Old 08-29-2012, 04:19 AM   #57
jmaryt
Drives: 2012 honda civic ex
with the small ground clearance,you have to be concerned
about your car being "lifted" up off the road by snow packing underneath
with snow falls over 5".of course when this happens,you are '"done" call a hook!
j.t.
jmaryt is offline   Reply With Quote
Old 08-29-2012, 12:42 PM   #58
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Originally Posted by Stu baru View Post
Had the same internal debate and decided on winter rubber on stock rims come November, and wider rims and sticky rubber next April.
This is what i'm currently doing with my 3000GT. Winter tires on stock rims during winter, nice rims with high performance tires during summer.
These tires are beastly during the winter. I recommend them.
http://www.discounttiredirect.com/di...w=false&cs=225
blackfireball5 is offline   Reply With Quote
Old 08-30-2012, 03:24 AM   #59
jmaryt
what's the tread life look like on these guys? thanks!
j.t.
The Following User Says Thank You to jmaryt For This Useful Post:
Missy (11-10-2013)
Old 08-30-2012, 03:47 PM   #60
blackfireball5
j.t.
I have had my current tires for at least 4 winters i believe. Still have a bunch of tread.
Old 08-30-2012, 11:33 PM   #61
jmaryt
ok! thanks i'll look into them!
appear to be a good value!
j.t.
blackfireball5 (09-04-2012)
Old 09-04-2012, 06:20 PM   #62
blackfireball5
No problem!
Old 09-04-2012, 10:24 PM   #63
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
It will be interesting to hear stories of this car in the snow - and I'm sure countless stories of spins and of people driving through snow on the stock summer Primacy's.
As for weight in the rear - I've heard conflicting stories. With my old car and old pickup, there was like a 70/30 F/R weight distribution, so you needed 100 lb in the trunk to help. People with 50/50 BMWs and Miatas claim no need to put weight in the trunk, and that just causes the car to spin more (more weight in motion side to side).
ashtray is offline   Reply With Quote
Old 09-05-2012, 09:43 AM   #64
avp1
Drives: Traded BRZ for Supra
You do not need additional weight in the back. Just keep steering wheel straight when start moving, and be gentle on the clutch. I drove RX-8 trough seven winters and never had a problem. I do not expect BRZ to be much different.
avp1 is offline   Reply With Quote
The Following User Says Thank You to avp1 For This Useful Post:
HunterGreene (09-05-2012)
Old 09-05-2012, 12:58 PM   #65
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Additional weight over the drive wheels will certainly help.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-05-2012, 01:12 PM   #66
kramerica_industries
kramerica_industries's Avatar
Drives: 2013 Ultramarine FR-S
I definitely plan to get a set of winter tires for Chicagoland. I'm VERY curious to see how it handles in snow, slush, and ice.
From 2006-08 I drove a 6MT IS250 in Iowa winters on factory all season tires. The balance on that car I believe was right about 57/43 front/rear. After it snowed the first winter I had it I ended up putting two 75lb sand bags in the trunk, wedged all the way up right behind the rear seat and secured with straps to keep the weight planted over the rear wheels and to prevent shifting. That car was a TANK in the snow, never ever once got stuck or worried about traction. But that car was over 600 lbs heavier even before I added the sand bags. I'm hoping that just snow tires will suffice for the FR-S, otherwise I might put a single sand bag over the rear tires to see how that works.
In any event, I imagine our cars will be wicked fun in the snow!
kramerica_industries is offline   Reply With Quote
The Following User Says Thank You to kramerica_industries For This Useful Post:
ill86 (09-05-2012)
Old 09-05-2012, 01:31 PM   #67
JWA
Drives: BRZ, Exige, Boxster
Yep. It makes a difference on a truck where there is no weight in back, but on a reasonably balanced car all you're doing is adding momentum to lateral motion. I've driven Miatas, an M Coupe, two Boxsters, and other modern sports cars through Milwaukee winters with Performance Winter tires and nothing else. Heck, my mom drives a MT Miata PRHT with Blizzaks and she's fine.
This thing will be fun in the winter with decent tires. I'm looking forward to it.
JWA is offline   Reply With Quote
Old 09-05-2012, 01:49 PM   #68
HunterGreene
Hail Magnet
HunterGreene's Avatar
On the other hand, you could tie a sandbag to the hood, over the axle, and then strap down another in the trunk. That would keep the close weight distribution, right?
Old 09-05-2012, 01:57 PM   #69
Lytheum
Drives: 2013 BRZ Premium 6MT
i cant decide between performance snow or studless snow/ice tires. learning towards the performance snow ones, just worried they wont be much better then all season. ive used the studless the last 4 or 5 and great while snowing they suck the rest of the time.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 09-05-2012, 02:01 PM   #70
HunterGreene
Hail Magnet
Being we are from the same area, I'm sure you know that studded snow tires are illegal on the roads in Ohio. I didn't read that from your post, just wanted to make sure it was out there.
I have ContiWinterContact TS810 S (the performance Winter/snow tires) that I used on the tC for the past three years that worked wonderfully. I plan on using them on the FR-S as well.
Rustproofing for Winter blackfireball5 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 28 11-12-2012 11:33 PM
Its not winter, but can hail do this to the car?? tbala FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 08-17-2012 01:36 AM
winter driving paraguin BRZ First-Gen (2012+) — General Topics 25 08-03-2012 06:26 PM
For the winter brichard0625 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-30-2012 05:16 PM
BRZ/FR-S and winter driving: Watch this video if you have any concerns! Turbowned BRZ First-Gen (2012+) — General Topics 53 07-16-2012 12:29 AM
