Old 01-14-2013, 12:08 PM   #1
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
DRL
Is there a way to disable this without taking it back to the dealer? Im curious because I'm back and forth between switching out to an LED, or not having the DRL at all.
TheGuyWithTheFireStorm is offline   Reply With Quote
Old 01-14-2013, 12:11 PM   #2
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Why not just run the standard bulbs until you get the LEDs? Switching them out should only take a couple minutes when you get them.
Trashed675 is offline   Reply With Quote
Old 01-14-2013, 12:15 PM   #3
I know the bulbs dont cost much, but I don't have the money to spend on a (high quality) HID kit. I know I can turn to DDM Tuning and get a set for around $70. No DRLs would just be a current fix until I manage to find color matched DRLs + HIDs. Are you still running the OEM DRLs?
Old 01-14-2013, 12:28 PM   #4
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Unplug the DRL resistor. It disables them without killing your high beams. Look in the DIY section.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
TheGuyWithTheFireStorm (01-14-2013)
Old 01-14-2013, 02:49 PM   #5
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
The dealer disabled mine for free with Techstream, why not just go that route?
Cade01 is offline   Reply With Quote
Old 01-14-2013, 03:48 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Why don't you like DRL's? You legally have to have them here in Canada and I appreciate that.
Old 01-14-2013, 05:32 PM   #7
Whats Techstream!?
The Following User Says Thank You to TheGuyWithTheFireStorm For This Useful Post:
PNW FRS (01-14-2013)
Old 01-14-2013, 05:50 PM   #8
PNW FRS
PNW FRS's Avatar
I too believe that DRLs are a benefit. My experience has been that it helps with visibility and that in turn helps with accident avoidance. If you're driving a huge SUV... maybe not so much.. but with a low, small car like the FRS.. it could mean the diff between hit or near miss.
PNW FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to PNW FRS For This Useful Post:
SkAsphalt (01-15-2013), TheGuyWithTheFireStorm (01-14-2013)
Old 01-14-2013, 08:17 PM   #9
Hardrock4445
Hardrock4445's Avatar
Replace drl relay with horn relay equivalent. Done.
Hardrock4445 is offline   Reply With Quote
Old 01-14-2013, 09:35 PM   #10
roddy
roddy's Avatar
Drives: '13 Ultramarine
Here...
http://www.ft86club.com/forums/showthread.php?t=7435
Old 01-14-2013, 10:09 PM   #11
Cade01
Cade01's Avatar
Originally Posted by TheGuyWithTheFireStorm View Post
Whats Techstream!?
It is the software Toyota uses to scan and change setting on your car. They plug in a cable, push a few buttons, and bam, no DRLs.
The Following User Says Thank You to Cade01 For This Useful Post:
Old 01-14-2013, 10:30 PM   #12
Originally Posted by roddy View Post
Thanks!
Old 01-14-2013, 11:01 PM   #13
mush
mush's Avatar
for a car this small, i would leave the DRL on
