Old 08-01-2012, 06:42 PM   #85
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Originally Posted by brzmass12 View Post
Now I just have to go to the dealer and see if they can fix it as it can get awfully hot in the northeast in the summer.
I wish you luck - I took mine to the dealer with the same issue and they made a big deal that they had tightened the belt up using the idler pulley adjustment. It didn't change anything. If you want it fixed, you'll have to be forceful.
NRGBalanced is offline   Reply With Quote
Old 08-01-2012, 08:53 PM   #86
brzmass12
Drives: SWP BRZ Limited MT
I saw that you are from Boston as well. Mind if I ask you the name of the dealer?
brzmass12 is offline   Reply With Quote
Old 08-01-2012, 09:04 PM   #87
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Call Subaru. For the benefit of not only you but the community at large we need to make sure issues like this one are addressed.
Subie is offline   Reply With Quote
Old 08-02-2012, 11:09 AM   #88
NRGBalanced
PM'ed. They're who I purchased from in the Waltham area and they don't have a stellar service reputation.
Thanks for the advice. What is the protocol for this? Is SOA looking for technical issues, or are you suggesting I comment on my lack of satisfaction with the service I received?
Old 08-02-2012, 12:19 PM   #89
Subie
Señor Member
Subie's Avatar
Both. I don't know exactly how dealers operate, but Subaru may not be aware of the A/C issue. Since others, myself included, are experiencing this problem, it appears to be some sort of design or assembly flaw. Making sure that higher-ups are involved increases the chance of a resolution for you, including a potential TSB.
The Following User Says Thank You to Subie For This Useful Post:
NRGBalanced (08-02-2012)
Old 08-02-2012, 05:45 PM   #90
pastuch
pastuch's Avatar
I have the first legitimate failure in this thread:
My power trunk opener just died. Both the button in the car and the one on my keyfob. I'm pretty pissed, I had every electric motor in my G35 die on me. I'm already starting to wonder when the window motors and power door locks will fail!
pastuch is offline   Reply With Quote
Old 08-02-2012, 06:16 PM   #91
Jayde
Jayde's Avatar
It seems to be a common problem. Take it to the dealer and get it fixed under warranty.
Jayde is offline   Reply With Quote
Old 08-02-2012, 08:02 PM   #92
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
You sure the poorly placed "off" switch in the trunk didn't just get flipped? That turns off the power trunk release and requires the key instead. It's a valet thing but like hell any valet will ever drive my car!
ashtray is offline   Reply With Quote
Old 08-02-2012, 08:06 PM   #93
ashtray
Odd noise the other day from I think the drivers side front dash speaker area. Sounded similar to a blown speaker. I turned the radio off and the noise was still present. Unplugged my iPhone, no change. Went away the next day. Weird.
Old 08-03-2012, 10:57 AM   #94
pastuch
pastuch's Avatar
Thanks for this... I didn't realize there was a switch. That's probably the problem.
Old 08-03-2012, 01:21 PM   #95
pastuch
pastuch's Avatar
Sure enough, my golf club must have pushed the button. Big relief. Thanks gents.
The Following 2 Users Say Thank You to pastuch For This Useful Post:
Da Breeze (04-16-2016), WRXGuy1 (08-03-2012)
Old 08-03-2012, 03:08 PM   #96
Jayde
Jayde's Avatar
Glad it was something simple!
Old 08-04-2012, 03:58 AM   #97
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Am I the only one noticing that around highway speeds air gets underneath the hood and pushes it up and makes it look like it's floating around?
speedracer38 is offline   Reply With Quote
Old 08-04-2012, 01:20 PM   #98
ashtray
^^^You sure your hood is closed all the way?!
