Drives: 2013 Scion FRS
Removing Intake Silencer
Has anyone tried this? My friends at a meet disconnected my intake to see what it sounded like. One mentioned removing the silencer from the intake.
#2 |
Drives: 2013 Raven FR-S
Edit: holy crap i cant read
what silencer are you referring to? and do you have a turbo? Last edited by Ravenlokk; 09-23-2012 at 02:36 AM. Reason: im a dumbass |
#3 |
Drives: 2013 BRZ Limited
I've removed it and plugged up the opening. Unfortunately there was no major sound difference.
#4 |
I'm not talking about the sound tube. Apparently theres a silencer under the intake box or somewhere around there. Idk A guy was just talking about it.. and no my frs is N/A
#5 |
Assuming OP is referring to this. And I'm not sure. Got the AIRAID box personally, and love it. Plus the price is great- especially with the $50 rebate!
#6 |
That Guy
Drives: 2013 asphalt FRS MT
I'm pretty sure the OP is referring to chamber the projects downward ~90 to where the sound tube comes off. Yes people have removed it. No we don't have anything that's 100% concrete about it's effects. Perrin posted gains of 0 hp when they tested it out. Some have reported no issues, others are reporting issues at high load and low rpm. YMMV
#7 |
Drives: 2013 Subaru BRZ
I removed that and the sound tube, no difference but a cleaner engine bay really.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#8 |
Drives: 2014 SWP 6MT BRZ
Why is this in the Forced Induction forum???
#9 |
Drives: 2003 Subaru Outback
#10 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Removing the intake silencers can cause issues with the MAF reading the incoming air. One job of the silencers is to counteract resonance from the engine that causes the air in the intake pathway to vibrate. These vibrations can cause the MAF to mis-read the air passing through it. Best to leave them on just in case.
#11 |
Re-member
Drives: Toyota camry
Yeah leave it on. Google a video of Ferraris new v12. That engine has these weird looking tubes sticking out from the intake for each cylinder bank. They function similarly to the box you have removed in that they aid intake harmonics. The volume of the box on our car is very carefully calculated. It may be there to alter the engine note, but it also likely plays a role in helping the intake cram as much air as possible into the engine. Some engines actually achieve a small supercharging effect from a properly tuned intake.
Nothing decays like progress, and nothing preserves like neglect.
| The Following User Says Thank You to ahausheer For This Useful Post: | ddevl_86 (03-30-2021) |
#12 |
Well I dont see where removing the silencer (a hollow box) would make much more of a difference than changing to a short ram intake as far as air flow goes. I ended up removing it and it actually sounds good. It gives the engine a more growly note when I really get on it. I'm eventually going to get a sri but this is cool for a while.
#13 | |
Scrape Master
Drives: Goal: Oldest FRS State Side
#14 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
what does this have to do with boost?
| The Following User Says Thank You to jdzumwalt For This Useful Post: | usptwins (09-27-2012) |
| Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete | GrimmSpeed | DIY (Do-It-Yourself) Guides | 99 | 01-25-2015 01:24 AM |
| JDM 86 Rear Seat Silencer | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 12-01-2012 09:33 PM |
| Removing decals | sa1126 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 07-12-2012 12:48 PM |
| Removing pinstriping | Zxtole | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 06-10-2012 08:12 PM |
| Removing the 86 badge on the front of the car | Pake1 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-10-2012 08:37 AM |
