#43 |
NW Region Moderator
Drives: FR-S No More
Car has sat for 48 hours with no problems. I should take voltage readings to see what the drop is between sittings... I'll do that tonight and let it sit tomorrow.
#44 |
Grip>Slip
#46 |
Drives: 2018 Golf R
After about a week in my CL the battery was dead.
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | calis5nest (02-22-2013) |
#47 |
Drives: 2013 BRZ, 1967 corvette conv
Not to pee in anyone's Wheaties here, but I was kinda hyped to get this device for my car, then I started reading the following thread:
http://forums.redflagdeals.com/merge...ad-1147913/24/ ... as you can see, it goes for (currently) 74 pages. The executive summary is that it seems that the Blackvue has a fairly noticeable overheating problem, which appears to be exacerbated by leaving it in "park monitor" (or whatever it's called) mode, which is one of the big things I wanted to use it for to begin with. |
#48 | |
Grip>Slip
If I install the power controller to the same constant hot wire that you wired directly to the camera (Positive to the GRN/YEL, Ground to the BLK/YEL), I should be golden, right? |
#49 |
A problem with this device is that it's a clearly visible electronic device to outside bystanders.
I don't like leaving obviously expensive items in plain view inside of any of my cars, reason being to prevent a potential car prowl. This would be better IMO if the camera was more hidden. Not sure if a concealable blackvue-type camera exists... |
#50 | |
Drives: 2017 WRB PP
| The Following User Says Thank You to Hix For This Useful Post: | BRZranger (08-28-2012) |
#51 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Good day. -- F1point4
| The Following User Says Thank You to F1point4 For This Useful Post: | ATL BRZ (08-29-2012) |
#52 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#53 |
Drives: 2013 Argento Silver FR-S
#54 |
Photo Specialist
#55 |
Photo Specialist
Camera install is done. DIY is coming.
#56 |
I just ordered the blackvue and power magic pro, but mine is the "Session 2" version, which supposedly addresses the overheating problem.
| BRZ/FR-S Coilover Installation Guide | GrimmSpeed | DIY (Do-It-Yourself) Guides | 64 | 02-21-2020 05:30 PM |
| Suspension Installation Warning!!!! | Don@Accelerated | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 07-20-2012 06:44 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
| TRD parts installation manual | Nardi330 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 05-21-2012 03:19 AM |
| chrome fender trim installation | taosracer | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-15-2012 03:13 PM |
