| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
Site Moderator
Drives: Stuff
Mine hasn't burned a drop in almost 14,000 miles including 4 track days, at least nothing measurable. It's always basically at the full dot.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#16 |
Drives: FR-S (red manual)
I'm not sure how low it was. The service advisor did act somewhat concerned. Now, I'm getting more nervous. I hope if something is wrong they'll catch it and fix it while under warranty.
#17 |
I went thru a half quart in the first 3500, then consumption slowed down
#18 |
First 86
Drives: Scion FRS Argento Automatic
Mine hasn't used a drop.
Life is short...NO BORING CARS |
#19 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
if you dont get the rings bed in early, it will be an oil burner. Just like the EZ subaru engines.
#20 | |
#21 |
Backyard Fabricator
on your nice new engine, give it plenty of cylinder pressure and engine braking to force the rings out to the bore. If you baby it, it have a hard time bedding the rings in.
For now, keep checking the level every 1000 miles. Keep in mind the dipstick can be a bit of a pain to read correctly, and the difference between the low and full marks is 1L |
| The Following User Says Thank You to JP For This Useful Post: | FRSjeff (12-14-2012) |
#22 |
Drives: 2004 Subaru Forester 2.5XT
If you look at all of the Subaru forums where 0W-20 is specced (the new Foresters, Outbacks, the Impreza, etc.) you'll find oil consumption threads. There has been one on the Forester board since June 2011 which is only a couple of months after the Forester came out with the new engine.
Some of my theories: -Engines being broken in too easy (i.e. by the book) -First oil change done too early (the factory fill has boatloads of moly and extra zinc and phosphorus all which probably help with break-in) -Not enough testing on 0W-20 in these engines. Maybe top off with 5W-20. A 5W-20 will be less volatile than a 0W-20 and possibly even less volatile than a 5W-30 (which shears to a 20 weight anyway). These engines were supposedly designed with 0W-20 though. -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | FRSjeff (12-14-2012) |
#23 |
Drives: 2013 FR-S Blue MT
@bluesubie, we haven't seen many threads about big oil burners in the FA20 yet. This thread is the only one I can recall about oil consumption that I have read.
IMHO the impreza cvt cars seem like more likely candidates for ring sealing issues due to the nature of how the cvt works, whereas the brz/frs owners have control over engine revs and braking in both AT/MT configurations. BRZ/FRS owners overall are likely to drive their cars a bit more aggressively I would think than the average Impreza owner. I have ~4500 miles on my car so far and haven't seen the oil level move from full. I changed the oil at 550 miles and 2500 miles. |
| Factory Oil Fill Level | Black Tire | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 54 | 12-09-2016 01:14 AM |
| SOUND LEVEL TO LOW!! Not loud enough | Hbomb | Electronics | Audio | NAV | Infotainment | 24 | 12-21-2012 09:02 AM |
| Whole new level of respect for my FRS | 20valvewynn83 | Southern California | 18 | 08-19-2012 05:40 PM |
| Another Level 86's | SportInjected | Great Lakes | 4 | 07-30-2012 10:13 PM |
| An entry level FR revival? | aliphian | Other Vehicles & General Automotive Discussions | 9 | 11-14-2011 08:09 PM |
