Old 09-13-2012, 06:29 PM   #29
tjdiz92
Drives: 2013 Argento FR-S MT
I shift too hard lmao idk man. Maybe my sound system installer maybe messe it up or whoever installed my HIDS. But all seems well so far. Going to do a drive cycle and see if my CEL comes on.
2013 Argento Scion FR-S M/T 15% tint-6k HID headlights-6k HID blinker Switch backs-LED domelight-LED reverse lights-LED license plate light-Gloss black roof-Hertz audio components w/ 2 10 inch kicker L'3s.
tjdiz92 is offline   Reply With Quote
Old 09-13-2012, 06:38 PM   #30
CBR600RR
Drives: Raven Black
Originally Posted by ATL BRZ View Post
First it was correlated to extreme bogging issues when coupled with an aftermarket intake, now the $950 Visconti tune is correlated to Check Engine Lights? Wow, scary stuff.
Lol one case of a car coincidentally having the tune and throwing a CEL and you assume that it must be due to the tune??!!??!!
Scary stuff!!!
Old 09-13-2012, 06:43 PM   #31
tjdiz92
^^ I really tried to emphasize I wasn't blaming the tune. Whatever though
Old 09-13-2012, 07:20 PM   #32
CBR600RR
Drives: Raven Black
^Ya that is what I was getting at. But ALT BRZ thinks otherwise.
The tune is not the issue here.
Old 09-14-2012, 10:45 AM   #33
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by SkullWorks View Post
[IMG][/IMG]
Correlated: To have a mutual relationship or connection, in which one thing affects another.
Check the thread title again. Correlation =/= causation. I'm giving the OP the benefit of the doubt.
Old 09-15-2012, 05:42 AM   #34
Visconti
Drives: 05 STi
Your input was very helpful in this thread - thanks !
Visconti is offline   Reply With Quote
Old 09-15-2012, 06:32 AM   #35
dura1198
dura1198's Avatar
Drives: 2015 WRX
Crazy stuff
Please update your Tune features...
What this flash does -
Raises RPM Limit
Improve Fuel Economy
Adjusts Direct Injection / Port Injection Mixture
Adjusts Caming Timing
Smooths out Wide Open Throttle Fueling
Smooths Timing table
Unplugs Traction Control
dura1198 is offline   Reply With Quote
Old 09-15-2012, 11:29 AM   #36
Visconti
Drives: 05 STi
Raises RPM Limit
Check out my thread for my STG1 flash - it's in my signature ..
John
Old 09-15-2012, 11:47 AM   #37
2forme
Originally Posted by ruskymx View Post
I think, the traction control light will come one anytime the CEL does. IIRC, every thread about the CEL coming on, also involves the TC light as well.
I got a check engine light last time I put my stock intake back on because I forgot to tighten one clamp (was in a rush). There was no traction control light. As soon as I tightened the clamp and turned the car off/on, it went away. So I don't think this is true.
Unfortunately, this is relatively impossible. CEL's happen when the ECU reads certain values from sensors. Typically, this is either an "out of bounds" value (a sensor is reporting a voltage that's not within expected spec in the ECU; e.g. cam advance problem) or a predetermined condition from multiple sensors that calculates out of spec to the ECU (One sensor reports one condition that conflicts with another sensor, both are within spec separately; e.g. My CEL. Engine was receiving a lot more air than the MAFS was reporting).
So it's highly unlikely that John's tune caused a CEL. He doesn't touch how the engine receives CELs. And I'm willing to bet the ECUTek tuning software won't allow him to run a part over spec; such as cam advancement. The only exception I can think of is RPM, of course. He can tell the ECU to let the motor rev past what it can handle, but even then. The CEL would be caused by the mechanical damage as a result.
I'm willing to bet he knows what he's doing and it sounds like there was a problem with your evap system.
Old 09-15-2012, 12:53 PM   #38
Foobar
SLO NO MO
Foobar's Avatar
John
Psst John - I think you missed the last line that he added to your STG1 description:
Old 09-15-2012, 01:50 PM   #39
Visconti
Drives: 05 STi
Oh ahahahhahHhhh
Old 09-15-2012, 02:37 PM   #40
ftc~brz
Done
Drives: WRB BRZ
Originally Posted by tjdiz92 View Post
So I was playing around with my traction control trying turn it on and It wouldn't come on. I opened up where it is and it wasn't plugged in! It's been plugged in before as I've used it but it seems to have just come out somehow. So I plugge it back in so far everything seems normal and fixed. Gonna do a drivin cycle and see if it any codes are thrown again. So if anyone gets the code p1449. Check your traction control haha. Cheers
I turn my trac and slp off....damn thing turns it's self back on and wont stay off! it's like my passenger window switch & trac button conspire against me when I'm not around.
I'm not sure if it's normal for it to just turn back on and I'm not that far into the owners manual yet. "It's a real page turner" though.
ftc~brz is offline   Reply With Quote
Old 09-15-2012, 06:41 PM   #41
tjdiz92
well the trick to keeping it off is to turn on vsc sport then press and hold traction control for like 5 seconds. That will shut it off until you turn it back on or shut off the car.
Old 09-15-2012, 06:43 PM   #42
tjdiz92
Raises RPM Limit
HAHA it wasn't the tunes fault that I'm and idiot!
Will A Tune Void My Warranty? Apex Chase Engine, Exhaust, Transmission 12 07-13-2015 02:19 PM
Visconti E85 tune + Injen Intake + Perrin pulley + stubby antenna = WICKED COOL FUN! white devil Engine, Exhaust, Transmission 31 09-29-2012 12:05 PM
A Question for Those of You WITH the Visconti Tune White64Goat Engine, Exhaust, Transmission 22 09-02-2012 06:27 PM
1st Auto with Visconti E85 tune! white devil Engine, Exhaust, Transmission 35 08-22-2012 05:22 PM
Looking for a tune?? TSLRich NY / NJ / CT / PA 0 08-01-2012 09:29 AM
