Old 09-17-2012, 09:16 AM   #71
Visconti
Drives: 05 STi
Originally Posted by gmookher View Post
cant you tune that out with higher octane? would love to see a medley of maps
Haven't had the need to do that just yet.
Visconti is offline   Reply With Quote
Old 09-17-2012, 03:41 PM   #72
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Out of curiosity, what were the mileage numbers on these before and after dynos and did any of you reset the stock ECU prior to making your stock ECU Pulls?
This is the reason I ask - these dyno pulls are ALL on the same completely stock FR-S, the lowest beign 250 miles w/o reset and the highest being 8000 miles w/ ecu reset. Your stock numbers all look a lot like what my car was back at 250 miles. It has picked up quite a lot through break-in alone, and more through a simple ecu reset.
For additional clarity these runs are back to back with the only difference being an ECU reset that brought the power up to the 178 mark:
My thinking is that to have apples to apples you should always test them all after a reset and at the same mileage. (One would assume that a reflash resets the ECU memory).
Boosted2.0 is offline   Reply With Quote
The Following 2 Users Say Thank You to Boosted2.0 For This Useful Post:
bedabi (06-18-2013), rice_classic (09-17-2012)
Old 09-17-2012, 03:43 PM   #73
Visconti
Drives: 05 STi
I'm assuming it was all done on the same day
Old 09-17-2012, 04:02 PM   #74
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Easy button on resetting the ECU? Disconnect battery or pull a fuse? Or both?
Old 09-17-2012, 04:47 PM   #75
Boosted2.0
Boosted2.0's Avatar
Just disconnect the battery for 5 minutes or so.
Old 09-17-2012, 05:57 PM   #76
AJUSA.com
AJUSA.com's Avatar
Dyno tests are not the end all be all.
These for example show the opposite of what is being claimed in this thread.
Originally Posted by t14abrunson View Post
Run 2(Red) - Stock
Run 12(Blue) - Tune Only (ECUTek)
Run 19(Green) - Tune w/ Catback Exhaust (Perrin)
Run 27(Purple) - Tune w/ Catback Exhaust & Intake (Perrin/Injen)
AJUSA.com is offline   Reply With Quote
The Following User Says Thank You to AJUSA.com For This Useful Post:
2forme (09-17-2012)
Old 09-17-2012, 06:24 PM   #77
2forme
Exactly my point. I'd love to have every ounce of power as possible, but not at the cost of risky AFR.
Out of curiosity...which tune did you guys use for this?
Old 09-17-2012, 06:32 PM   #78
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
The stock dyno was around 1k in mileage. The non stock was dynoed around 6k.
Also I am not claiming anything, I am just merely presenting the data we logged during the dyno runs. Also that is a different car with a different environment, with a different intake, and a different exhaust. Can't compare those apples to apples
mechaghost is offline   Reply With Quote
Old 09-17-2012, 07:20 PM   #79
AJUSA.com
AJUSA.com's Avatar
I was just quoting another user in that post. Not sure what tune is being used.
Old 09-17-2012, 08:02 PM   #80
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
I thought it to be odd too, so for good measure, like any test should be, I put this on MY 6MT FRS, STOCK OEM ECU just to see what it did...
Here are the results in 3rd & 4th.
Perhaps the OP's hardware is faulty? But 2 different cars with similar results, one @ 6000 miles while the other @ 5000 miles. Note that the baseline used was done a few days earlier when I tested another intake.
Just posting my findings.
Regards,
Drift-Office is offline   Reply With Quote
Old 09-17-2012, 08:07 PM   #81
jeebus
Regards,
so you lost 8 peak HP with the AR intake and gained 1-2HP in the middle? to these intakes.
jeebus is offline   Reply With Quote
Old 09-17-2012, 08:09 PM   #82
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I haven't been impressed with the dyno sheet of the AirRaid or Injen intakes, just put the $300 towards the E85 tune
Old 09-17-2012, 08:24 PM   #83
AJUSA.com
AJUSA.com's Avatar
Would be interesting to see what the car was dynoing at after putting a 1000 miles on it with the intake once it had time to "get used to". Dyno tests as you can see vary by almost 11HP on stock cars. Regardless, all of the intakes we have tested have increased g's and airflow. If that does anything on a stock car? But with a tune there is an obvious increase in power over the stock intake.
Old 09-17-2012, 08:44 PM   #84
Drift-Office
Not sure about the OP, but here's my recorded runs from the time I drove the 2 miles to get to my dyno from the dealer's lot to my 1000 mile break in to the recent 5000 mile mark before conducting this series of intake tests... AFRs on the brand new car are richer of course but there wasn't much appreciable difference between the 1000 - 5000 mark, after it "got used to" the driving...
Regards,
The Following User Says Thank You to Drift-Office For This Useful Post:
AJUSA.com (09-17-2012)
In Annapolis for the weekend - Get your Visconti Tune! Visconti Mid-Atlantic 6 09-16-2012 11:10 AM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 05:04 AM
A Question for Those of You WITH the Visconti Tune White64Goat Engine, Exhaust, Transmission 22 09-02-2012 06:27 PM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 08:02 PM
1st Auto with Visconti E85 tune! white devil Engine, Exhaust, Transmission 35 08-22-2012 05:22 PM
