| NY / NJ / CT / PA NY, NJ, CT, PA |
#29 |
Drives: Asphalt Scion FR-S
if temp really starts to drop and snow is around the corner, waxing my car cleaning it up and putting her in the garage lol.
#30 | |
-Mike Paisan ![]() 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#31 | |
#32 |
Drives: '13 Asphalt FRS 6MT
I just bought a set of TC rims to use on my frs this winter, because i got a killer deal on CL. I took the gamble cause I'm fairly sure the offset will not be an issue, same size wheel, same size tire BUT the TC wheel uses mag style lug nuts. I didnt notice till I got home and am kicking myself, So I will report back but it my understanding that if the wheel is not hub centric it won't work, to top it off the TC lug nuts are 12-1.5 and frs is 12-1.25 so to test it I need to buy new lugs.
#33 | |
Hail Magnet
#34 |
TC lugs are the wrong pitch (1.5 vs 1.25) so they won't work. Looks like mine will be back up for sale, from what I've read the tc wheel has a 54.1mm bore while the frs has a 56mm hub, and I'm no sure machining them out 2mm is cost effective. Can't measure till I get home later tonight but ill report back once I do.
#35 | |
Hail Magnet
And anyone else know about this? Winter seems to be suddenly becoming much more annoying for me...
#36 | |
Just got a chance to measure the bores and tried to test fit, they will not work, as stated before the wheels have a small 54.1mm bore which won't fit over the 56mm FR-S hub. I'm sure they could be machined out but its not worth the hassle for me and they were cheap enough so I should be able to actually make some money off of it. Damn shame too cause they look really nice. Anyone in the NJ area want some cheap TC wheels? haha Mike - I'll be watching out for your sale! And I'm local! |
#37 | |
Hail Magnet
#38 |
#1362
Drives: 2014 Ice Silver WRX
starting to get pretty chilly. when are you guys planning to swap tires?
#39 | |
#40 | |
Hail Magnet
The trick is that you don't want to be driving on snows that much in warmer temperatures, because the rubber is softer than your stockies/summer tires and will wear out more quickly. |
#41 |
SLO NO MO
Summer Performance Tires aren't really designed for use below 50 degrees Fahrenheit, so whenever your region starts to see temperatures drop below 50F during your normal commute, I'd consider putting the winters on.
We started to drop below 50 here in NY this past week, so I'll be swapping out this weekend. |
#42 | |
#1362
also i noticed that you're a DGM BRZ on LI. i may have seen you pass by on stewart this past saturday.
| Let's see your computer setup! | Hanakuso | Off-Topic Lounge [WARNING: NO POLITICS] | 79 | 11-06-2022 11:43 AM |
| Brz Drag Setup | Tansey86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-12-2012 11:24 AM |
| Offset help for staggered setup | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-24-2012 01:46 PM |
| Audio setup | 315FR-S | Electronics | Audio | NAV | Infotainment | 20 | 05-17-2012 06:23 PM |
| 2 car setup...feasible? | mankarn86 | CANADA | 3 | 03-30-2012 02:00 AM |
