| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#547 |
SLO NO MO
Rota gets a lot of criticism since they had some failures early on that were highly publicized. Truth is they sell a lot of wheels and they're affordable. Any wheel will crack under abusive conditions. It was just more publicized with the Rota since the population set is huge. They make OEM tires for the big car makers in the Asian markets and comply with the Japanese standards. They aren't the lightest wheels around nor are they using the most advanced manufacturing techniques, but you have to ask yourself if you require that for your use case.
I think they're fine. That said, I'm going with Weds TC105N's because I really liked the look, it's not overly expensive, and RavSpec has a good deal and are local to me. I'd keep my primacy tires to burn through them but I'm going staggered with 17x8 / 17x9 so that's not an option. Had I stayed square with 17x8, I'd use them up first. Sent from my Galaxy Nexus using Tapatalk 2 |
#548 |
Not just compound, whole new tire.
#549 | |
Drives: Attitude
Thanks for the clarification. |
#550 |
Drives: Ford Focus RS & Toyota 86 GTS
Anyone running 225/40/18 on 18x8.5/9.5?
Recently received my Work Emotion Kiwamis in bronze and was wondering if anyone is possibly running 225/40/18 on a staggered 18x8.5/9.5 setup?
#551 |
Drives: 86
I have 225/40/18 on 8.5 but its too narrow for 9.5 so I run 245/35 instead.
#552 |
Thanks for the reply buddy.
Can you link me to your build thread so I can have a peak...
#553 |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
I have 225/40R18 on the front on mine and 255/35R18 on the rear its a good fit
BONKRS for life
#554 |
You guys finding 245/255 easy enough to slide?
#555 |
Ridge Racerrrrrrrrr
I remember reading 225/245 (f/r) tire sizes allow the FRS to still have some fun with its stock power
#556 |
Drives: FR-S Asphalt AT
what's your offset? I was thinking about running the same set up but for the Raijin's
#557 | |
As for the KDW2... The KDW2 are OLD! There are much better tires and options now.
#558 |
Drives: Whiteout FR-S
I tried researching the forums and learning, but all these numbers are making my head hurt and I'm not entirely sure which numbers to match to ensure fitment.
Can anyone confirm if these will fit the stock tires? http://www.ebay.ca/itm/17X9-ROTA-GRI...03d839&vxp=mtr Wheel size: 17x9 Bolt pattern: 5x100 Offset: +30 If they fit the stock tires, does that mean the stock lug nuts will fit too? If not, how do I find out which aftermarket lug nuts to buy? |
#559 | |
#560 | |
Also, does that mean the stock lug nuts won't fit? How do I know what size to get? Can I deduce that somehow from the wheel size? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
