Old 10-17-2012, 06:58 PM   #15
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
I took it to the dealer to have the rattles addressed, they said they didn't notice anything after inspection. They obviously didn't inspect anything because after I left I heard the rattles from my door panel instantly. I found the rattles are coming from the window control switches. Going back to show them. I don't turn the stereo on anymore because it's too annoying to hear buzz and rattles over the music. I never go over 30 on volume. The noises are there with bass down, sub level down, and volume at 15! I even switch it from FEEL to HEAR to NATURAL,,,rattles constantly! I also have it set up for the FR-S,,,,,they come setup for a TC from factory! Turn stereo off, push and hold the main knob down, now you can control car type, sub level, and enter a personal start up text.
chrisbfrs is offline   Reply With Quote
Old 10-17-2012, 11:18 PM   #16
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
I think that set to "feel" with the bass on 2 and the volume at 20 is blasting the bass on this thing. It's a standard car stereo, not a custom billion watt thumper.
But then again I'm an old fart who listens to mostly classical music.
cwb48 is offline   Reply With Quote
Old 10-17-2012, 11:39 PM   #17
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Originally Posted by Xanatos View Post
Yup! All speakers and headphones have a break-in period. They don't produce their true sound quality until their broken in.
lol
All I ever listen to is POTUS and NPR talk radio at levels just high enough to comfortably listen to, and after trying to listen to some music after a few weeks I got plenty of rattle out of that speaker.
Jar is offline   Reply With Quote
Old 10-18-2012, 12:41 AM   #18
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Originally Posted by Hotlava86 View Post
So i have had my FR-S for about 2 months now. Within the first 48 of owning the car my passenger speaker blew out (or at least sounded like it had). I took it to the dealership a week or so later showed the tech the problem, he instantly said that yes the speaker was in fact blown and would be replaced under warranty. A week later the replacement speaker came in and they replaced it. Well now less than 2 days later the EXACT same speaker is blown out again.
I am talking about the door speaker on the passengers side.
EQ settings are moderate at best. Bass 2, treble 3, fade and balance set to Middle, ASR high rate, ASL medium, SSR feel, interface USB, mode FR-S.
So i am not BLASTING bass through them. The volume is typically around 25-30 on the highway and 20-25 in the city.
So today i will be discussing with the dealership about upgrading my base system to the premium system for free because of the hassel.
I feel as if the problem is in the Amp or the wiring. What do you guys think?
Try this turn off the radio hold the big round mode button in for a few seconds a menu will come up check to make sure the car type says FR-S it is set to TC stock and the TC has more speakers and could be sending to much power to yours.
Old 10-18-2012, 12:54 AM   #19
Blackbeltmma
Drives: Raven Black FRS
LOL - I put a 1000 watt stereo system with 2-10" subs in the trunk. The entire car ignites when I pump it. I put rubber pads under my licence plate to slow down the rattling.
Nothing like driving on a twisty road, with extreme bass pumping.
Thats one minor reason I call my car, "Therapy."
Raven Frs
I call this car "Therapy"
Happy driving.
Blackbeltmma is offline   Reply With Quote
Old 10-18-2012, 04:06 PM   #20
RossGA
Drives: Audi S4
A bad amplifier can destroy a speaker.
A failing amplifier can send all kinds of DC garbage and pulses to the speaker that can damage the mechanical structure of the speaker, or warp the coil by heating.
If a speaker goes bad and is replaced by a new speaker which also goes bad, almost always will find the amplifier is malfunctioning and torching the speaker. It may not be producing audible sounds while doing this, in fact it may sound somewhat normal. Esp if the amplifier is DC coupling the speaker....you won't hear the damaging current at all...but the amp and the speaker coil will both be getting pretty hot.
RossGA is offline   Reply With Quote
Speaker Sizes Thefuzz Electronics | Audio | NAV | Infotainment 68 05-28-2021 07:18 PM
Rattle-ly Speaker Door Panels engee Cosmetic Modification (Interior/Exterior/Lighting) 45 11-25-2014 08:45 AM
Speaker help! KRAZYK Electronics | Audio | NAV | Infotainment 0 08-02-2012 09:54 AM
Popped up dashboard speaker grill Laika BRZ First-Gen (2012+) — General Topics 8 06-21-2012 12:35 AM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 05:43 AM
