#15 |
Koni will probably only be inserts.
We'll have our own custom valved Bilsteins eventually....it takes a while. Just so no one thinks I'm biased, I run Koni yellows on my own personal car (Mini) and love them. Both will be great options. ![]() KYB and Tokico will probably eventually have an option too but again this is something that takes a lot more time than coilovers because tooling is quite a bit more complicated. And that's probably why Koni does inserts for struts. Hopefully I'm wrong and some good options come out soon. - Andrew |
#16 |
Drives: Legacy GT
You'll only have to cut apart the front for Konis at least. In the rear it will be a full replacement shock.
#17 |
Drives: '08 Impreza, 03 SV1000S
#18 |
Senior Citizen
Drives: Scion FR-S
?? I think Koni inserts would require "breaking" that seal with a pipe cutter for install, plus drilling a hole at the bottom to lock them in place. I guess not all manufacturers definition of "applicable products" are the same! LOL!
#19 |
That's why you drill a hole in the bottom to release the fluid and pressure. Then hack off the top of the strut and pull out the guts. The Koni insert happens to fit inside the old body.
#20 | |
Boosted
Drives: Sideways
If I combined this with Eibach Sportlines I could probably achieve an even flush with my wheels.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#21 |
We need to update our site with more BRZ parts...stay tuned.
- Andrew |
#22 | |
Curious cat.
Drives: 86 GT base M/T - Red
Interesting...assuming with these you get lower ride height without compromising shock travel. Am I right? Planning on doing rear mounts to match as well? Curious how these would work with RCE Yellows (if they'd be compatible). Any thoughts on whether the roll centers might begin to go out of whack with the additional drop?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#23 |
Exactly, you get additional drop without using up bump travel. It still does alter geometry, so with the Yellows it is recommended to use the Whiteline roll center kit as well. Not "required" but recommended.
Rear mounts are under consideration. ![]() - Andrew |
#24 | |
Add lightness!
Drives: 17' WRX
Seriously! I had koni inserts on my 02 wrx, they were awesome. I would definitely do that again.
#25 |
Boosted
Drives: Sideways
To drop the rear a little more as well?
#26 |
Drives: gti, nsx, integra type r,porsche911
anybody gonna go KW V3 ....
and call it a day?
#27 |
Default User Title
| AST Dampers just arrived! | Matt Andrews | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 09-20-2012 03:11 PM |
| OE Replacement Dampers | Sccabrz192 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-08-2012 11:52 AM |
