Old 08-29-2012, 11:54 PM   #295
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
No love down under.
TouchMyHonda is offline   Reply With Quote
Old 08-30-2012, 12:15 AM   #296
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Originally Posted by TouchMyHonda View Post
No love down under.
Have love for what Don and John are doing will be a purchaser of their products just didn't realise you were taking the piss lol .....my bad
GC GTS Aero Kit is offline   Reply With Quote
Old 08-30-2012, 03:21 AM   #297
Shiny
Drives: 05 Ford F150 Scrow
The BRZ-300 is perfect with larger injectors, clutch and 10 psi - pumpgas!
305whp.. With e85 that package should make 40-50whp more.
The BRZ-400 is fine at 12-15psi on pumpgas... I was getting bored so I poured the corn in ad turned it up.
If this car lasts we'll spend more time on pumpgas numbers
John
Thanks for the replay. We don’t have E85 hear. All we have is normal gas, no corn.
So I will be ok with the 10psi kit. What is the safest HP I can run and what will be the torque for that.
I am planning to get my Toyota 86 Auto in a year. Can’t afford it now. Just bout a house . Hopefully be then Toyota and Subaru would have fixed any issues with the car. And will see how reliable the boosted car & transition are.
Plus will see what other options will be there.
One more questions, what is the power numbers (HP & Torque) on the NA tune?
Thanks in advance.
Shiny is offline   Reply With Quote
Old 08-30-2012, 03:51 AM   #298
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
^^ about 30 or so whp with just the n/a tune. Great tune.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
The Following User Says Thank You to usptwins For This Useful Post:
Shiny (08-30-2012)
Old 08-30-2012, 04:07 AM   #299
Shiny
So that will be about 200 WHP. What about torque?
Old 08-30-2012, 04:11 AM   #300
serialk11r
Drives: '06 AM V8V Coupe
Peak torque given peak power just tells you how inefficient the setup is at high rpm :P
But seriously, look at the threads where they compare the tuned and stock torque curves, basically you gain a significant amount at high rpm where the engine is running very rich stock, and a moderate amount in the low to mid range. Aka, no massive kick in the pants.
The Following User Says Thank You to serialk11r For This Useful Post:
usptwins (08-30-2012)
Old 08-30-2012, 04:50 AM   #301
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Itll be about 193whp or so, if you look in the first couple of pages, it will show you. Or look at the Visconti flash thread
The Following 2 Users Say Thank You to usptwins For This Useful Post:
Baker (08-30-2012), Shiny (08-30-2012)
Old 08-31-2012, 04:14 AM   #302
Visconti
Drives: 05 STi
Hi Don
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Shiny (09-02-2012)
Old 08-31-2012, 04:41 AM   #303
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Just curious if you guys can enlighten me... How does the response of these turbo setups stack up against lower compression setups? How would you compare the response of the disco and the GT30r?
I'd like to hear some perspective and impressions of how the turbo responds on this engine. The dyno only shows the power output. Obviously the larger turbo is going to loose response, but when do you feel the boost is hitting hard and the throttle response is good?
I've never had a 12.5:1 compression turbo motor build before. I'd imagine that E85 and turbo would work amazing with this compression. Your thoughts gentlemen?
Coheed is offline   Reply With Quote
The Following 2 Users Say Thank You to Coheed For This Useful Post:
Deepseadiver (08-31-2012), TouchMyHonda (08-31-2012)
Old 08-31-2012, 02:22 PM   #304
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Higher compression would result in faster spool time and better out of boost response.
E85 would be a must in my opinion with any real boost. Sure the direct injection will help keep things cooler than solely port injection, but your just asking for trouble with 12.5:1 and 15+psi on pump gas...which is why I'd imagine they switched to e85 for the 400 build. That and timing.
NotSoJDM is offline   Reply With Quote
Old 08-31-2012, 05:15 PM   #305
Coheed
Coheed's Avatar
I'm interested to see if 330-340whp on the disco can be had without going over 13-14psi boost with proper fuel supply and larger injectors. And I know the spool will be quicker, but I am actually really interested in the response of this engine to the turbo mods.
Every subaru I've driven has been pretty unresponsive compared to inline-4 setups because of the long exhaust runners. That's why I'm so curious how this engine responds. I think 330whp is a riot in a 2800lb car. More power is really good too, but this car gets a ton of praise for its responsiveness, I wouldn't want to muddy that.
Plus, another 100whp is only a turbo swap away with simple upgrades.
Old 08-31-2012, 06:21 PM   #306
Rurounimidnight
Rurounimidnight's Avatar
Drives: Past S13 S14 350Z, Future FRS
Yes! Exactly this
Rurounimidnight is offline   Reply With Quote
Old 08-31-2012, 08:31 PM   #307
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by Rurounimidnight View Post
Yes! Exactly this
We made 320whp on the disco on 93 octane last week!
Don@Accelerated is offline   Reply With Quote
The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post:
Shiny (09-02-2012), usptwins (08-31-2012)
Old 08-31-2012, 09:51 PM   #308
Coheed
Coheed's Avatar
Don, how was the response on that turbo setup? I've been in the fwd SR20 game for years and that continues to be my favorite turbo because it is so responsive. How does the suby handle it?
Visconti Tuning - Who wants to run on e85? or 100 Octane Visconti Engine, Exhaust, Transmission 174 05-21-2013 04:00 PM
Visconti Tuning Stage 1 Tester #3 (I think) ruskymx Engine, Exhaust, Transmission 46 09-15-2012 05:29 AM
Visconti Tuning Stage1 candidate brichard0625 Engine, Exhaust, Transmission 134 09-03-2012 01:04 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 01:47 AM
Visconti Tuning NA STG1 Group Buy Visconti Groupbuys 683 08-24-2012 12:28 PM
