Old 07-23-2011, 09:17 PM   #15
Abflug
Abflug's Avatar
Drives: MR2
offers from 260 € for a used set to open end!
I don´t think the ft-86 is reaching my expections so I´m going to invest into my MR2 as I already mentioned before.
Abflug is offline   Reply With Quote
Old 07-24-2011, 01:52 AM   #16
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
the eibach pro-kit should be comfortable as far as springs go, while still offering improved performance over stock. the dampers can make a HUGE difference, so i would recommend spending as much as you can there. KYB AGX are pretty stiff. tokico illuminas are good, but apparently Koni yellows are some of the best for the money, and very comfortable.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 08-05-2011, 08:56 PM   #17
26psi
Drives: 1991 MR2, 2008 Corolla
I'd like to add my two cents:
I used to have the Tein-S springs with Tokico Illuminas on my '91 Turbo and while I LOVED the razor sharp turn-in and responsive steering, I ended up blowing the rear shocks just 5,000 miles into the whole venture This probably happened for two reasons: 1) I travel down a pothole ridden So-Cal freeway everyday so I was really running a risk by daily driving my beloved 'Two 2) I did not modify the bump stops at all and I ran the highest shock setting. In hindsight this was a retarded idea but what can I say- the handling benefits were addicting
Since this whole suspension fiasco, I now run the stock OEM shock and spring set-up. Indeed I compromised killer handling characteristics for ride comfort and durability, but it's realistically the most ideal set-up for my driving habits. Plus, I paid about $100 per shock for the OEM units so the price is right
If I were to do it all over again I would probably still stick with the Tein-S springs with the Tokico Illuminas but I would be smart enough to turn down the stiffness a bit and perhaps modify the bump stops.
That's my .02 cents. Okay, it was more like .25 cents
26psi is offline   Reply With Quote
Old 08-11-2011, 10:35 AM   #18
Abflug
Abflug's Avatar
Drives: MR2
Thank you for your comments!
I think I can´t go wrong with oem j-spec bilstein shocks and the eibach pro kit!
Any MR2 owners here? MF_DEUCE Scion FR-S / Toyota 86 GT86 General Forum 31 12-06-2012 12:24 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 09:22 PM
any other Mazda rx7 owners here? millertime Other Vehicles & General Automotive Discussions 12 05-26-2011 08:51 PM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 01:51 AM
Stock suspension adjustability? #87 Scion FR-S / Toyota 86 GT86 General Forum 4 01-02-2010 05:36 PM
