Old 12-17-2012, 04:32 PM   #1
Sheldon
Drives: 2013 Whiteout FR-S
Wheel Directory: Rota G-Force 18x8.5 +48 / 18x9.0 +35
I did some research on finding a staggered setup without having to break the bank. My preferred option would have been PF01 or RPF1 (18X8.5, 18X9.5) but at the time I could not find them in 5x100. I know tire rack now offers the PF01 in that setup, but it's too late now.
I'm pretty happy with how it came out, but if i could change anything it would be to have the fronts come out some more, maybe a +40 would've been more ideal. Also, the fronts came with different center caps than the rear, but that did not bother me too much.
The reason I did not want a square set-up was that from what I've seen with this car, is that if I went with a size that was perfect in the rear, would've been poking too much in the front...and vice versa.
I also considered the 57 extremes, but was nearly double the price of these wheels. So far, even after tracking the car, they have held up pretty well. No issues so far.
Set-up is:
18 X 8.5 +48
18 X 9.0 +35
Eibach Pro Kit
Sheldon is offline   Reply With Quote
Old 12-17-2012, 04:36 PM   #2
WheelDude.com
Drives: 2013 FRS
Send a message via AIM to WheelDude.com
Looks good, gunmetallic goes really well with whiteout since they both have a little pearl in it.
Good choice!
Zoeb
WheelDude.com is offline   Reply With Quote
Old 12-17-2012, 06:10 PM   #3
Sheldon
Thanks Zoeb. Although I did not order from you (maybe I should have-long story), I heard great things about your support.
Old 12-17-2012, 06:24 PM   #4
WheelDude.com
Drives: 2013 FRS
No worries, if you need anything in the future let us know
Old 12-17-2012, 07:05 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Looks Awesome! Personally I think that the slightly conservative front offset looks perfect. Did I miss the tire sizes? Thanks for posting.
Old 12-17-2012, 09:25 PM   #6
Sheldon
Thanks, no I forgot to post them -- 225/40/18 Front, 255/35/18 rear. Went with the General GMax AS03.
Old 12-17-2012, 11:18 PM   #7
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Looks good but hard to tell it's lowered and i'm a conservative lowering guy i only got Tein H Techs.
Old 12-17-2012, 11:56 PM   #8
Sac-BRZ
Drives: BRZ Limited AT
Looks good. Didn't realize those had that much concave in them.
Sac-BRZ is offline   Reply With Quote
Old 12-18-2012, 08:46 AM   #9
Sheldon
Yeah I was a little disappointed with that. Probably should have went with the Sportlines like my gut told me. Most likely I'll go with a coilover kit next year.
Old 12-18-2012, 06:52 PM   #10
tuwey
tuwey's Avatar
Drives: focus svt
How much room is between the tire and strut in the front. I have the same rims, but i'm not buying tires till spring. I'm planing on mounting 245/35/18, and need to know if a small spacer (3-5mm) is needed.
tuwey is offline   Reply With Quote
Old 12-18-2012, 09:19 PM   #11
Sheldon
I'm not sure if you could get away without using a small spacer. It is tight with the 225s. The pic below is with the car jacked up, so it may camber in towards the strut when lowered back down.
Old 12-18-2012, 09:55 PM   #12
JoeBoxer
JoeBoxer's Avatar
Yeah +48 on a 8.5 is really close to the strut, I had +44 on a 235/40 and it was really close.
Old 01-04-2013, 12:06 PM   #13
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 01-18-2013, 08:48 PM   #14
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I am getting the exact same set up, same tires except for 245/35/18's in the back. But will be dropped with Eibach Sportlines.
The front looks dangerously close to the struts and thinking about spacers up front. Which brand do you guys recommend for a good reliable spacers?
BRZPDX is offline   Reply With Quote
Wheel Directory: Rota G-Force 18x9.0 +35 sirus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-30-2013 09:34 AM
>>> Klutch SL14 staggered 18x8.5/18x9.5 wheels - starting @ $985.00 shipped speed depot Wheels and Tires 35 12-05-2012 12:54 PM
Staggered 18x8.5 and 18x9.5 WORK XSAs dminner Wheels and Tires 16 10-03-2012 12:13 AM
