Old 12-12-2012, 12:54 PM   #85
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
^ saddest thing i''ve heard all day =(
Thanks for the info SixSpeed
fenixv8 is offline   Reply With Quote
Old 12-12-2012, 02:38 PM   #86
Mo707
Mo707's Avatar
Originally Posted by 086A View Post
Hi guys/gals, I finally finished my push start last week. I wanted to get a video and pics up, but I got very busy this weekend. I will try and see what I can do this week. I would love to do a full DIY, but it could get very lengthy.... Hopefully this week I can get an updated video finished. I will try to give all of the Part #s and give a explanation of what I did and how it operates. I am not going to do wire for wire DIY, sorry. Although I would be glad to answer any question you have on the install.
Now I just need to get a TRD start switch....
Aloha,
What was the part number for the brz push to start housing? I want to start getting these parts together.
Mo707 is offline   Reply With Quote
Old 12-23-2012, 01:48 PM   #87
086A
086A's Avatar
Drives: Whiteout FR-S MT
See page 2 for the part numbers.
I am on vacation till the new year then I will have more videos up.....
Merry Christmas,
Sent from my iPad using Tapatalk HD
"Built by Passion!"
086A is offline   Reply With Quote
Old 12-25-2012, 11:15 PM   #88
Mo707
Mo707's Avatar
Originally Posted by markmatley View Post
Is the switch panel the plastic piece that holds the push button, pocket, and usb/aux module?
did you figure that out?
Old 12-26-2012, 04:27 AM   #89
086A
086A's Avatar
The piece is the whole pocket including the USB/Aux port. It just needs to be transferred over. Sorry I don't have any pics of just the part.....
Name:  ImageUploadedByTapatalk HD1356510260.393058.jpg
Name:  ImageUploadedByTapatalk HD1356510307.984968.jpg
Name:  ImageUploadedByTapatalk HD1356510360.504243.jpg
"Built by Passion!"
The Following User Says Thank You to 086A For This Useful Post:
Mo707 (12-26-2012)
Old 12-27-2012, 10:25 AM   #90
Hops Normal
Hops Normal's Avatar
Drives: 2013 Scion FR-S Peral White
so quick question. do you think this would be better than buying two idatalinks? idk if it would work for everything 086A used the idatalinks for.
http://ifar.ca/en/products/evo-serie...243,3581,10861
Hops Normal is offline   Reply With Quote
Old 12-27-2012, 02:24 PM   #91
086A
086A's Avatar
The only difference is the way this system does the immobilizer bypass. The idatalink doesn't need to have the key in the car after its programmed with the key info.
So yes it will work, but the key will have to be hidden in the vehicle dash somewhere.
"Built by Passion!"
Old 12-27-2012, 02:31 PM   #92
Hops Normal
Oh nvm then. Im gonna go with Idatalink
I don't want to have to use my key at all.
Sent from my SPH-L710 using Tapatalk 2
Old 12-27-2012, 05:47 PM   #93
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Nope. I haven't had time to pursue this due to renovating my house. I think the best bet would be to go down to your local Subaru and have them look up the parts and numbers with the blow up schematics to make sure.
Good luck and let me know if you get anywhere with this. =)
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 12-28-2012, 03:11 AM   #94
redKnight
Drives: Subaru
Is the Switch Panel really only $4.84? That's the price I got from the first site that popped from google. If yes, then that's not bad at all.
redKnight is offline   Reply With Quote
Old 12-28-2012, 05:08 AM   #95
086A
086A's Avatar
That price is correct. I paid $5 and some change for it in Hawaii. The rubber mat was more at $7. You could maybe remove the stock one and cut it. But for $12 it was easier to order it the same time.
"Built by Passion!"
redKnight (12-30-2012)
Old 12-29-2012, 06:50 PM   #96
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
does anyone have the part number for the actual push to start button? ive got the panel, mat and key cover, but i need the rest to get this rolling!
ph0en1xtk is offline   Reply With Quote
Old 12-29-2012, 09:18 PM   #97
mr2lor
Drives: 2013 Scion FR-S Asphalt MT
Can you link the website for those pieces? TIA
mr2lor is offline   Reply With Quote
Old 01-05-2013, 12:07 PM   #98
ph0en1xtk
ph0en1xtk's Avatar
guess this went overlooked, so ill bump it up. Does anyone have the part number for the button itself?
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 06:19 PM
for sale: OEM - RED STI push button start, brand new. notFRS Interior Parts (Incl. Lighting) 3 08-02-2012 03:16 AM
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 02:45 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 04:52 PM
Push button start general question maxeveland Other Vehicles & General Automotive Discussions 9 02-14-2012 11:13 AM
