Old 11-20-2012, 05:44 PM   #71
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Good info!
When I saw results on the first page I
The Following User Says Thank You to RRnold For This Useful Post:
Jesse (12-01-2012)
Old 11-21-2012, 05:02 PM   #72
Jeffsu350
Drives: Frs
I just got my first oil change analysis back from Blackstone.
Same as everyone else, high wear and silicon.
I did an easy 1K break in with varying RPM on the highway.
After 1K I drove the car relatively hard. This oil also has 50+ autox runs.
They did suggest to run the next oil change out 10k miles.
I have my free oil changes, so I will probably do 7,500 miles.
Jeffsu350 is offline   Reply With Quote
Old 11-22-2012, 08:48 AM   #73
bluesubie
Drives: 2004 Subaru Forester 2.5XT
10,000 miles based on one uoa of the factory fill? Sometimes I really wonder about their comments. Did you not fill the bottle completely? Nice to see someone really pushing the factory fill instead of, "ZoMg! I need to change the oil at 50, 100, 500, 1,000, and 3,000 to get the metal bits out!".
-Dennis
bluesubie is offline   Reply With Quote
Old 11-22-2012, 09:13 AM   #74
Jeffsu350
Drives: Frs
I had the dealership fill the bottle when they did my free oil change.
The TBN was still good so I think that's what they were referring to.
I wouldn't be surprised if we could go longer than 10k for subsequent changes
Old 11-22-2012, 11:54 AM   #75
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Just sent mine in at 4k miles, eager to see what comes back.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 11-30-2012, 10:12 PM   #76
yomny
yomny's Avatar
Seems like my Mobil 1 could make it to 6k, il see what my next analysis says.
The Following User Says Thank You to yomny For This Useful Post:
civicdrivr (11-30-2012)
Old 11-30-2012, 11:26 PM   #77
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
@yomny, you might want to blur out your full address and phone number.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
yomny (11-30-2012)
Old 12-01-2012, 07:12 PM   #78
zoomzoomers
zoomzoomers's Avatar
So I guess it goes to show that there's nothing to fear with Mobil 1?
Old 12-01-2012, 10:13 PM   #79
yomny
yomny's Avatar
I've been using it in most of my cars, and i can easily acquire 0w-20 at my local auto parts.
Old 12-01-2012, 10:35 PM   #80
zoomzoomers
I've always had great results with Mobil 1. It wasn't till I got here that I saw negative reviews of it. Glad to see you're getting good results with it.
Old 12-01-2012, 11:08 PM   #81
getbent
Drives: 2013 FR-S Blue MT
@yomny your UOA has been the best one I have seen for this engine yet. You didn't have much oil shearing compared to nearly everyone else. What kind of driving do you typically do (highway/city percentage)?
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 12-03-2012, 10:20 AM   #82
bluesubie
Most defintely. After one more oil change, and a uoa showing your break-in metals settling down, I would just go to 7,500 mile intervals.
Your residual moly levels from the factory fill assembly lube and factory fill will drop, but I believe ExxonMobil uses the new trinuclear moly.
Infineum Moly additive technology pdf.
Similar friction modification and anti-wear with lower moly levels.
-Dennis
Old 12-04-2012, 12:27 PM   #83
yomny
yomny's Avatar
I did a frist oil change at 150 miles, so that could be a good reason why. I drive the car a 50/50 between highway and city, plus i drive me car hard, not abusively but like a sports car.
bestwheelbase (12-11-2012)
Old 12-06-2012, 09:51 AM   #84
bluesubie
This thread reminded me that you guys doing uoa's will really need to keep an eye on fuel and flashpoint. As I mentioned in the other thread, BS does not actually test for fuel dilution but they extrapolate the number from the flashpoint reading.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=968027
Interesting to see that Blackstone is recommending that the above interval be extended when the flashpoint has dropped to 375. Short trips will increase fuel, as will not taking the uoa sample on a hot engine or a couple of WOT runs before the sample.
I would still be a bit cautious about following Blackstone's advice. I've pointed out errors in their uoa's before. Two cases were uoa's of Rotella T6 that came back with weaker zinc and phosphorus levels than a typical GF-5 5W-30, which is not possible.
-Dennis
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
