Old 09-07-2012, 01:43 PM   #29
Turbowned
Turbowned's Avatar
Hey, it could be worse; Mercedes-Benzes have a left-to-right motion to change gears with the manual mode... you wanna talk about counter-intuitive? I don't know what they were thinking. Never much cared for M-B anyway...
Old 09-07-2012, 01:58 PM   #30
Kurenai
Drives: 2013 Scion FR-S Hot Lava 6AT
I too would like to know if a way of swapping up/down shift is found...
I found + towards driver very intuitive on my MR2-Spyder... and I keep doing it wrong on my FR-S..
.. I kinda feel like James May and the dogleg 1st gear when i do it.
Kurenai is offline   Reply With Quote
The Following User Says Thank You to Kurenai For This Useful Post:
Laika (09-07-2012)
Old 09-17-2012, 11:19 AM   #31
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Fixed..
http://www.ft86club.com/forums/showthread.php?t=17018
01s0uljah is offline   Reply With Quote
Old 09-17-2012, 05:41 PM   #32
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by arghx7 View Post
It could be done if you reprogrammed one or more of the control modules. Or maybe if you repinned an electrical connector.
Why is it like that in the first place? It's probably because that's what their customer clinics told them the expected buyer wanted. Or maybe they didn't bother doing any evaluations. Nobody actually uses manual shifting functions on a regular basis. They try it out a couple times and then forget about it.
A lot of people on this forum only drive in manual mode everyday...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 09-18-2012, 01:38 AM   #33
Azzaboynt
Azzaboynt's Avatar
Drives: Red 86 GTS Auto
Ummm.... If you were in a stick shift car, then under braking you will be both pulling and pushing the stick as you go down the gears...
It would be nice though if there was a standard for the autos across all manufacturers and models. Makes the transition to new cars a lot eaiser.
Point in case, yesterday I had to jump in and out multiple times and drive a VW polo, and a Toyota Corolla. Given that the indicators for each car was on the opposite sides to each other, it was a pain in the azz. Towards the end of the day I figured it was just easier when I needed to indicate, to hit both left and right hand stalks. Indicating to turn with wipers...
Current drive: 2012 Toyota 86 GTS
Azzaboynt is offline   Reply With Quote
Old 10-02-2012, 04:24 AM   #34
Allankh
Akaytch
Drives: TSX, tC2(sold), FRS(waiting)
Instead of swapping the wires or reprogramming the ECU
Try to reprogram you're brain, it's cheaper, faster... and easier
Allankh is offline   Reply With Quote
Old 10-02-2012, 01:50 PM   #35
SkullWorks
Drives: SSM LT MT BRZ
a couple of things.
this is an AUTOMATIC you are talking about, it is not related in any way shape of form to a sequential roller barrel actuated race box, please remove all such thoughts from your head.
YOU ARE WRONG...let that sink in....better than 75% of all auto boxes are forward to shift....as are most upshifts in what has been standard for years....the 5 speed h pattern gearbox...1st UP 3rd UP 5th UP...only second and fourth are down,,,,in down shifting it is a split...
Automatics have been manually selectable for some time with the standard
P
R
N
D
3
2
1
pattern...and since you are driving an automatic...not a manual....it makes far more sense to maintain this same pattern...because this is a street car,
if you want a reverse manual selection, switch the wires and be done with it,
if you want a manual transmission....well....you paid extra for an auto...so obviously you didn't...
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Do you think FT-86 will have automatic? TRD Engine, Exhaust, Transmission 217 08-03-2013 09:36 AM
Red Automatic FRS available BRZ88 NY / NJ / CT / PA 0 06-01-2012 12:04 PM
automatic pdf :D enjoy carbonBLUE Engine, Exhaust, Transmission 4 04-26-2012 11:17 PM
Anyone Else Considering an Automatic FR-S? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 410 02-16-2012 12:41 PM
