#1 | |
Drift King
Drives: '13 Firestorm FR-S 6MT
OFFICIAL Torque Android app PID/Misc Thread
For the BEST tablet mount for the Nexus 7, visit this post!: http://www.ft86club.com/forums/showp...&postcount=436
List of confirmed working PID(s) can be found in the second post. Frequently Asked Questions can be found in the third post. Custom made themes can be found in the third post. As many of you know, and I'm sure many of you don't know, there is an App called Torque/Torque Pro on the Android market for Android based devices. To sum it up, the app allows the user to have access to hundreds of readings from the cars factory sensors, and can allow for data logging and other cool features, you will find the description pulled directly from the app below. What are the benefits of this app? Allow for data logging to help with trouble shooting An alternative to expensive gauges which take time to set up. Good for anyone that wants a basic idea of what's going on with their cars. i.e. I plan on mounting a Nexus 7 in my car, for the only purpose of a "Gauge Pod" and maybe the use of navigation. This is actually very similar to the Nissan GT-R's setup. (You can monitor specific readings through the head unit and have the ability to customize it your preference.) There are various reasons as to why I'm starting this thread; - The main focus of this thread is to have area where we can discuss the manufacturer specific PID's for OBDII, I'm not entirely sure if FRS/BRZ PID's are the same. The app comes standard with a bunch of features, but to get the good stuff we need access to the PID's which tend to be very hard to get. I'm hoping with the help of the large community we can gain access to PID's like the Engine Oil Temperature (EOT), to be able to have a live reading of our cars EOT. I plan on maintaining a list of PID's that are confirmed to work with our vehicles. UPDATE: Oil Temp PID has been determined. - We can also use this thread as a universal thread for anyone having troubles with app, OBDII BT transmitter and other problems. -Discuss current setups such as your layout on torque, mounts, devices, transmitters. There's many benefits of this thread, and hopefully with the help of the community we can get access to an advanced list of PID's for our cars. Here is the app description; Quote:
| The Following 17 Users Say Thank You to Brody602 For This Useful Post: | ali (03-16-2015), amram (04-06-2014), Black Tire (08-08-2014), blackfireball5 (03-31-2014), CxG (01-12-2017), Fly Guy (04-26-2013), ftc~brz (07-12-2013), gled21 (03-08-2016), jonnyozero3 (04-20-2013), Lischynski (10-28-2014), melon (02-16-2014), mid_life_crisis (09-09-2013), nexusatm (08-19-2015), themadscientist (11-28-2014), WillRacer1jz (11-13-2013), zoomzoomers (04-01-2013), \o/ (09-04-2014) |
#2 | ||
Drift King
Oil Temperature PID credit to andreyiv:
| The Following 32 Users Say Thank You to Brody602 For This Useful Post: | 6pack (10-28-2014), adjusts (07-27-2017), ali (03-16-2015), blackfireball5 (03-31-2014), ChiefG (09-03-2014), CxG (01-12-2017), daiheadjai (09-10-2014), Draco-REX (04-22-2014), finch1750 (03-18-2014), Fly Guy (04-26-2013), fstlane (04-05-2015), FT86Z (08-27-2023), garfull (09-16-2013), jonnyozero3 (04-20-2013), Joon525 (09-13-2017), LeeMaster (02-05-2013), Lischynski (10-28-2014), melon (02-16-2014), mountainside (08-23-2013), nexusatm (08-19-2015), P3tras (07-03-2015), Pacific (03-27-2014), Sideways (08-30-2016), T-Steve (04-19-2023), t0dd (02-04-2013), timurrrr (04-05-2021), Touge Factory (11-05-2013), Trunksse (01-11-2014), UREU (12-19-2021), whataboutbob (07-20-2013), WillRacer1jz (11-13-2013), zoomzoomers (04-01-2013) |
#3 | |
Drift King
Frequently Asked Questions:
