go_a_way1
Old 12-29-2012, 11:26 AM   #743
Mitch
form follows function
Drives: RIP '13 BRZ
I've got 255/40/17s back there on a 17x8+45 lowered without issue.
Just curious, why do you want to stagger your tires?
Mitch is offline   Reply With Quote
Old 12-29-2012, 11:30 AM   #744
ModBargains.com
ModBargains.com's Avatar
255 is the widest I've seen without modifying fenders
ModBargains.com is offline   Reply With Quote
Old 12-29-2012, 12:06 PM   #745
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
I have similar wheel setup 18x9+35... I have 235/40/18 but could easily fit 265/30/18 on stock fenders tons of room, next set of wheels I will get I will probably do +25 for the rear instead of 35 or do a 35 offset with x10 width
JesseE is offline   Reply With Quote
Old 12-29-2012, 12:08 PM   #746
fatoni
it might depend on the diameter of your springs so figure that out first. also, i would advise against the stagger as it will provide zero benefit (at least nothing i can think of) but will give a host of disadvantages.
also, if youre looking for grip, i would suggest you try to use tire compound over size to achieve your goals. what are your goals?
The Following User Says Thank You to fatoni For This Useful Post:
white_knight (12-30-2012)
Old 12-29-2012, 03:24 PM   #747
stanm
stanm's Avatar
Drives: 2013 Asphalt FR-S 6MT
http://www.ft86club.com/forums/showthread.php?t=25171
Post #9, that one has 265/35/18
stanm is offline   Reply With Quote
Old 12-29-2012, 04:35 PM   #748
Silp3
Silp3's Avatar
Tires
Hi all,
I have an opportunity to purchase snow tires very cheaply. I have searched google, other forums, as well as here on FT86.
The tire in questions are brand new General Altimax with steel wheels off of an Outback. They are being offered for 100$ and I am sweating trying to make sure they will fit.
My only concern is the height of the tires. They are 215/60/16. The 60 scares me especially because I am unaware of the offset. The Miata tire calculator suggests they will be 1.3 inches taller, and the radius will increase by .08 inches.
Does anyone think I may rub with a tire this tall? I know the handling and the speedometer will suffer, however, for my use, the added tire height will serve me well in mud season as well as snow season up in Maine.
Last note: I posted this in the General Forum Because more eyes will see and I can get a quicker response. This offer ends at 6pm. But here is a picture to alleviate the wrong forum posting
Silp3 is offline   Reply With Quote
Old 12-29-2012, 04:41 PM   #749
Silp3
Silp3's Avatar
Quick tire question
Hi all,
Here is a picture for the spank bank
Old 12-29-2012, 04:48 PM   #750
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
If you are stock height they should fit despite the extra sidewall height. Keep in mind that 1.3" is split by the rim. Also if the wheels have proper offset for a Leggy it should be just fine on the FR-S.
Worse case if they don't fit they are still sell-able.
Old 12-29-2012, 04:49 PM   #751
mashal
DADA
mashal's Avatar
Drives: 2013
Word
mashal is offline   Reply With Quote
Old 12-29-2012, 04:50 PM   #752
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Should fit fine. I have the same tires (different size), they rock in the snow.
Flat Black VW is offline   Reply With Quote
Old 12-29-2012, 05:22 PM   #753
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You will possibly rub when the wheel is turned. As for speed, at highway speeds you'll be going about 4mph faster than your speedo reads.
Will the person let you bolt them up before buying?
Old 12-29-2012, 05:25 PM   #754
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Thanks, guys.
Im going for the staggered option purely for looks. Originally, i wanted the rims to be staggered, but i was advised that the rear rims would be too large to fit without modding the fenders. So I've opted for wider tyres instead.
white_knight is offline   Reply With Quote
Old 12-29-2012, 05:56 PM   #755
Mitch
Drives: RIP '13 BRZ
Originally Posted by white_knight View Post
Thanks, guys.
Aesthetically there's not much difference when just staggering tires on same-width wheels. One tire will just look a little stretched compared to the other. Meanwhile this can have a profound affect on how your car handles at the limit. You're basically just building in understeer.
Edit: you're also sacrificing the ability to do any sort of tire rotation without paying mounting fees to swap tires side to side.
The Following User Says Thank You to Mitch For This Useful Post:
Old 12-29-2012, 08:07 PM   #756
white_knight
Thanks Mitch
Food for thought. I may as well go the full nine yards -- roll the guards, and get the staggered rims.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
