Old 11-08-2012, 08:03 PM   #1
wtout86
Drives: Whitout FR-S 6MT
Wheel Directory: OEM Subaru Impreza STi (JDM 2001) 17x7.5 +53
I came across a pretty good deal on a set of jdm gold sti wheels 17x7.5 with 53 offset with really good winter tires, but 225 45 17. Just the tires are worth his asking price. Should I jump on these? Does anyone think the 225 is too wide for winter?
wtout86 is offline   Reply With Quote
Old 11-08-2012, 08:24 PM   #2
wtout86
$650, apparently about 10,000km according to seller, Good price?
Old 11-08-2012, 08:34 PM   #3
Pete156
I like to eat!
Excellent price!
Pete156 is offline   Reply With Quote
Old 11-08-2012, 08:43 PM   #4
jma
That width even with 53 offset should clear everything without problems. Your speedo will be off a bit, so what, it's a winter set. Thinner, taller tires are supposedly better for snow but I don't believe such a small increase in width will make any difference.
FYI, Like you I picked up a used set for winter with 225/40/18 tires, 18x8, 43 offset, no clearance problems. Your wheels are a lot nicer than mine, even in gold(not my color of choice). Enjoy.
jma is offline   Reply With Quote
Old 11-08-2012, 08:51 PM   #5
wtout86
1.464% size difference according to tire rack. Probably wont even notice it. I'm going to try and pick them up tomorrow.
Old 11-08-2012, 09:00 PM   #6
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
Definitely not too wide. Narrower the better in snow but I had 255 Blizzaks on my 370z and that thing was a tank in the snow!
sajonf is offline   Reply With Quote
Old 11-11-2012, 05:28 AM   #7
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Do it. Great looking wheels.
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 11-11-2012, 10:56 AM   #8
Hippophobia
Drives: 2013 Whiteout FRS
Why would the speedo be off? It's the same height as OEM tires/wheels. The width is not going to change speedo readings.
You should fit fine with those. I'm running 225/45/17s on a set of 05 Legacy GT 17x7 +55. No fitment issues. My summer wheels/tires are 225/45/17 on 17x8.5 +43 Advans. Also no issues.
Hippophobia is offline   Reply With Quote
Old 11-11-2012, 12:02 PM   #9
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Although they're both 45 series tires, that 45 is a percentage of the width, so when the width increases from stock with the same 45 series sidewall, the sidewall height actually changes a bit and it will have a larger overall diameter. Stock tire sidewall is 45% of 215mm while these tires will have a sidewall that is 45% of 225.
If you ever want to see the difference the width will make in the overall diameter you can go to tirerack and find a given tire and then click on specs. It will show the overall diameter of the tire and various other sizes of that tire for you to compare. Good information to have if you're concerned with maintaining the gearing the car currently has. A larger overall diameter might make the car feel a little slower but you'd probably get slightly better highway mileage at the same speed.
A5D5TRYR is offline   Reply With Quote
Old 11-11-2012, 12:45 PM   #10
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
http://www.1010tires.com/tiresizecalculator.asp
really nice offset calculator too, i'd save these links....
http://www.1010tires.com/WheelOffsetCalculator.asp
The Following User Says Thank You to JoeBoxer For This Useful Post:
A5D5TRYR (11-11-2012)
Old 11-11-2012, 01:39 PM   #11
A5D5TRYR
A5D5TRYR's Avatar
Originally Posted by JoeBoxer View Post
Just went and had a look. That's pretty comprehensive, thanks!
Old 11-11-2012, 01:59 PM   #12
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
What year sti were they off? Check bolt pattern before you buy.
It is in change that we find purpose.
Double4Free is offline   Reply With Quote
Old 11-12-2012, 02:27 PM   #13
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Watching topic to see wheels mounted!
Old 11-12-2012, 10:10 PM   #14
wtout86
Well the ad says 5x100 right in it, so I hope he's right. I'll bring a measuring tape to double check. Should be picking these up tomorrow afternoon. Will put pics up as soon as there mounted.
Wheel Directory: OEM Subaru Impreza WRX (2002) 16x6.5 +53 avusblue Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 07-21-2016 09:03 PM
Wheel Directory: OEM Subaru Impreza WRX (2012) 17x8+53 GrimmSpeed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 04-29-2016 12:54 AM
Wheel Directory: OEM Subaru Legacy GT (2005-2007) 17x7.0 +55 Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 08-17-2015 08:17 PM
Wheel Directory: OEM Subaru Impreza 2.5RS (1998-1999) 16x7.0 +53 BRZZZZZZZZZZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-03-2014 03:28 PM
Wheel Directory: Subaru Option BBS 17x7.0 +53 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-20-2013 10:59 PM