(Please note: Some of the answers provided are borrowed from other users, not just me.) Q. How do I add extra PID's? A. Open the Torque app and then hit the menu button. Select "Manage extra PIDs/Sensors" (should be second from the bottom). Hit the menu key again and select "Add custom PID". Enter the PID information provided (And a full and short name of your choice). Hit ok. The parameter will now be available for logging and real time display. Q. How accurate are the readings, are they trustworthy? A. Generally speaking any sensor related information should be accurate considering it is coming directly from your ECU. There is a slight lag/delay in receiving the information but nothing major, unless your racing competitively you may want actual gauges. I've tested the Boost and AFR gauges for accuracy in my brothers EVO X in comparison with his in car gauges, the readings I was getting on my tablet matched perfectly his in car gauges. When it comes to WHP that is a calculation based on the car specific information you input into the app, for an accurate reading, you'd to input exact weight, max RPM ect. The same applies to any other non sensor calculations. Q. Will we be able to monitor Boost levels even if our car isn't a factory forced induction system? A. Yes it shouldn't be an issue, our MAP sensor is what calculates these values. We are able to monitor our Vacuum produced and Boost is the same value as Vacuum except Vacuum is a negative value and Boost is a positive value therefore it should display real time boost information with any setup. Q. The PID I've entered is in Celcius can I switch it to Fahrenheit? A. Yes. To change the read out to Fahrenheit, go to Settings -> Units on the main screen for Torque and uncheck the checkmark that says something along the lines of Display In Celsius. All temperature readouts should change to Fahrenheit correctly. Q. I don't have an option for OBD header in the custom PID, do I need this? A. For certain PID's such as Engine Oil Temperature you need to input OBD header information, you'll need to purchase the Torque Pro App in order to be able to enter the OBD header information. Custom made themes: Quote:
#4 |
Drives: 1995 Acura Integra GS-R
Getting a Nexus 7 this week, got a Proclip to use with it. Might be trading proclip mount for the beatrush one when it comes out. I think it's an awesome alternative to actual gauges.
There is no glare from the display, it's just the camera with sun right in front of it. Got the charger looped around behind and into glovebox charger. It's slightly in the way of headunit, but all corner touch controls are still operable. ![]() This mount clips where center console joins with dash, and clips in vent. It's a little close to headunit, so I might 'upgrade' to Beatrush's mount that goes in the slit to the right a little. Last edited by xn7485; 12-06-2012 at 09:05 PM. Reason: Picture |
| The Following User Says Thank You to xn7485 For This Useful Post: | Scooby South (12-24-2012) |
#5 | ||
Drift King
Edit: I'm also looking into if the app's boost gauge will support aftermarket turbos, because it supports factory turbo setups. Simply because I plan on going down the FI route. I did get some feedback on the Torque forums from a user but idk how reliable his info is.. If anyone can confirm this it would be appreciated. :happy0180: Quote:
#6 |
Drift King
BUMP
'13 6MT Firestorm FR-S
#8 | |
Drift King
#9 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
Super Mini ELM327 OBD-II Interface Bluetooth V1.5 Auto Diagnostic Scanner For Windows PC
Arkon TAB-FSM Tablet Seat Bolt Mount ![]()
| The Following 3 Users Say Thank You to Spartan65 For This Useful Post: |
#10 |
Drift King
Nice setup! Currently AVO is looking into seeing if they can acquire the vehicle PID's via the tunner edition of EcuTek for us ! ;D
| The Following User Says Thank You to Brody602 For This Useful Post: | Spartan65 (12-04-2012) |
#11 |
Drives: 2013 Ultramarine FR-S
hows that seat bolt mount working out? pretty sturdy or does it move around when cornering? I've been looking for some car mounts for my Nexus 7 and this one topped my list.
| The Following User Says Thank You to Freeman For This Useful Post: | CxG (01-12-2017) |
#12 |
Ok when cornering, but I was thinking of augmenting it for our third world country roads where I live.
#13 |
BTW, I've been told PIDs are locked on ECUTek tunes. So unless it's a standardized parameter (ex. Coolant Temp), then you won't be able to access the signal.
#14 | |
Drift King
, if this is the case I believe Techstream is the only way..
| The Following User Says Thank You to Brody602 For This Useful Post: | Barusu (04-21-2017) |
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 05:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-23-2012 12:05 AM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 05:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 02:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 09:23 PM |
