| CANADA Canada |
Drives: WRB BRZ
which is better to use Shell 91 or PetroCanada 94?
I'm debating if i should use Shell 91 with no ethanol or PetroCanada 94 with 10% ethanol? Toronto can be quit cold in the winter and quit hot in the summer, and I don't want to switch back and forth with different octane.
#2 |
Drives: Whiteout FR S 6MT
My car mech buddy recommended Chevron 94.
and he said the 91 from Shell will kill your engine faster Please correct me if I am wrong. Also I am here to see what fellow members suggest |
#3 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
While I'm not in your climate zone I've used 91 exclusively and have had absolutely no problems in 5,000 miles.
#4 |
Drives: hybrid + racecar + FR-S
I"ve been exclusively using 94. As soon as I went to one tank of Esso 91, it was a reduction in pick-up. I have yet to try an E0 91 shell. I'm curious too.
Team Lexus IS300 race car '14 Lexus RX450h Sport Design daily driver '14 FR-S fri/sat/sun car: SARD LSR wing, Downforce front lip, Mann Engineering dampers, TRDsways, Milltek xhaust, AEM Intake, RAYS 57xtreme, OnPoint Dyno ECUTek tuned: +30rwhp! |
#5 |
Drives: FRS
I have been using mostly shell 91 but i did use 1 tank of petro 94 a while back. really didnt notice a difference at the time but ill have to try it again.
shell is just closer to home for me. |
#6 |
Drives: '13 Ultramarine
I bounce back and forth between the Shell and Petro Canada. It doesn't seem to make much difference in the cold weather. When it is warm (or Hot) out, the car seems to like the 94 a little better, but I get crickets. No crickets with the Shell 91 (0% ethanol) warm or cold.
| The Following User Says Thank You to roddy For This Useful Post: | Demandred7 (01-17-2013) |
#8 |
Drives: BRZ MT SWP
are there any differences between shell V-power 91 and shell 91?
i used those mixed pumps(you can select 87 89 91) to add 91, and then i saw a single pump supplies only 91(with V-power sticker) |
#9 |
Sarcastic SOB
V Power in Canada is ethanol free.
For performance, Petro 94 is best but you get crickets. I have also used V Power 91 and don't detect any major difference. No Chevron 94 ethanol free in Ontario. It's all good so long as you're 91 octane or above. Winter time isn't really when you want to max out power, so mileage should probably determine your best choice.
#11 |
Try 91 V-power Shell (if Quebec also has no ethanol) for slightly better gas milage, or Petro Canada 94 for slightly improved running/power. You may not notice a difference this time of year, but in the summer you likely would. JMO.
#12 |
Drives: Scion FRS Ht Lva(AT)
All the Shell Canada 91 is V-Power.
The 3 product pumps are blender pumps that draw from a V-power(91) and a regular(87) underground tank mixing to generate 89. The V-power only pump will be connected to the V-power(91) tank only. |
| The Following User Says Thank You to smbrm For This Useful Post: | 8987846 (01-13-2013) |
#13 |
Drives: BRZ MT SWP
i put petro 91 once and it had way more mileage than V power 91. will try another tank of v power 91 tmr to confirm it.
#14 |
Drives: WRB BRZ
| Heads up, you can get 20 Cents off gas from Shell if you have a Ralphs Reward card | jflogerzi | Southern California | 4 | 12-27-2012 03:47 AM |
| Petrocanada 94 or shell 91? | QC-FRS | CANADA | 24 | 06-18-2012 05:55 PM |
