Old 09-23-2012, 08:26 PM   #15
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
there's also 7.5 +40 ce28's/le28s
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-24-2012, 05:15 PM   #16
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Based on the response that @switchlanez got I am updating the topic title and the Wheel Directory to this: Volk Racing CE28 17x8.0 +38
Old 09-27-2012, 01:19 AM   #17
ayau
Drives: Some rust bucket
Originally Posted by switchlanez View Post
@ayau I got a response:
thank you so much! for some reason, i didn't get the notification saying that you responded.
isn't 17x8 a little wide on 215 tires? maybe they wanted the stiffest sidewall and went with skinnier tires?
Old 10-12-2012, 11:41 AM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Bump for an answer to this. I know a 215 would be a bit stretched but it would be fine right? I'm have new wheels (17 x 8 et38) but don't have extra room to store the stock tires and I don't want them to go to waste. Could I run the stock tires til I burn them up and van slap on the 225s I want?
Old 10-12-2012, 12:13 PM   #19
ayau
i did a little research on ideal tire and wheel sizes after asking that question.
in general, you want to match the wheel width to the tire tread width. each tire will have a different tread width. for example, a bridgestone re11 215/45/17 has a tread width of 8'', and the OEM 215/46/17 michelin primacy tire has a tread width of 7.5''. as you can see, both tires have the same specifications, but they have different tread widths.
if you look at pictures of the re11, you'll be able to see that the shoulders are much more squared vs. the OEM. this just shows that even though they have the same specification, they're made to accomodate different wheel sizes.
for you, fitting 8'' wheels on the OEM tires will give it a more stretched look than the RE11. you can find the tire tread widths on tirerack.com. hope that helps.
Old 11-17-2013, 09:25 PM   #20
fooyc
fooyc's Avatar
Drives: GT86-JDM
Stock suspension. tires: 235/45R17.
fooyc is offline   Reply With Quote
Old 05-27-2014, 09:15 PM   #21
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
New Wheels!
I got bored of my OZ wheels and wanted to go lighter. I found this unicorn rim. Custom diamond black powdercoat. 33 pounds with Dunlop Sport Maxx RT 225/45/17 tires. Saved another 1.6 pounds per corner over my last setup which was -5.4 pounds per corner vs. stock already.
industrial is offline   Reply With Quote
Old 07-08-2015, 10:05 PM   #22
Premium 615
Premium 615's Avatar
Drives: '15 BRZ Limited
33 lbs
Premium 615 is offline   Reply With Quote
Wheel Directory: Volk Racing CE28 18x8.5 +44 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 73 07-24-2015 06:02 PM
Wheel Directory: Advan RG-D 18x8.0 +45 wtf.bbq Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 09-11-2013 06:36 AM
Wheel Directory: ESM 004 18x8.0 +40 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 06-13-2013 03:43 PM
Will 18x8.5 +35 Fit all around? wootloops Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-06-2013 07:58 AM
WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** RavSpec Wheels and Tires 59 07-24-2012 01:07 PM
