go_a_way1
Old 12-29-2012, 08:21 PM   #757
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Forgot to ask:
Is there a set difference in width between the front and rear rims in a staggered setup, or does it vary per design?
white_knight is offline   Reply With Quote
Old 12-30-2012, 04:14 PM   #758
Mitch
form follows function
Drives: RIP '13 BRZ
Originally Posted by white_knight View Post
Forgot to ask:
Well, no. You can go a half inch wider, you can go four inches wider. The whole and only mechanical reason to do a staggered setup is that:
1. You don't have enough rear traction to put down power.
2. The maximum wheel width you can fit all around in a square setup isn't sufficient to put down power.
and 3. You can fit wider wheels in the rear than will clear in the front.
If you aren't having traction issues directly related to having too much power for the rear tires to hold, then the amount by which you're going wider in the rear is completely arbitrary. Pick whatever looks good, but just know that the wider you go the more it will upset the handling.
Mitch is offline   Reply With Quote
The Following User Says Thank You to Mitch For This Useful Post:
jeepmor (01-22-2021)
Old 12-30-2012, 08:52 PM   #759
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Hey all,
Picked up a set of 17x9 +35 rpf1s. Going to run a 245/40/17 rs3 in the summer and a 245/35 toyo R1r in spring and late fall. Currently stock springs. Running -2 degrees of camber up front. Going to rce yellow springs and plan on running -2degrees or more up front. You guys see any issues with rubbing under load?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
white_knight (01-10-2013)
Old 12-30-2012, 09:12 PM   #760
whataboutbob
AutoX-10/10ths every run
Originally Posted by feldy View Post
Hey all,
I'd be interested in input on this as well. I've got the same wheels on order and will be running 245/40R71 Dunlop Z2s. I've put Whiteline camber bolts and caster bushings on, and will be adding COMCs and the adjustable rear camber bushings.
Build thread:Here
Old 12-30-2012, 09:35 PM   #761
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Hey all,
It's doable. Hard to say if the front would rub the fender. Depends on your camber, spring rate and shock compression. Not a whole lot of room on the outside at fender edge. I wouldn't sweat it. Take some measurements though before purchase.
Edit look up at the white FRS with Rota Grid 9" +30. Just a 5mm difference. Tires are another story but irrelevant.
ill86 is offline   Reply With Quote
Old 12-30-2012, 09:37 PM   #762
whataboutbob
I'll post how mine works out. Probably won't have any input until sometime in Feb if I can get the SS Z2s at that point. The wheels are supposed to arrive mid Jan.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
ill86 (12-30-2012)
Old 12-31-2012, 01:29 PM   #763
luna91
Drives: BRZ Subaru
Hey guys! first post haha. Looking to purchase some wheels since this 215's are skinny lol I was looking at 18x9.5 45+, however im not sure if that side will fit the front? i read the rears are good. Thanks.
luna91 is offline   Reply With Quote
Old 12-31-2012, 02:11 PM   #764
ill86
ill86's Avatar
Drives: iG FR-S
How wide of a tire do you want to mount?
Staggered or square fitment?
Why 9.5" up front?
Old 12-31-2012, 04:40 PM   #765
luna91
Drives: BRZ Subaru
Well i had a extra set of wheels, im not trying to buy others since i have this one. I was thinking 245 in the front and 255 rear.
Old 12-31-2012, 04:54 PM   #766
ill86
ill86's Avatar
Drives: iG FR-S
So a 9.5" square setup with mismatched tires?
Going be fairly aggressive up front. A suggestion: buy a pair of 8.5" for up front.
Old 12-31-2012, 05:04 PM   #767
luna91
Drives: BRZ Subaru
You are correct, you think 255's rear/front will work?
Old 12-31-2012, 05:28 PM   #768
ill86
ill86's Avatar
Drives: iG FR-S
A 9.5 +45 w/ 255mm tire is going to be awfully close to the suspension components. If you already have the wheel test fit it and measure clearance for tires.
Old 12-31-2012, 05:31 PM   #769
ill86
ill86's Avatar
Drives: iG FR-S
(My internet connection is screwing up)
I don't think it is going to work unless you get a coilover setup that is smaller in diameter to OEM. ( to provide clearance )
Old 12-31-2012, 05:40 PM   #770
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I'm gonna see if I can run a 235/40 AD08(runs wide) on my rear Work's 18x9.5 +27. Front 225/40 18x9.5 +29
Aggressive pull coming soon
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
ill86 (01-03-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
