Old 08-12-2012, 12:06 PM   #113
Turbowned
Turbowned's Avatar
The nearest E85 station from me is almost an hour away. I'd burn through probably 3-4 gallons just getting there and back, so I don't really consider it an option. Would a water/meth injection kit allow similar results on pump gas do you think?
Turbowned is offline
Old 08-12-2012, 12:10 PM   #114
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
So badass. I'm curious also to see what kind of heavy abuse it will be able to take at similar power levels.
TylerLieberman is offline
Old 08-12-2012, 12:25 PM   #115
bakerr6
Drives: 2013 raven black fr-s
I'll be running e85 on mine, and will be buying about 300 gallons of fuel on this date each year:
http://clarkcounty.wave3.com/news/bu...arth-day/52698
bakerr6 is offline
Old 08-12-2012, 12:27 PM   #116
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
Originally Posted by digital_assassin View Post
Turbo isn't specific to manual or automatic but you'll get more out of it with a manual. Now that thats out of the way, you should have bought a manual
Ehh, My Elise is Manual - the FR-S is my daily driver that I'm slowly growing fond of upgrading
Kochinopride is offline
Old 08-12-2012, 02:23 PM   #117
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Gotcha.
digital_assassin is offline
Old 08-12-2012, 04:08 PM   #118
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
How long can you store E85?
Parting out HERE
civicdrivr is offline
Old 08-12-2012, 04:14 PM   #119
SnapOv3st3r
Drives: 400whp Scion tC
Yes, Meth Injection will provide the same abilities.
SnapOv3st3r is offline
Old 08-12-2012, 04:26 PM   #120
serialk11r
Drives: '06 AM V8V Coupe
Not exactly, direct injected fuel is much more effective, but if you use 100% methanol then you are getting a lot more cooling effect per equivalence fuel, even if it picks up some extra heat from the valves and heads.
serialk11r is offline
The Following User Says Thank You to serialk11r For This Useful Post:
Allch Chcar (08-13-2012)
Old 08-12-2012, 04:29 PM   #121
bakerr6
E85 doesn't spoil, but it does absorb water. If you are storing e85, you need 2 keep 2 things in mind:
1.) The container you use
2.) The environment
Since it is very sensitive to electricity, soft metals are not good containers to store it in. Also, there are some plastic drums that the fuel will break down. Find 55 gallon drums that are UL guaranteed.
Ethanol will soak up water, so if it is stored in an air-tight container, then technically, it shouldn't ever go bad. However, if you have it sitting in a gas tank, or something else that is exposed to the elements, that would not hold true.
bakerr6 is offline
The Following User Says Thank You to bakerr6 For This Useful Post:
civicdrivr (08-12-2012)
Old 08-12-2012, 04:40 PM   #122
SupraLove
Drives: 2007 Toyota Camry LE, 5AT i4
This is awesome, but it will be interesting to see how long the engine will last with 9psi boost with the high compression and stock internals... I would have thought that the max the FA20 could handle would be 5-6psi until some forged parts come to market. Anyway, this is great news. Great news.
SupraLove is offline
Old 08-12-2012, 05:06 PM   #123
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Damn that is pretty epic. Any of the number crunchers care to calculate power to weight at these levels and find comparable cars?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline
Old 08-12-2012, 05:13 PM   #124
SnapOv3st3r
Sure man, if you say so. I presumed the guy asked the question because e85 may not be readily available to him. It can't be effective, if you can't even get any in your surrounding area.
Old 08-12-2012, 05:25 PM   #125
pinoyplaya
Drives: WRB MT-BRZ LMTD
WoW. I want this now! Damn thats sick!
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline
Old 08-12-2012, 05:35 PM   #126
Zadkiel
Drives: CBS BRZ Limited 6MT
E85 is probably more prevelant in the corn growing areas of the country. US E85 is made from corn stock. I think part of the reason E85 is so hard to come by in some areas is marketing, vehicle age, and manufacturer demand. E85 was marketed as a cleaner burning alternative to gasoline, but it gets worse MPG. That isn't bad if you're driving a supercar or high performance vehicle, but when the majority of vehicles that use it/marketed as flex fuel vehicles are SUV's.....
Vehicle age has a lot to do with it because a lot of the driving populace has cars that are 10 years old or so. Now a days with a lot of cars the manufacturing has gotten better, so the average age of vehicles will increase even more. A lot of those cars were designed without any E85 considerations in mind and it's detrimental to older engines. It's like leaded fuel. A lot of cars were designed to run on it, when they stopped making it, performance, mpg, and reliability suffered.
As far as the manufacturer is concerned, not a lot of vehicle companies make E85 vehicles. The 2 biggest that spring to mind are Chevy and Ford. Not a lot of other car manufacturers produce a vehicle that was designed to run on both. I think the lack of infrastructure, lack of benefit over normal gasoline, and the "buzz" of electric/hybrid vehicles are what is preventing E85 from being adopted.
Again, not busting on the OP, but as bad as our fuel pumps sound on E10, I'd hate to hear it on E85.
http://en.wikipedia.org/wiki/E85
http://en.wikipedia.org/wiki/Flexibl..._United_States
Back in (Crystal) Black.
Zadkiel is offline
horsepower, old hp record, record, scion fr-s, subaru brz, turbo
Highest mileage FRS\BRZ Grishbok BRZ First-Gen (2012+) — General Topics 199 09-22-2018 04:40 PM
Best cruising speed for highest MPG. BrandonFYIA Scion FR-S / Toyota 86 GT86 General Forum 95 03-29-2015 11:53 PM
Dynosty FR-S/BRZ Sound Tube Delete Kit Dustin@Dynosty Engine, Exhaust, Bolt-Ons 104 02-11-2014 11:35 AM
Dynosty Turbo Scion FR-S / BRZ (Dyno and Preview Video) Hal@Dynosty Forced Induction 33 08-25-2013 02:58 PM
new jdm legacy B4 uses FA20 turbo cyde01 Forced Induction 3 07-26-2012 03:00 AM
