#295 |
Vtec Jesus
No love down under.
#296 |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
#297 | |
Drives: 05 Ford F150 Scrow
So I will be ok with the 10psi kit. What is the safest HP I can run and what will be the torque for that. I am planning to get my Toyota 86 Auto in a year. Can’t afford it now. Just bout a house . Hopefully be then Toyota and Subaru would have fixed any issues with the car. And will see how reliable the boosted car & transition are.Plus will see what other options will be there. One more questions, what is the power numbers (HP & Torque) on the NA tune? Thanks in advance. |
#298 |
Toyota Soul
Drives: 96 taco
^^ about 30 or so whp with just the n/a tune. Great tune.
No replacement for Displacement??? Tell that to the people with a 2JZ.
| The Following User Says Thank You to usptwins For This Useful Post: | Shiny (08-30-2012) |
#299 |
So that will be about 200 WHP. What about torque?
#300 |
Drives: '06 AM V8V Coupe
Peak torque given peak power just tells you how inefficient the setup is at high rpm :P
But seriously, look at the threads where they compare the tuned and stock torque curves, basically you gain a significant amount at high rpm where the engine is running very rich stock, and a moderate amount in the low to mid range. Aka, no massive kick in the pants. |
| The Following User Says Thank You to serialk11r For This Useful Post: | usptwins (08-30-2012) |
#301 |
Toyota Soul
Drives: 96 taco
Itll be about 193whp or so, if you look in the first couple of pages, it will show you. Or look at the Visconti flash thread
#303 |
Drives: DGM BRZ Limited
Just curious if you guys can enlighten me... How does the response of these turbo setups stack up against lower compression setups? How would you compare the response of the disco and the GT30r?
I'd like to hear some perspective and impressions of how the turbo responds on this engine. The dyno only shows the power output. Obviously the larger turbo is going to loose response, but when do you feel the boost is hitting hard and the throttle response is good? I've never had a 12.5:1 compression turbo motor build before. I'd imagine that E85 and turbo would work amazing with this compression. Your thoughts gentlemen? |
| The Following 2 Users Say Thank You to Coheed For This Useful Post: | Deepseadiver (08-31-2012), TouchMyHonda (08-31-2012) |
#304 |
Drives: '13 BRZ | '04 E55
Higher compression would result in faster spool time and better out of boost response.
E85 would be a must in my opinion with any real boost. Sure the direct injection will help keep things cooler than solely port injection, but your just asking for trouble with 12.5:1 and 15+psi on pump gas...which is why I'd imagine they switched to e85 for the 400 build. That and timing.
#305 | |
Every subaru I've driven has been pretty unresponsive compared to inline-4 setups because of the long exhaust runners. That's why I'm so curious how this engine responds. I think 330whp is a riot in a 2800lb car. More power is really good too, but this car gets a ton of praise for its responsiveness, I wouldn't want to muddy that. Plus, another 100whp is only a turbo swap away with simple upgrades. |
#306 |
Drives: Past S13 S14 350Z, Future FRS
#307 |
#308 |
| Visconti Tuning - Who wants to run on e85? or 100 Octane | Visconti | Engine, Exhaust, Transmission | 174 | 05-21-2013 03:00 PM |
| Visconti Tuning Stage 1 Tester #3 (I think) | ruskymx | Engine, Exhaust, Transmission | 46 | 09-15-2012 04:29 AM |
| Visconti Tuning Stage1 candidate | brichard0625 | Engine, Exhaust, Transmission | 134 | 09-03-2012 12:04 PM |
| Another Accelerated Performance Turbo BRZ - Visconti Tuned ! | Visconti | Forced Induction | 34 | 08-28-2012 12:47 AM |
| Visconti Tuning NA STG1 Group Buy | Visconti | Groupbuys | 683 | 08-24-2012 11:28 AM |
