#337 |
Drives: Honda Fit
#338 | |
#339 |
Drives: rsx was stolen :(
How to fix rear deck sound
This is how i fixed my issue. I discovered that the noise is coming from the passenger side rear airbag. To get at the rear passenger side airbag, refer to this tutorial http://www.ft86club.com/forums/showthread.php?t=10002
I will skip some steps here and get to the point. Once you remove the outer plastic trim, you will see the following (See below) The red outline is where the PRIMARY sound is coming from. Gently tapping the airbag device will reproduce the sound. The clamp (outlined in red) is not fully attached to the chassis and makes a clinking noise. I simply took a 3inch x 3inch piece of t-shirt and wrapped it around the clamp outlined in red to dampen the sound. In addition, I sprayed from WD40 over the metal clamp outlined in blue. After i did all that, the noise went away. |
| The Following 3 Users Say Thank You to sieeegel For This Useful Post: |
#340 | |
So you put the piece of shirt behind the clamp against the frame of the body or against the part that is next to the plastic cover?
#341 | |
Drives: 2013 BRZ Premium MT
#343 |
Any update?
#344 |
Drives: Subaru BRZ Limited
Mine's going to the dealer on Wednesday for this and a few other little things. Will report back (there is no way they can give me a "no trouble found" either, because it's not even intermitten...it's all the time).
#345 |
#346 |
Señor Member
Drives: 2013 SSM DZE BRZ
I had the second part of the TSB performed (I already had the first part of it done earlier) and the noise remains. Additionally, there is now some rattling from the rear shelf that wasn't there before. I'll be in contact with SoA to resolve this, but for now, I'm a bit disappointed.
#347 |
Drives: WRB BRZ
I did the first part of the TSB, still have the popping noise. I notice the sound isn't there if the seats are folded down. Anyone else have the same issue?
#348 |
Got my car back yesterday and the popping is gone!! Finally, thank god silence!
All they said they did was add extra insulation to the rear parcel shelf. I could tell that they must have sprayed silicone in the rear holes as well though. Only annoying thing now is that it's so quiet I'm noticing all the other tiny rattles in other areas. Oh well, a good trade off
#349 |
I finally broke down and took it in to the dealer. End result - they couldn't reproduce it. I drove with them and pointed it out, but unfortunately the roads are smooth near the dealership so it wasn't nearly as bad as it sometimes can be. They basically said "there's nothing we can do if we can't pinpoint the source". No shit, that's what I need THEM to do. Nice way to spend a day off.
![]() Might just keep trying other dealerships in the hopes that one decides to put some effort into it. |
#350 | |
Drives: 2013 Raven Black FRS
I sprayed some WD40 in mine, last weekend. Haven't driven it since, I'll let you know the results I get tomorrow. I did not remove anything, just sprayed WD40 is all.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
| Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) — General Topics | 59 | 12-01-2013 12:28 AM |
| NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! | Speed Element | Wheels and Tires | 19 | 07-19-2012 02:27 PM |
| Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) | Hachiroku | BRZ First-Gen (2012+) — General Topics | 67 | 11-09-2011 05:58 PM |
| May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
