Old 01-13-2013, 01:37 PM   #127
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by skatery1989 View Post
Ya should have threw that in there.
So, it is somewhat possible your car could read in the 220+ range on a Dynojet. But either way, glad you are liking the kit I can't wait to get one!
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 01-13-2013, 01:49 PM   #128
2forme
Not necessarily. He said it was corrected and that another stock 86 dynoed at 160 on that dyno, corrected. That sounds like it's tuned pretty well to match a dynojet.
The Following User Says Thank You to 2forme For This Useful Post:
Opposed (01-13-2013)
Old 01-13-2013, 01:51 PM   #129
crank
crank's Avatar
Drives: WRB 2013 Subaru BRZ Limited
Best result/ build thread glad to see more pictures and videos! Glad to hear a satisfied customer and see a working kit! Btw is that the intake pipe that Perrin designed?
Full Perrin Intake/ Perrin Cat-Back /PST Carbon Fiber Drive Shaft/ 5% Tint All around
Build Link:http://www.ft86club.com/forums/showthread.php?t=44038
crank is offline   Reply With Quote
Old 01-13-2013, 01:56 PM   #130
Pete
Pete's Avatar
Drives: 22 BRZ
That torque curve looks like a tiny turbo, it dies off at 6200rpm. What would cause that with a belt driven compressor that has no wastegate?
Pete is offline   Reply With Quote
Old 01-13-2013, 01:56 PM   #131
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@skatery1989 thanks for posting all the info!
Old 01-13-2013, 01:57 PM   #132
Sportsguy83
Drives: Limited BRZ
He is a mile high plus elevation in Colorado. Most likely the reason for the lower numbers.
That is what corrections are for....
Old 01-13-2013, 02:07 PM   #133
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
The way torque is falling off towards the topend while boost is still ramping up... Is that timing being pulled or some other breathing issue? I guess we'll get the answer with the e85 tune. Thanks for the info!
industrial is offline   Reply With Quote
Old 01-13-2013, 02:12 PM   #134
Opposed
He said that guy who pulled 160 was on a different dyno. Either way, not worth going back and forth about dyno's, we all know they are different. But I did miss the "corrected" comment done on the Dyno Dynamics. So I guess its still the elevation thing? Looks like he is only seeing 6 psi at redline too?
The Following User Says Thank You to Opposed For This Useful Post:
2forme (01-13-2013)
Old 01-13-2013, 02:17 PM   #135
Sportsguy83
Drives: Limited BRZ
That was with 15% correction.
Maybe you are talking about something else and I apologize if you are but see skatery's comment above.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 01-13-2013, 02:20 PM   #136
skatery1989
Drives: BRZ Limited
When I change to E85 I have a smaller pulley that should add another 3psi.
skatery1989 is offline   Reply With Quote
Old 01-13-2013, 02:27 PM   #137
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I base lined at165
Coheed is offline   Reply With Quote
Old 01-13-2013, 02:34 PM   #138
2forme
The VE of the motor falls off after 6750, so its just a case of the engine losing breathing ability after that.
I posted another chart overlaying Skatery's dyno with my E85 run on your charts thread, you'll notice they both start losing breath at the same time.
Pete (01-13-2013)
Old 01-13-2013, 02:37 PM   #139
Sportsguy83
Drives: Limited BRZ
VE?
Old 01-13-2013, 02:39 PM   #140
2forme
VE?
Volumetric Efficiency. Basically the engines ability to breathe efficiently.
Sportsguy83 (01-13-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-16-2013 12:48 AM
Circuit Motorsports - SEMA 2012 Interview - Vortech Supercharger! Circuit Motorsports Forced Induction 6 11-06-2012 02:30 PM
