Old 10-28-2012, 09:19 AM   #3361
lopro25
lopro25's Avatar
Drives: Hot Lava FR-S
Originally Posted by Calum View Post
Also, can you give us a run down on how to use launch control? Every time I try to use it I just bounce the engine off the rev limiter.
You have to do things in this order...
1. Stop the car
2.go to neutral with clutch out
3. Clutch in and go to first
4. Mash the gas HARD. You've got to be WOT
5. Revs should bounce off of 4k(or whatever you have set)
6. While revs are bouncing push the CC stalk up or down to adjust your RPM setting.
I had a problem because I have a habit of shifting to first and leaving clutch in before I'm fully stopped, but I guess for LC to work it has to see 0mph and then neutral and then first. I was going to first before stopping fully.
Sent using mobile Tapatalk App
lopro25 is offline
The Following 2 Users Say Thank You to lopro25 For This Useful Post:
Calum (10-28-2012), JPxM0Dz (10-28-2012)
Old 10-28-2012, 10:06 AM   #3362
Visconti
Drives: 05 STi
Will the sensor be plug and play, or will guys have to add an input to the ECU?
How is the ECU controlled electronic boost control working? (Not the Crawford car itself, I understand you can't talk about that, just the feature)
Boost control works just fine when setup correctly.
I'm also working on a meth kit fails afe that's wired into the Ecu.
Right now I'm sorting out the wiring, but the plan is full plug and play no cutting of anything
John
Visconti is offline
The Following 3 Users Say Thank You to Visconti For This Useful Post:
Calum (10-28-2012), civicdrivr (10-28-2012), LeavingNormal (10-28-2012)
Old 10-28-2012, 12:14 PM   #3363
Calum
That Guy
Drives: 2013 asphalt FRS MT
1. Stop the car
Ah! I was missing step 2. Thanks.
John
Wow, that sounds ominous. Did something have a catastrophic failure?
How many inputs do you think can be added, so far you've spoken of a flex fuel sensor, boost solenoid and now a meth kit? Is there any chance of running all of these simultaneously? It would be a metric fuck ton of tuning but all three of these working in concert could make for a very flexible and safe setup.
Calum is offline
Old 10-28-2012, 12:21 PM   #3364
Visconti
Drives: 05 STi
I'm not sure if I can do all 3 at the same time RIGHT now, but I can Master Phil @ EcuTek to do somethingn for me.
How I see it is if your running meth then you most likely have no e85.. which means you dont need the flex fuel stuff
-John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Calum (10-28-2012)
Old 10-28-2012, 12:31 PM   #3365
Visconti
Drives: 05 STi
Where is my e85 cold start datalogs / input guys ??
Visconti is offline
Area86 (10-28-2012)
Old 10-28-2012, 12:35 PM   #3366
Yruyur
Yruyur's Avatar
@Visconti did you copy my dongle id from the most recent forms or an older one. I just remembered my first tune was using a loaner from another member here but that was a long time ago.
Yruyur is offline
Old 10-28-2012, 12:36 PM   #3367
Visconti
Drives: 05 STi
Most recent..
The loaner cables tuners were labeled differently on my folder system so I know what dongle ID that is.
Visconti is offline
Old 10-28-2012, 12:50 PM   #3368
Yruyur
Yruyur's Avatar
Here is my screen shot. Is it possible my vin is wrong or is the error message only for the dongle id?
Yruyur is offline
Old 10-28-2012, 01:12 PM   #3369
DSTL
Drives: 2013 BRZ Limited 6MT
Mine started right up after sitting 3 hours last night. Upper 30s out. Sat overnight now and will do a cold and warm start log in the next hour.
DSTL is offline
The Following 2 Users Say Thank You to DSTL For This Useful Post:
Area86 (10-28-2012), TyperRspec789 (10-28-2012)
Old 10-28-2012, 03:27 PM   #3370
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
This is intoxicating...
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
Old 10-28-2012, 03:35 PM   #3371
Calum
That Guy
Oh yeah. In case anyone cares about the driveability issues I mentioned a couple pages back. It seems like the ECU just didn't have all the info for those areas as it's smoothed now. I did notice it a little bit yesterday but it was gone once the car warmed up. I'm guessing it's an open loop/cold start issue but even then it seems to be sorting itself out.
Calum is offline
Old 10-28-2012, 04:56 PM   #3372
Visconti
Drives: 05 STi
You need to COPY and PASTE dongle info into the form
Visconti is offline
Yruyur (10-28-2012)
Old 10-28-2012, 07:46 PM   #3373
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
Just to get this straight, I should be getting my cable in Monday - Tuesday... If I got an older Tune file from john, can we flash that or do I need a new one?
RR-10826-FF-LL-AB-ZA1J700C-STG1 v1.07-6AC5C5.BIN
1284K Download
ZA1J700C-enc.BIN
1284K Download
Got them Oct 15th.
Gregory Gawaran is offline
Old 10-28-2012, 08:02 PM   #3374
cnk
Drives: '13 DGM BRZ Limited
1284K Download
ZA1J700C-enc.BIN
1284K Download
Got them Oct 15th.
The file you want is RR-10895.
cnk is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
