#15 |
Drives: 2013 WRB Subaru BRZ 6MT
I had this same problem this morning. The window did not auto-up and only would go down. The reset procedure WORKED and the window goes and up down now correctly with the auto up feature.
NOTE: I had a 350Z before that had the same frame-less window that goes and up and down. This is a known large issue on the 350Z as well. I had to replace the window motor once to remedy the issue. |
#16 |
DEEEERP
exact same thing happened to me this morning, sigh...
#17 |
Drives: FR-S MT
It's not a "issue". It is a safety feature. Toyota designed the window to default to down-only configuration if it detected something blocking the path. The reason is that if someone's extremity is caught in the window, they don't want anyone to mistakenly close the window further.
#18 | |
Drives: '83 Rabbit GTi, '99 G20t
#19 |
Drives: FR-S MT
No, you have to reset it yourself. Maybe it resets after you turn the ignition off and on again?
| cold weather equals non operational windows | Shit Luck | Issues | Warranty | Recalls / TSB | 45 | 11-02-2016 12:32 AM |
| cold weather & remote starter | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 11-10-2012 07:03 AM |
| Cold-weather morning shifts | NetMagi | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 11-08-2012 12:05 PM |
| Cold / Wet weather brake issue? | Ingen | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-29-2012 12:42 PM |
| Pretty sure car hates the cold weather | HuntingtonFRS | Issues | Warranty | Recalls / TSB | 28 | 10-21-2012 05:52 PM |
