buildup again and have to strip them to get them replaced.
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub
mottor is offline   Reply With Quote
Old 02-06-2013, 07:31 PM   #217
DF-Aero
Drives: GT86
looks like they aqre not shipping this paint anywere:/ Anyone kind enough to buy and ship private?
DF-Aero is offline   Reply With Quote
Old 02-22-2013, 03:09 PM   #218
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Now that you guys have had this done for a while, have you noticed any issues with scratching, peeling or other types of wear on the tint? Do you go through drive-through car washes or only wash by hand?
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
chanomatik (02-22-2013)
Old 02-23-2013, 02:56 PM   #219
jesperswe
Drives: GT86
Are there any "legal" issues with blackening the rear lights?
jesperswe is offline   Reply With Quote
Old 02-24-2013, 04:02 PM   #220
timmyah
timmyah's Avatar
Drives: 2013 Scion FR-S - Whiteout
Painted my tails yesterday. Duplicolor metal cast, spraymax 2k.
timmyah is offline   Reply With Quote
Old 02-25-2013, 08:58 PM   #221
MosesFRS
MosesFRS's Avatar
Drives: Whiteout
Mid paint pic
MosesFRS is offline   Reply With Quote
Old 02-25-2013, 09:02 PM   #222
MosesFRS
MosesFRS's Avatar
Drives: Whiteout
Couple more
Old 02-25-2013, 09:03 PM   #223
MosesFRS
MosesFRS's Avatar
Drives: Whiteout
Brake lights
Old 02-25-2013, 11:01 PM   #224
grostoine
Drives: Subaru BRZ
Here is mine, 3 layers VHT Red nightshade + 4 layers of duplicolor acrylic clear. Need a polish to be perfect!
grostoine is offline   Reply With Quote
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 10:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
