Old 08-04-2012, 02:33 PM   #99
twodollarcuts
Drives: Subaru BRZ Limited
I have slight rattling coming from the front left of my car. When I ride in the passenger's seat it's not as noticeable, but I haven't pinpointed it exactly. I literally picked up my a couple of hours ago from the dealer but didn't really notice it until about halfway home. I didn't notice this on the test drive yesterday. It's most noticeable from 1st to 3rd and then I hear 4 or 5 clicks when I stop. Any clues?
twodollarcuts is offline   Reply With Quote
Old 08-05-2012, 06:52 AM   #100
kgc
Drives: 2013 Subaru BRZ Limited AT
Originally Posted by speedracer38 View Post
Am I the only one noticing that around highway speeds air gets underneath the hood and pushes it up and makes it look like it's floating around?
Your hood is probably not fully closed.
kgc is offline   Reply With Quote
Old 08-05-2012, 08:46 PM   #101
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Good response....but I'm not retarded.
speedracer38 is offline   Reply With Quote
The Following 2 Users Say Thank You to speedracer38 For This Useful Post:
ngabdala (08-21-2012), Subie (08-05-2012)
Old 08-05-2012, 09:02 PM   #102
Subie
Seρor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Thanks for the chuckle. I was wondering when you'd chime in.
Subie is offline   Reply With Quote
Old 08-14-2012, 08:25 PM   #103
warman
warman's Avatar
Drives: WRB BRZ
Didn't want to make a new thread but I don't hear anything specifically mentioned about a rattle I'm hearing in my BRZ.
It seems to be coming from the driver side door, but slightly behind me. It happens when I'm listening to a song that has a lot of bass or when I'm on a road that causes a lot of vibration. If I put my arm on top of the door panel, it stops.
Seems like it's something inside the door panel, but I don't believe it's the one everyone has mentioned near the front of the door by the hinge since this seems to be in the back of the door.
warman is offline   Reply With Quote
Old 08-14-2012, 10:58 PM   #104
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I have a horrible squealing coming from the rear area. It happens every time I release the clutch and press the throttle. Strange phenomenon, this one. :P
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Tujin (09-06-2012)
Old 08-16-2012, 10:24 PM   #105
Zadkiel
Drives: CBS BRZ Limited 6MT
Rattle coming from some location in the rear. Can't pinpoint it because I'm usually going around 70-80 when it starts.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 08-17-2012, 01:35 AM   #106
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
I have had a rattle happen in the rear for me as well. Seems to go away once the car warms up. Sounds almost like the rear brake light in the back window rattling against the glass, but I'm not sure if that's the cause or not...
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
Old 08-17-2012, 11:08 AM   #107
Longhorn248
Hook 'em
Longhorn248's Avatar
You sure it's not just the window switch panel? Sometimes it's hard to locate rattles.
Longhorn248 is offline   Reply With Quote
Old 08-17-2012, 06:11 PM   #108
Zadkiel
Originally Posted by Oriental Life View Post
The rattle I look for is very ocasional knock, most likely coming from the back shelf somewhere. The car is scielent, but lightweight, therefore plastic-metal joints are common in interior.
Don't get me wrong, car is well built, but I'm anal about sounds in any car. Our family Forester had its share of interior rattles (trunk mostly) till I sound proofed it all arround. Now its scilient for a number of years.
I buy Subaru for excellent drivetrain, not for interior :-), however my Limited is huge step forward.
I think I have this, but it starts from 70mph or 80mph. I looked outside and the only thing I can think of is the plastic/rubber mud flap starting to flop around at speed.
Old 08-17-2012, 06:15 PM   #109
Zadkiel
I don't think it's that with mine. I thought it might have been a transmitter rattle as described in another thread, but whatever they did to get the interior trim out, I can't do. I thought it might be an exterior piece but I jacked up the car and can't find anything loose underneath. I'm just clueless AND the dealer hasn't gotten back to me about coming in. I just want to know what it is. That's my whole pet peeve. So long as I know what is making the noise, and if it isn't serious, I don't mind.
Old 08-17-2012, 11:17 PM   #110
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
I actually narrowed it down to the back shelf. Its most likely the amp or the remote key sensor that is causing this metallic sound. Didn't have time lately to search more for it.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
Old 08-17-2012, 11:18 PM   #111
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Mine has low miles still but no noises at all so far.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-19-2012, 11:10 PM   #112
warman
warman's Avatar
Drives: WRB BRZ
I don't think it is.. it doesn't go away at all when i tap the door panel near the window switch, but it does if I put my arm on the rear part of the panel, or if I wind the window down a tiny bit.
