GEARS!!???
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
hard shifting in sport mode AT
Hello all, I was accelerating onto the highway today in sport mode and had to let off of the pedal because another car was moving into my lane ahead of me, the transmission kicked kinda hard downshifting. Is this normal? I know in my mazda 3 it would do this if it was getting ready to go into a higher gear and you suddenly let off.
#2 | |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
#3 |
GEARS!!???
#4 |
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Is it reproducible? One-off things are always abnormal, but because they only happen once, future occurrence doesn't matter.
This is how I use my brain. |
| The Following User Says Thank You to b.e For This Useful Post: | whataboutbob (12-09-2012) |
#5 |
Registered you sir
Drives: 99 impreza coupe
Ya couldn't put the pedal down harder and pass them, huh? Doesnt seem like anything too bad could have happened.
#6 |
Some times the car shift like a greased ape some times it just shift? I ordered the whiteline tranny bushing, I'll see if it changes it's current behavior.
#7 |
Drives: Asphalt FRS
The trans shifts hard sometimes, I think we're all just hyperaware of whats going on with our cars. Any serious trans problems should throw a cel code (correct me if i'm wrong)
#8 |
Drives: Silver AT Limited
did you press the brake pedal? The car will auto blip in sport mode when braking to put you in the correct rpm range as you slow down
#9 |
Drives: 2013 Scion FR-S 6AT Firestor
I have been noticing a similar, yet different problem with my FR-S AT.
If I hold the pedal at a certain spot any old spot, just hold it at the exact same on for a duration of time) I expect the gears to shift in a roughly time sequential manner, I.E 2 sec though first, 2.5 through second, 3 through third, 4 through 4th, etc. What I find happening sometimes though, is that It shifts really randomly, eg 3 sec through first, 1.5 trough 2nd, 3 through third, 1 through 4th, etc. not any particular "standard sequence". I am not very familiar with how an AT works, but I would think that this is not normal. Remember also, I am holding the throttle at the exact same spot through all the gears, and it never does this near or at WOT, only at 1/4-3/4 throttle. If I need a new thread on this, I can start it up, and sorry for jacking this one, but I saw an "odd shifting in AT" thread and thought it might be sufficiently related.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna 5AD Spoiler 205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only) Rally Armor mudflaps in black with red logos |
#10 | |
Tintiot
Drives: Raven FRS
Both in Acc and slowing down the sports mode makes hard shifts as you would if driving hard on a Manual. hey just my 2 cents. Dont know any better
Raven FRS AT Stock
Rebadged |
#11 | |
Registered you sir
#12 |
Drives: GT86
This is the Dynamic Rev Matching system they have installed. Yes, it does hard down shifts and yea, its normal. What I noticed is it downshifts hard, when you're driving hard so that the car keeps up with you... as someone mentioned, like you would be doing when driving hard in a manual.
I love the system but I also don't know how it works exactly, but its definitely nothing to be worried at all. Its designed this way. |
| The Following User Says Thank You to Froylavin For This Useful Post: | sofrsnsokleen (12-13-2012) |
| Vsc sport mode and trac off | RWD-boxer | Engine, Exhaust, Transmission | 94 | 02-25-2020 09:23 PM |
| Hard shifting into first gear; normal? | blalor | Engine, Exhaust, Transmission | 54 | 08-31-2017 09:57 PM |
| AT Sport Mode - What does it do exactly? | karbon | BRZ First-Gen (2012+) — General Topics | 49 | 09-02-2014 02:40 AM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 02:22 PM |
| sport mode... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-01-2012 11:50 AM |
