#29 |
Drives: Jaguar X-Type
Just get snow tires on steelies and you'll be fine. It won't look as nice, but no car looks nice after a snow storm. xD
#30 |
Snow Don't Hurt!
Whoring out, but also on-topic!!!
![]() Say goodbye to your retinas, scumbags! Mwahahahahaha!!!!! |
#31 |
Drives: 2013 Subaru BRZ
^ LOL, hideous but effective.
Just got my Legacy GT re-insured for the winter! BRZ will be summoned to the garage shortly. |
#32 |
Drives: 2013 WRB BRZ Premium 6MT
What's the big deal with mounting 17" snow tires on the stock wheels? That's what I'm doing.
#33 |
Snow Don't Hurt!
Money. I got the steelies with studded Hankook iPikes for $280 (I'm sure you can tell). Next paycheck I'm getting Sparco RTT524's 18x8 +48, then Blizzak WS70's 235/40R18. In between I'll be getting Clear Bra, so not sure how quickly I'll get the new snow tires, but they're coming. The steelies are VERY temporary.
#34 |
Drives: SWP BRZ LTD
#35 | |
Drives: SWP BRZ LTD
#36 |
Drives: Acura RSX
I thought a bunch of people bragging about ability to drive manual is annoying but then I came to this thread and saw rain masters!
#37 | |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I won't be driving my BRZ in the rain, on purpose. I'm sure it's fine, and I've driven plenty of RWD cars in the rain and snow - but AWD does spoil you. Plus, it's the OTHER drivers you gotta worry about more in the rain, so I like the idea of my BRZ stationed safely garaged. |
#38 |
Btw - remember, in a skid, steer in the direction you want to go! This works for all skids - understeer, oversteer, and 4wheel drifts.
Understeer (most likely in fwd) - you're turning the wheel but the car isn't turning as much as you need. Turn MORE (and slow down) in the same direction. Oversteer (most likely in RWD) - you're turning the wheel and the car turns more than you wanted. Turn the wheel back the other way. 4wheel drift (more common in some AWD) - the car is at the proper angle for the turn, but is losing traction and sliding through it. Just keep the wheel where you have it, and yell "wheeeee!". Lifting off the gas usually brings the car back under control quickly. So, in the rain - you may enter a turn a little too fast, not get that initial bite and understeer towards the outside of the turn. That ok. Less gas, and a little more steering in the same direction you were turning. Just point those wheels where you want the car to go. Ok, now the front bites but you've lifted a bit off the gas, weight shifts forwards, and now the rears lose traction - again heading for the outside of the turn. This time you counter steer (turn the wheel in the opposite direction). But you're still pointing the wheels where you want to go. In a bad moment, you could start with understeer, correct for it and experience oversteer, correct for that but lift too much and get snap oversteer in the opposite direction (ie over correct), and need to turn the wheel back the other way. But no matter which way that back end is sliding, just keep pointing the front tires to where you want to go. And for the inexperienced, this all happens FAST. You could understeer, then oversteer, the over correct, then turn it back in all in one or two seconds. The smoother you go, the better, but that doesnt mean to react slowly. Kinda tricky to explain. Fwd drivers who understeer usually just need to give it less gas and do nothing else and the car regains control. RWD takes a little more work. (on the "fun scale", RWD slides are the best - right there at near full opposite lock where you steer the car with your throttle inputs. AWD drifts are fun too. Again, steering how tight or wide you want to go by your throttle inputs but after initial turn in, your steering wheel is straight. Fwd slides just suck - that's when you pull the hand brake to initiate an oversteer and then you're steering the car with the rear brakes.) |
#39 |
Drives: 2010 Cooper S, 74 Beetle
My reason to buy a GT86/BRZ is because of wet conditions and snow. So much fun!
If if was dry and tons of grip all the dime I would not bother with a car that was fun to drive on and above the limit. Buy some proper winter tires, and start by learning car control on empty parking lot in snowy conditions... |
#40 | |
Site Moderator
Drives: Stuff
The proper thing to do with understeer is to REDUCE steering angle, get traction, slow down, then increase steering angle to complete the turn.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#41 | |
While the idea is to regain traction, and your method certainly would do that quickest - driving straight off the road with full traction is less desirable than skidding through a turn and keeping it on the road. Online (Forza) racing, in fwd if you start to understeer on the track, you can usually just lift a bit until you scrub off enough speed to regain traction. As you leave the racing line (or your lane on the street) during understeer, the amount you have to turn to get back increases anyways - so you'll have to increase the amount you turn the wheel at some point. The point being though that you keep turning in the same direction as before. Where-as in oversteer you turn the wheel in the opposite direction. It almost comes naturally once you have a little wheel time in fwd and RWD, but for people with 100% experience in one type of layout, the reaction needed may be foreign. (or not realize just how quick that back end can swing out 90 degrees! It's tougher to understeer 90 degrees in a 45 degree turn.) |
#42 |
Site Moderator
Drives: Stuff
Oh I didn't realize we were talking forza dynamics.
![]() In reality, if you've exceeded traction turning more simply won't help (well not efficiently, sure it will cause more tire scrub which will slow the car until traction is regained). Turning more will NOT make it more likely to regain traction in less space than doing it correctly. Lift if you want (which depending on car setup can cause a spin instead, try that in my ITR for example and you won't have to worry about understeer anymore). Otherwise, the best, quickest and safest method is a quick reduction in steering angle, slow down, then add steering back in - assuming it's badly understeering. If it's just a slight understeer, gently easing off the throttle will often correct it by itself. If you are close enough to go off road or hit a curb you are certainly going to do that anyways if you use the turn more and understeer more method you are suggesting to people. Yes, after slowing down you will have to increase steering angle again, the difference is that you are now within the traction circle - instead of outside of it. This is one of the first things taught at autocross schools because the turn more and slide more method is so common with novice autocrossers. You are correct that with experience the actions taken become natural, unfortunately that doesn't mean the CORRECT actions are what becomes natural. One of our co drivers has never had to correct his bad habits so once we switched to a different setup which requires more proper inputs, he has wrecked the race car more than once...
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 10-22-2012 at 11:22 AM. Reason: Added more detail |
| First time drifting | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 08-21-2012 01:47 PM |
| About time | Touge_ninja | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-21-2012 05:08 AM |
| Wait time | veuxx | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-09-2012 01:45 PM |
| Shipping Time? | zex | CANADA | 6 | 06-06-2012 01:16 AM |
