Old 11-07-2012, 09:26 PM   #15
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by benster View Post
this is also for a nascar based engine that spins between 6000 and 9500 rpms for 2 hours straight, not a daily driver. I do understand the reason for this in a race when the engine is always in the upper rpm range and being pushed hard for a long time, just not in a street engine.
I drive my car harder than you do apparently.
Old 11-07-2012, 09:53 PM   #16
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Originally Posted by chulooz View Post
Their oil lasts to the double digits; you just need to replace the filter midway through.
AMSOIL Ea Heavy-Duty Extended-Life Oil Filters
Excellent Efficiency and Capacity Throughout Extended-Service Intervals.
AMSOIL Ea Heavy-Duty Extended-Life Oil Filters (EaHD) provide excellent filtering efficiency and high levels of contaminant capacity for heavy-duty on- and off-road gasoline and diesel applications. They provide extended service intervals that coincide with the maximum drain interval recommendations of AMSOIL synthetic motor oils (not to exceed one year), increasing convenience and reducing maintenance costs.
And at the bottom of this thread is a WRX uoa showing probably the lowest insolubles that you can get. He ran the factory Honeywell filter (which everyone says sucks) for 5,000 miles. People on WRX and STI forums are still searching for Tokyo Roki's (after Subaru switched to Honeywell several years ago in the EJ engines) because they have always been considered the best oil filter Subaru has used.
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
AZP Installs (11-25-2012)
Old 11-08-2012, 05:07 AM   #17
Le86
Drives: Asphalt FR-S
Originally Posted by GMT View Post
This is the knowledge I need. I didn't want to make a mess. I'm at 1000 mi and wanted to swap out the oil filter filter to get rid of any metal from the breaking in period. San Francisco Toyota won't perform the oil change until 7500 mi. It'll take me close to a year to get there so I was thinking about an oil filter change.
Just so you know, I did an oil change at 1000 miles out of paranoia of metal shavings. I used a telescoping magnet and poked it around inside my oilpan after draining all the oil and it didn't pick up a single speck of metal shavings. I only did it because I read that so many people did the oil change at 1000 and I just had to see for myself. IMHO, it was a waste of money. If I had the choice still, I would just wait until my dealer recommended 5000 miles oil change.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Le86 For This Useful Post:
GMT (11-08-2012), leej (11-08-2012)
Old 11-23-2012, 07:38 AM   #18
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Preventative care is the best kind
I will be changing mine often..
Anyway, its simple, leave the car to cool down, most of the oil will drain out, if you have a stock filter it will have an anti drain back valve.
With the new one, pour a bit of oil in to it, till it fills about half way and just wait, it will soak into the filter.
Then rub a thin film onto the rubber, put it on and tighten it by hand, not too tight though.
And you are done
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
GMT (11-25-2012)
Old 11-23-2012, 12:36 PM   #19
ST185RC
Drives: White Out FR-S
Spend money on a filter magnet, it will pay for itself over time relative to changing your filter between oil changes.
ST185RC is offline   Reply With Quote
Old 11-25-2012, 09:41 PM   #20
GMT
GMT's Avatar
Drives: 2013 Scion FR-S 6MT Asphalt
Where can I get a filter magnet?
I've never used one so this is new to me. Thanks.
- and yet, it moves! ... Galileo
GMT is offline   Reply With Quote
Old 11-25-2012, 10:31 PM   #21
Ingen
Drives: Ultramarine FR-S 6MT
Alternatively, 15 bucks worth of neodymium magnets will do the same work without so much cost.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 12-08-2012, 12:08 AM   #22
Splat
Drives: FR-S ultramarine
this is also for a nascar based engine that spins between 6000 and 9500 rpms for 2 hours straight, not a daily driver. I do understand the reason for this in a race when the engine is always in the upper rpm range and being pushed hard for a long time, just not in a street engine, but hey, if it floats your boat to do it, go ahead.
I'd probably be doing that if I had a 4-500hp engine, but then again I'd probably just change the oil at the same time due to blow-by getting in the oil and deteriorating it.
my opinion, take it or leave it.
I will leave it.
I run my car hard every weekend for fun for couple hour rides 5-7k rev almost always and that is running hard for this car. Does not matter what the HP is. The key here is recommend oil change at whatever, and is set for the average daily driver. This does not mean you can not do it sooner. The best way to keep your oil filter working properly, or any filter for that matter, is to make sure it is clean and not clogged. Spending a few bucks and minutes is good time spent with your pride and joy.
Splat is offline   Reply With Quote
The Following User Says Thank You to Splat For This Useful Post:
GMT (12-19-2012)
Old 12-08-2012, 12:27 AM   #23
White Shadow
Drives: 12,000 miles per year
Just for the record, there will be oil in the oil filter when you remove it from the engine. The oil filter has an anti-drain valve that keeps oil in the filter when the engine is shut off. The idea behind the anti-drain valve is to keep oil in the filter, which helps the engine build oil pressure as quickly as possible upon engine start-up. Anyone who has removed an oil filter should know that it has oil in it just by the weight of the thing alone!
BTW, an old mechanic's trick is to fill a new oil filter with clean engine oil before installing it. You can fill it up and turn it upside down and the oil will stay in there without leaking out. I do it all the time on my 4Runner, which has an upside down filter mounted out in front, just like the FR-S/BRZ.
White Shadow is offline   Reply With Quote
The Following User Says Thank You to White Shadow For This Useful Post:
GMT (12-19-2012)
Old 12-08-2012, 07:51 AM   #24
gmookher
I never tried a filter magnet but will now...which one are you all getting?
Old 12-10-2012, 02:07 AM   #25
IShouldStudy
IShouldStudy's Avatar
Drives: 2013 Firestorm FRS, 97 BMW M3
Some other members have already purchased filtermags and I believe the recommendation was the filtermag ss300 if you are using the #130 subaru oil filter. It depends on the filter dimension of the filter you are running. For instance I'm trying to decide which oil filter to go with tonight and have been doing quite a bit of research.
Mobil 1 oil filter at autozone (M1-104) has an outside diameter of 3.62
K&N HP-1004 oil filter has an outside diameter of 3.156
For the K&N you would want the SS300 filtermag per the diameter specifications on the filtermag website and Jegs.
http://www.jegs.com/p/FilterMAG/Filt...13786/10002/-1
Willow Springs
IShouldStudy is offline   Reply With Quote
Oil filter part number change, both #s deconstructed. Calum Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 03-05-2023 01:02 PM
Oil Filter Hayashi Hawaii 2 02-20-2013 12:07 AM
WTB: TRD oil filter 86_ZN6 Engine, Exhaust, Bolt-Ons 0 08-26-2012 12:50 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
