#71 | |
Radio wiring harness guru
Drives: 1996 SVX L AWD
These terminals and pins are so small, there's almost no tolerance for anything to be out of place.
#72 | |
SLO NO MO
Sent from my Galaxy Nexus using Tapatalk 2 |
#73 | |
In addition, you can have video with your aux audio by adding another RCA jack to the empty slots on the 28-pin harness (pins 13 and 14).
#74 |
SLO NO MO
OK, until I receive SVXdc's RCA -> Tyco pins to plug into the stock harness, I just ghetto engineered a solution for now just to show proof of concept.
BOYO Ultra Slim license plate camera installed: ![]() Close-up of how I routed the wiring up through the license plate light opening: ![]() End-result on head unit:
#75 |
Drives: 2013 BRZ Limited
Looks really good. Anyone suggest a tiny (non license plate mounted) camera with single cord with power (I'll run it up and tap the dash radio + line)?
#76 |
Drives: 2013 Subaru BRZ
I used the Rydeen Miny camera, sounds like exactly what you want but im not sure where you could get one other than a retailer.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#77 | |
SLO NO MO
I have the BRZ Limited, so I didn't have that space above the license plate to mount one of these (the trunk release button is there). Since I wanted to keep a centered camera, the ultra slim license plate camera was the only real option for me. It's pretty stealth though, and while my closeup shows the wire visibly, it's actually black and only shows a little bit on the upper right corner. No problem for a black or gray car, anything else, however, you'll definitely notice it. |
#78 |
Drives: 2016 Toyota 4Runner Trail Premium
OK, I just ordered the Rydeen Mobile ZH07-150B from eBay and the RCA w\pins from SVXdc. Assuming everything goes well with the eBay order I should have a factory looking setup for around $160. Considering I paid $180 for the Homelink mirror this seems like a good value to me.
#79 | |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
#80 |
SLO NO MO
I saw little difference between my BOYO Ultra Slim and the $12 Chinese generic camera. The Chinese generic one was plastic and allowed moisture to build up on the lens though, whereas the BOYO is metal and watertight. A lot smaller too, if you didn't know it was there, you'd miss it as just a license plate holder. The $12 one was a major eye sore, sticking out like my car was a borg or something.
#81 |
Long term durability is definitely something to consider with these cameras. Its an electronic part that sits outside of your vehicle through the elements. Might as well just buy a nice one and know its not gonna break.
Build Thread:
#82 | |
![]() I've got one of those cheap home camera systems, 4 not so great camera's outside. Have lasted 4 Wyoming winters so far, even the crappy ones last, unless they fail right away.
#83 |
Drives: 16 Impreza 5dr CWP
So do we have a plug and play harness available yet? Is SVXdc's wiring available?
I'd really like to use the OEM camera with a plug and play harness set-up. I'm trying to figure out how to get the JDM trunk trim piece with the knockout already in place for the OEM camera. |
#84 | |
Build Thread:
| What will you hang from your rear view mirror? | Dillano609 | Scion FR-S / Toyota 86 GT86 General Forum | 148 | 11-15-2013 02:52 PM |
| Zoom Engineering Rear View Mirrors | Kami Speed | Interior Parts (Incl. Lighting) | 13 | 07-17-2012 02:18 PM |
| Taking rear view mirror off ? | JB1 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-21-2012 09:53 AM |
| Rear view Mirror pic | nixeighty6 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 45 | 01-27-2012 05:10 PM |
